I’m trying to use ARM64 version of Nsight Systems CLI package inside an LXD container. Regardless if I use nsys launch+nsys start+nsys stop or nsys launch+“nsys start -x true” nsys always crashes while processing events:
- Using nsys stop:
# nsys stop
Processing events...
Unexpected exception thrown while sending CLI command.
/fast/src/Alt/QuadD/Common/CliCommon/CLICommon.cpp(292): Throw in function QuadDCommon::CliClientUtil::response QuadDCommon::CliCli
entUtil::waitForServerReply(std::__cxx11::string*, int)
Dynamic exception type: boost::wrapexcept<QuadDCommon::IOException>
std::exception::what: IOException
[QuadDCommon::tag_errno_text*] = Resource temporarily unavailable
[QuadDCommon::tag_error_text*] = Failed to read message length
[QuadDCommon::tag_api_function*] = ReadAll
[QuadDCommon::tag_fd*] = 8
[QuadDCommon::tag_errno*] = 11
- Using nsys launch with stop-on-exit=true
# nsys launch -w false -s none -t opengl <app name and parameters>
WARNING: Backtraces will not be collected because sampling is disabled.
application launched
^CSignal 2 (SIGINT) was forwarded to the target application process group 17603
The target application terminated with signal 2 (SIGINT)
/fast/src/Alt/QuadD/Common/CliCommon/CLICommon.cpp(292): Throw in function QuadDCommon::CliClientUtil::response QuadDCommon::CliClientUtil::waitForServerReply(std::__cxx11::string*, int)
[QuadDCommon::tag_errno_text*] = No child processes
[QuadDCommon::tag_fd*] = 20
[QuadDCommon::tag_errno*] = 10
Versions I use:
- nsight-systems-cli-2020.4.1_2020.4.1.126-1_arm64.deb
- Host and inside containers:
# uname -a
Linux emag-ubuntu18 5.4.0-48-generic #52~18.04.1-Ubuntu SMP Thu Sep 10 12:54:16 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
- GPU and drivers:
# nvidia-smi
Mon Oct 19 09:37:16 2020
| NVIDIA-SMI 450.51.06 Driver Version: 450.51.06 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Quadro RTX 4000 On | 00000000:01:00.0 Off | N/A |
| 30% 29C P8 2W / 125W | 1MiB / 7982MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Is it a bug in Nisght Systems or something is wrong with my container?
