Array Expression
Hello, why does this little program give me an error?
  • program array
    real :: a(4),b(4)
a=(/0.,3.,3.,1./)
b=(/0.,3.,3.,1./)
if (a.eq.b) write (6,*) “a and b are the same”
stop
end
PGF90-S-0083-Vector expression used where scalar expression required (array.f: 8)
0 inform, 0 warnings, 1 severes, 0 fatal for array
I thought Fortran 90 allowed these expressions. Thanks!
Hi lionel,
The expression “a.eq.b” is valid. However, the expression returns an array of logicals which can’t be used in an if statement. Adding the ‘all’ intrinsic to perform a reduction should get the desired behavior:
% cat tmp.f90
      program array
      real :: a(4),b(4)
      a=(/0.,3.,3.,1./)
      b=(/0.,3.,3.,1./)
      if (all(a.eq.b)) write (6,*) "a and b are the same"
      stop
      end
% pgf90 tmp.f90
% a.out
FORTRAN STOP
Hope this helps,
Mat
