Array in struct bug on Fermi
I recently got a GTX 480, which replaced my GTX 285, and updated to version 3.1 of the SDK. I have since then had problems with structures containing arrays. I have attached a small example that demonstrates the problem, and the following lines of CL kernel code is an excerpt of that. If run, the next cl-call returns CL_INVALID_COMMAND_QUEUE.
typedef struct Data
  float data[1];
} Data;
float get(Data data) {
  return data.data[0];
__kernel void bug_kernel(__global Data* datas)
  Data data0 = datas[0];
  Data data1 = datas[1];
  data0.data[0] = get(data1);
  datas[0] = data0;
Have anyone else had similar problems? Does the attached application give other results on your machines?
NVIDIA_arrayInStruct_bug.zip (4.45 KB)
Technically, composite types like structs and pointers which are nested cannot be passed as kernel arguments, so the behavior is undefined…
I am aware that pointers in structs are problematic, but pointers and arrays are not the same thing and I cannot remember anyone pointing out that arrays in structs should produce undefined behavior. Is this explicitly stated in the specification, or any other documentation?
