Array index in the device programm Improvment of the array index calculation in the device programm
Hello everyone !
To simplify, I had 2 2D arrays of 256*24 and one 1D array of 24. I want to add every cells of the 2D array and multiply the result by the corresponding row of the 1D array.
Here is my code :
// Kernel that executes on the CUDA device
__global__ void compute(float *result, int H, int W, float* x, float* a,float* b)
  int idx=threadIdx.x + blockIdx.x* blockDim.x;
  int idy=threadIdx.y + blockIdx.y* blockDim.y;
int index =idx + idy*W;
  // Modulo H : idxxx=index % H
  int idxx=(int)index/H;
  int idxxx=index - 24*idxx;
if ( idx < W && idy < H ) result[index]= (a[index]+b[index])*x[idxxx];
main()
int i=0,j=0;
  int H=24;
  int W=256;
  float h_Result[W][H];
// variables which will be used by the device
  float *d_ParamA;
  float *d_ParamB;
  float *d_ParamX;
  float *d_Result;
// Matrix allocation
  float ParamA[W][H];
  float ParamB[W][H];
  float ParamX[H];
size_t pitch_r,pitch_a,pitch_b;
// Matrix filling
  for (i=0;i<W;i++)
	for(j=0;j<H;j++)
		ParamA[i][j]=i+1;
		ParamB[i][j]=2*(i+1);
		} // for j
	} // for i
  for(j=0;j<H;j++) ParamX[j]=j;
	  // Memory size definition
  dim3 threadPerBlock(32,8);
  dim3 dimGrid(W/threadPerBlock.x , H/threadPerBlock.y);
	  // Memory allocation
  //2D
  cudaMallocPitch((void**) &d_Result, &pitch_r, W*sizeof(float), H);
  cudaMallocPitch((void**) &d_ParamA, &pitch_a, W*sizeof(float), H);
  cudaMallocPitch((void**) &d_ParamB, &pitch_b, W*sizeof(float), H);
  //1D
  cudaMalloc((void**)&d_ParamX,H*sizeof(float));
	  // Memory copying
  //2D
  cudaMemcpy2D(d_ParamA,pitch_a,ParamA,W*sizeof(float),W*sizeof(float),H,cudaMemcpyHostToDevice);
  cudaMemcpy2D(d_ParamB,pitch_b,ParamB,W*sizeof(float),W*sizeof(float),H,cudaMemcpyHostToDevice);
  //1D
  cudaMemcpy(d_ParamX,ParamX,H*sizeof(float),cudaMemcpyHostToDevice);
	  // Compute
  compute<<<dimGrid,threadPerBlock>>>(d_Result,H,W,d_ParamX,d_ParamA,d_ParamB);
// Memory copying
  cudaMemcpy2D(h_Result,W*sizeof(float),d_Result,W*sizeof(float),W*sizeof(float),H,cudaMemcpyDeviceToHost);
//Print the result
  for(i=0;i<W;i++)
	  for(j=0;j<H;j++)
	  printf("%5d ", (int)h_Result[i][j]);
	  printf("\n");
cudaFree(d_ParamX);
  cudaFree(d_Result);
  cudaFree(d_ParamA);
  cudaFree(d_ParamB);
This code works perfectly but I spent the whole afternoon drawing lots of schemes to find which index I had to choose for the X array (idxxx) !
Finally I’ve done a modulo of the index by 24 (when the index is 32 the index of the X array is 7)
But It does not look like a good way to compute the index and I still think that it exists a really easiest way to do it (in terms of computation time for the GPU)
Does anybody got an idea on this ?
I didn’t really get what problems you have with ‘%’ operator and why do you need to do your own implementation of that.
Besides that I’d replace ‘*’ with __umul24 (which is faster for current generation hardware) and would think about making your ‘x’ array power of 2 (so that you could replace ‘% H’ with ‘& H’ (edit: & (H-1) of course ;) ). You could also do several iterations of your algorithm per thread to absorb index calculation cost (as many samples in sdk do).
