I have a problem with the following code:
#include <stdio.h>
#include <cuComplex.h>
#include "cuda.h"
extern "C" struct vector
float x;
float y;
float z;
} vector;
struct vector *test;
__device__ struct vector *d_test;
const int dim = 50;
__global__ void d_testfunc(struct vector *values)
values[0].z = 3;
int main()
test = (struct vector*) malloc(sizeof(vector) * dim);
cudaMalloc((void**)&d_test, sizeof(vector) * dim);
for (unsigned int i=0; i<dim; i++)
test[i].x = 2;
test[i].y = 2;
test[i].z = 2;
printf("initial: %g\n", test[0].z);
cudaMemcpy(d_test, test, sizeof(vector) * dim, cudaMemcpyHostToDevice);
d_testfunc<<<1,1>>>(d_test);
cudaMemcpy(test, d_test, sizeof(vector) * dim, cudaMemcpyDeviceToHost);
printf("final : %g\n", test[0].z);
Running it like that does exactly what it should, it write “2” and “3”.
But when I change the data type in my vector from “float” to “double” it stops working, the output will be “2” both times. In my program I sadly need doubles. Why do doubles mess things up? Is there any way around it?
#include <stdio.h>
#include "cuda.h"
float x;
float y;
float z;
} vector;
const int dim = 50;
values[0].z = 3;
int main()
test[i].x = 2;
test[i].y = 2;
test[i].z = 2;
London
October 17, 2010, 9:05am
3
#include <stdio.h>
#include "cuda.h"
float x;
float y;
float z;
} vector;
const int dim = 50;
values[0].z = 3;
int main()
test[i].x = 2;
test[i].y = 2;
test[i].z = 2;
Did you choose the compute capability when you compile?
London
4
#include <stdio.h>
#include "cuda.h"
float x;
float y;
float z;
} vector;
const int dim = 50;
values[0].z = 3;
int main()
test[i].x = 2;
test[i].y = 2;
test[i].z = 2;
Oh, I didn’t know I have to manually specify that (I’m using a 1.3 card).
Compiling it with -arch compute_13 solved the problem, thanks.
