Whenever I set more than four arrow_params, only a maximum of four will be displayed.
static gboolean
overlay_graphics(AppCtx *appCtx, GstBuffer *buf,
NvDsBatchMeta *batch_meta, guint index)
int srcIndex = appCtx->active_source_index;
if (srcIndex == -1)
return TRUE;
NvDsFrameLatencyInfo *latency_info = NULL;
NvDsDisplayMeta *display_meta =
nvds_acquire_display_meta_from_pool(batch_meta);
display_meta->num_labels = 1;
display_meta->text_params[0].display_text = g_strdup_printf("Source: %s",
appCtx->config.multi_source_config[srcIndex].uri);
display_meta->text_params[0].y_offset = 20;
display_meta->text_params[0].x_offset = 20;
display_meta->text_params[0].font_params.font_color = (NvOSD_ColorParams){
0, 1, 0, 1};
display_meta->text_params[0].font_params.font_size =
appCtx->config.osd_config.text_size * 1;
display_meta->text_params[0].font_params.font_name = "Serif";
display_meta->text_params[0].set_bg_clr = 1;
display_meta->text_params[0].text_bg_clr = (NvOSD_ColorParams){
0, 0, 0, 0.5};
int i = 0;
NvOSD_LineParams *line_params = display_meta->line_params;
NvOSD_ArrowParams *arrow_params = display_meta->arrow_params;
cv::Point points[] = {
{0, 0}, {100, 100}, {200, 200}, {300, 300}, {400, 400}, {500, 500}, {600, 600}, {700, 700}, {800, 800}, {900, 900}, {900, 900}, {1000, 800}};
NvOSD_ColorParams arrow_color = {1.0, 1.0, 0.0, 1.0};
int arrow_width = 1;
for (int j = 0; j < 12; j += 2)
arrow_params[i].x1 = points[j].x;
arrow_params[i].y1 = points[j].y;
arrow_params[i].x2 = points[j + 1].x;
arrow_params[i].y2 = points[j + 1].y;
arrow_params[i].arrow_width = arrow_width;
arrow_params[i].arrow_color = arrow_color;
arrow_params[i].arrow_head = END_HEAD;
display_meta->num_arrows++;
i++;
if (nvds_enable_latency_measurement)
g_mutex_lock(&appCtx->latency_lock);
latency_info = &appCtx->latency_info[index];
display_meta->num_labels++;
display_meta->text_params[1].display_text = g_strdup_printf("Latency: %lf",
latency_info->latency);
g_mutex_unlock(&appCtx->latency_lock);
display_meta->text_params[1].y_offset = (display_meta->text_params[0].y_offset * 2) +
display_meta->text_params[0].font_params.font_size;
display_meta->text_params[1].x_offset = 20;
display_meta->text_params[1].font_params.font_color = (NvOSD_ColorParams){
0, 1, 0, 1};
display_meta->text_params[1].font_params.font_size =
appCtx->config.osd_config.text_size * 1.5;
display_meta->text_params[1].font_params.font_name = "Arial";
display_meta->text_params[1].set_bg_clr = 1;
display_meta->text_params[1].text_bg_clr = (NvOSD_ColorParams){
0, 0, 0, 1.0};
nvds_add_display_meta_to_frame(nvds_get_nth_frame_meta(batch_meta->frame_meta_list, 0), display_meta);
return TRUE;
