ARS408 Compatibility with Xavier
I will be connecting 6x ARS408 continental Radars to Xavier through CAN, will the bus load handle? also the radars require high speed CAN 500 kb/s is it supported by Xavier?
Hi, please check the module datasheet for detail CAN feature info. https://developer.nvidia.com/jetson-agx-xavier-series-datasheet
Xavier has two CAN ports available which supports speed 500kb/s as well as 1Mbps. You can connect Radars on CAN.
Thanks,
Shubhi
