Artefacts after sleeping (very-very old issue, again)
Hello. I’m going to create a new topic with very old issue: the artefacts after waking up.
I noted that it was fixed in drievr v396, but I still have artefacts in v430 (currently recommended).
I tested it in Kubuntu 18.04 and KDE nenon distros.
I tried drivers v430, v396 and v390 (current version from Ubuntu’s repo) on clean linux installations.
Early I watched that bug in Linux Mint 18.3 (Mate, based on Gtk).
I’m watching that behavior for:
here is information about my GPU:
$ nvidia-smi
Thu Jul 11 09:31:59 2019
| NVIDIA-SMI 390.116                Driver Version: 390.116                   |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce 930MX       Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   44C    P0    N/A /  N/A |    376MiB /  2004MiB |      5%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0      1055      G   /usr/lib/xorg/Xorg                           152MiB |
|    0      1304      G   /usr/bin/kwin_x11                             34MiB |
|    0      1312      G   /usr/bin/krunner                               1MiB |
|    0      1356      G   /usr/bin/latte-dock                           20MiB |
|    0      3096      G   /opt/viber/Viber                              43MiB |
|    0      3338      G   ...-token=4A24D0C805C30E72C1D096600892DF86     2MiB |
|    0      4763      G   ...-token=474A0E615221D3282EE8EB43B3819EAF    59MiB |
|    0     22317      G   /usr/bin/plasmashell                          58MiB |
(currently I returned back to driver version from official repo, because I don’t see any difference between newest version from PPA and older from official repo)
nouveau driver haven’t that problems.
What I’m doing wrong?
Any ideas?
Please see this:
https://devtalk.nvidia.com/default/topic/1056541/linux/gnome-shell-crashes-and-rendering-problems-on-xserver-with-430-26/post/5359597/#5359597
thank you!
I posted my result in that topic.
I have similar issue with driver v435.21
Sun Dec 22 17:53:30 2019
| NVIDIA-SMI 435.21       Driver Version: 435.21       CUDA Version: 10.1     |
|   0  GeForce MX150       Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   44C    P5    N/A /  N/A |    864MiB /  2002MiB |      0%      Default |
|    0      1055      G   /usr/lib/xorg/Xorg                           307MiB |
|    0      1633      G   cinnamon                                      36MiB |
|    0      4087      G   ...Soft/Defold/packages/jdk11.0.1/bin/java    46MiB |
|    0      4219      G   ...8912a0ec9758c/x86_64-linux/bin/dmengine    30MiB |
|    0      4357      G   ...-token=A7D79135B465CA1669272D9BE983CD98   375MiB |
|    0      4890      G   ...uest-channel-token=11176400498561509263    30MiB |
|    0      6389      G   ...uest-channel-token=15246403314640632525    36MiB |
|    0     10535      G   /usr/lib/firefox/firefox                       1MiB |
Can you read?
generix has posted a solution which works. Use it.
Actually problem was solved in plasma 5.17 and Qt 5.13
And all nvidia drivers works fine “out of the box” without any additional manipulations.
Plasma 5.18 was released today: https://kde.org/announcements/plasma-5.18.0
It promises fixing various visual glitches.
I’d say based on r3d9u11’s comment, the issue should be fixed in the latest release too. Too bad I’m on Kubuntu 18.04 and have to wait a while for the latest version of Plasma to be available.
VT switching for anything gpu intensive non-kde related is still broken for similar reasons.
Nvidia can’t expect everyone to make workarounds for their bugged and obsolete driver.
