I have written codes for the kernel,but after building solution,there is an error which said :“can’t generate code for non empty constructors or destructors on device”,I don’t know why this happened,and how to solve this problem,So I ask for help,Thank you very much!
Related topics
| Ask for help! Build error in VC2005 | 5 | 5156 | July 2, 2010 | |
| Cuda dll init error | 0 | 2774 | August 20, 2008 | |
| Internal error occurred problem | 0 | 3102 | May 14, 2008 | |
| Error building simple cuda project | 0 | 689 | November 27, 2011 | |
| how to fix the prj0019 a tool returned an error code from compiling with cuda build rule... | 1 | 1497 | June 13, 2013 | |
| Internal error compiling C++ code | 0 | 1427 | June 12, 2008 | |
| Compliation error - Description Resource Path Location Type expected constructor, destructor, or typ | 0 | 3177 | February 26, 2012 | |
| Cant compile on the GPU Allways console tell "Using device 0 - device emulation" | 1 | 2984 | December 16, 2008 | |
| build errors with visual studio but cuda program runs | 1 | 815 | January 20, 2020 | |
| Can't build any CUDA SDK sample | 0 | 1125 | March 6, 2012 |
