Using Jetson Orin NGX 64GB
Operating System - Ubuntu 20.04.5 LTS
Riva Version - arm64 v2.7.0
First I run bash riva_init.sh
and then I try running script from tutorial:
riva_asr_client --audio_file=/opt/riva/wav/en-US_sample.wav
I got follwing error:
Client output:
I1128 10:22:37.429924 420 riva_asr_client.cc:445] Using Insecure Server Credentials
Loading eval dataset...
filename: /opt/riva/wav/en-US_sample.wav
Done loading 1 files
RPC failed: Error: Unavailable model requested. Lang: en-US, Type: offline
Done processing 1 responses
Some requests failed to complete properly, not printing performance stats
Server output:
I1128 10:22:37.434805 197 grpc_riva_asr.cc:492] ASRService.Recognize called.
I1128 10:22:37.434899 197 riva_asr_stream.cc:214] Detected format: encoding = 1 numchannels = 1 samplerate = 16000 bitspersample = 16
I1128 10:22:37.434916 197 grpc_riva_asr.cc:558] ASRService.Recognize performing streaming recognition with sequence id: 1905442010
E1128 10:22:37.434995 197 grpc_riva_asr.cc:407] Error: Unavailable model requested. Lang: en-US, Type: offline
server-output.txt (10.4 KB)
config.sh (9.7 KB)
I am not seeing any citrinet_256 RMIR file in model_repository. I’ve also tried default ASR conformer model but the output was the same. Somehow script which should initialize riva server do not download all required files.
Any ideas?
HI @tymonzar
Thanks for your interest in Riva,
Thanks for sharing the config.sh file,
I can see the offline model is present (uncommented)
I kindly request to try
bash riva_clean.sh
rerun bash riva_init.sh
And let me know whether it works,
Also if still not working, please send docker logs riva-speech
complete output as file in this thread
Hi @rvinobha ,
thanks for contact - unfortunately it did not help. Here is the log:
I am also attaching full output after issuing bash riva_start.sh
(as riva-full-log.txt file)
riva-speech-logs.txt (1.6 KB)
riva-full-log.txt (88.0 KB)
Any updates on that issue?
Hi @tymonzar
Apologies, I will check with the team and provide updates
Hi @tymonzar
Offline Model is not packaged as prebuilt for embedded by default, Please fins the instruction below to add
Open config.sh
find models_asr
and add the below highlighted change
"${riva_ngc_org}/${riva_ngc_team}/rmir_asr_${asr_acoustic_model}_${modified_lang_code}_ofl:${riva_ngc_model_version}"
After the change the code will look like below
Now your offline model will work after this addition
I believe you should add this info somewhere. The quick start instruction is not correct for that case.
Thanks @tymonzar for your feedback
This will be added as code in config.sh in upcoming version
system
Closed
December 29, 2022, 1:38pm
#9
