Hello together,
I am trying to execute the simple cuda programs, below:
file name: vector_add.cu
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <assert.h>
#include <cuda.h>
#include <cuda_runtime.h>
#define N 10000000
#define MAX_ERR 1e-6
__global__ void vector_add(float *out, float *a, float *b, int n) {
for(int i = 0; i < n; i ++){
out[i] = a[i] + b[i];
int main(){
float *a, *b, *out;
float *d_a, *d_b, *d_out;
// Allocate host memory
a = (float*)malloc(sizeof(float) * N);
b = (float*)malloc(sizeof(float) * N);
out = (float*)malloc(sizeof(float) * N);
// Initialize host arrays
for(int i = 0; i < N; i++){
a[i] = 1.0f;
b[i] = 2.0f;
// Allocate device memory
cudaMalloc((void**)&d_a, sizeof(float) * N);
cudaMalloc((void**)&d_b, sizeof(float) * N);
cudaMalloc((void**)&d_out, sizeof(float) * N);
// Transfer data from host to device memory
cudaMemcpy(d_a, a, sizeof(float) * N, cudaMemcpyHostToDevice);
cudaMemcpy(d_b, b, sizeof(float) * N, cudaMemcpyHostToDevice);
// Executing kernel
vector_add<<<1,1>>>(d_out, d_a, d_b, N);
// Transfer data back to host memory
cudaMemcpy(out, d_out, sizeof(float) * N, cudaMemcpyDeviceToHost);
// Verification
assert(fabsf(out[i] - a[i] - b[i]) < MAX_ERR);
printf("out[0] = %f\n", out[0]);
printf("PASSED\n");
// Deallocate device memory
cudaFree(d_a);
cudaFree(d_b);
cudaFree(d_out);
// Deallocate host memory
free(a);
free(b);
free(out);
the program compile on
nvcc -o vector_add vector_add.cu
Once I execute the program, I get the following error:
vector_add: vector_add.cu:49: int main(): Assertion `fabsf(out[i] - a[i] - b[i]) < MAX_ERR' failed.
Aborted
Which means, that I cannot use the CUDA optimized programs. Could someone help where is the problem.
My environment is as follows:
~/Downloads$ nvcc -V
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:33:58_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
/Downloads$ nvidia-smi
Fri Jun 23 11:13:17 2023
| NVIDIA-SMI 525.85.12 Driver Version: 525.85.12 CUDA Version: N/A |
| | | MIG M. |
| 0 Quadro RTX 4000 Off | 00000000:01:00.0 Off | N/A |
| 22% 49C P0 35W / 125W | 1MiB / 8192MiB | 10% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Thank you very much in advance.
Kind Regards
Arun
