Assertion failure at line 1440 of ../../be/cg/cgem
I tried several simple expamples from SDK and write own ones, all were ok. Now I write an algorithm and cannot compile it. Please, help me!!! I got an compilation error:
[ilgis@srv003 NW]$ nvcc -I../NVIDIA_CUDA_SDK/common/inc/ --verbose gpu.cu
#$ SPACE=
#$ HERE=/usr/local/cuda/bin
#$ TOP=/usr/local/cuda/bin/..
#$ LD_LIBRARY_PATH=/usr/local/cuda/bin/../lib:/usr/local/cuda/bin/../extools/lib:/usr/local/cuda/lib
#$ PATH=/usr/local/cuda/bin/../open64/bin:/usr/local/cuda/bin/../bin:/usr/kerberos/bin:/usr/lib64/ccache:/usr/local/bin:/bin:/usr/bin:.:/bin:~/bin:/usr/local/bin:/usr/local/cuda/bin:/sbin:/usr/sbin:/home/ilgis/bin
#$ INCLUDES=“-I/usr/local/cuda/bin/../include” “-I/usr/local/cuda/bin/../include/cudart”
#$ LIBRARIES= “-L/usr/local/cuda/bin/../lib” -lcuda -lcudart
#$ PTXAS_FLAGS=
#$ OPENCC_FLAGS=
#$ gcc -E -x c++ -DCUDA_NO_SM_11_ATOMIC_INTRINSICS -DCUDA_FLOAT_MATH_FUNCTIONS “-I/usr/local/cuda/bin/../include” “-I/usr/local/cuda/bin/../include/cudart” -I. -D__CUDACC__ -C -I"../NVIDIA_CUDA_SDK/common/inc/" -include “cuda_runtime.h” -m64 -o “/tmp/tmpxft_00003e9a_00000000-3.ii” “gpu.cu”
#$ cudafe --m64 “-I/usr/local/cuda/bin/../include” “-I/usr/local/cuda/bin/../include/cudart” -I. --gen_c_file_name “/tmp/tmpxft_00003e9a_00000000-0.c” --gen_device_file_name “/tmp/tmpxft_00003e9a_00000000-0.gpu” --include_file_name /tmp/tmpxft_00003e9a_00000000-2.c --diag_error=host_device_limited_call --no_exceptions -tused -I"../NVIDIA_CUDA_SDK/common/inc/" “/tmp/tmpxft_00003e9a_00000000-3.ii”
#$ gcc -E -x c -DCUDA_NO_SM_11_ATOMIC_INTRINSICS -DCUDA_FLOAT_MATH_FUNCTIONS “-I/usr/local/cuda/bin/../include” “-I/usr/local/cuda/bin/../include/cudart” -I. -D__CUDACC__ -C -I"../NVIDIA_CUDA_SDK/common/inc/" -m64 -o “/tmp/tmpxft_00003e9a_00000000-4.i” “/tmp/tmpxft_00003e9a_00000000-0.gpu”
#$ cudafe --m64 --c “-I/usr/local/cuda/bin/../include” “-I/usr/local/cuda/bin/../include/cudart” -I. --gen_c_file_name “/tmp/tmpxft_00003e9a_00000000-5.c” --gen_device_file_name “/tmp/tmpxft_00003e9a_00000000-5.gpu” --include_file_name /tmp/tmpxft_00003e9a_00000000-2.c --diag_error=host_device_limited_call -I"../NVIDIA_CUDA_SDK/common/inc/" “/tmp/tmpxft_00003e9a_00000000-4.i”
#$ gcc -E -x c -DCUDA_NO_SM_11_ATOMIC_INTRINSICS -DCUDA_FLOAT_MATH_FUNCTIONS “-I/usr/local/cuda/bin/../include” “-I/usr/local/cuda/bin/../include/cudart” -I. -D__CUDABE__ -I"../NVIDIA_CUDA_SDK/common/inc/" -m64 -o “/tmp/tmpxft_00003e9a_00000000-1.i” “/tmp/tmpxft_00003e9a_00000000-5.gpu”
#$ nvopencc -TARG:sm_10 -m64 “/tmp/tmpxft_00003e9a_00000000-1.i” -o “/tmp/tmpxft_00003e9a_00000000-6.ptx”
Assertion failure at line 1440 of ../../be/cg/cgemit.cxx:
Compiler Error in file /tmp/tmpxft_00003e9a_00000000-1.i during Assembly phase:
incorrect register class for operand 0
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be returned non-zero status 1
–error 0x100 –
Please, help me how to escape this compuler bug!
Thank you
Ilghiz
gpu.cu.zip (2.13 KB)
This looks like a known bug. Are you seeing this with a specific SDK app, or only your own code? Is this specific to x86_64 Linux?
Sorry, I did not find it somewere else.
The application is written from the scratch. I have Fedora with Xeon 2 Gb and NVidia 8800 GTX.
Playing with different parameters I found that it is around
t=B[CI]+pII[CI];
in the line 226 of my source.
At least I have a solution for me, however it can occur somewere else.
Sincerely
Ilghiz
I just encountered this same error myself in my own code.
What exactly is the known bug, and what was the workaround?
Thanks,
Nick
Could it be the pointer array?
Try using indices.
I had a similar error. In my case it was a pointer array which accidentally pointed to host memory. After I fixed this everything worked fine.
