I have the following pipeline (my original pipeline has more elements, I removed several of them such as nvinfer and real sinks in order to provide here a minimal reproducible example):
gst-launch-1.0 \
uridecodebin uri="file:///home/ubuntu/testvids/vid1.m4v" ! m.sink_0 \
nvstreammux name = "m" width=1920 height=1080 batch-size=1 ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=RGBA" ! nvstreamdemux name=d \
d.src_0 ! tee name=t \
t.src_0 ! queue ! nvvideoconvert ! 'video/x-raw, format=I420' ! fakesink sync=false \
t.src_1 ! queue ! nvdsosd ! fakesink sync=false
The above pipeline produces the following output with both DS 5.0 and 5.1:
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
(gst-launch-1.0:11074): GStreamer-CRITICAL **: 00:13:22.404: gst_caps_get_structure: assertion 'index < GST_CAPS_LEN (caps)' failed
(gst-launch-1.0:11074): GStreamer-CRITICAL **: 00:13:22.404: gst_structure_fixate: assertion 'GST_IS_STRUCTURE (structure)' failed
Caught SIGSEGV
#0 0x0000007f91029e28 in __GI___poll (fds=0x557d632dc0, nfds=547894817672, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
#1 0x0000007f91136f58 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x000000557ca6ebe0 in ()
My questions are: why do I get the Critical errors, what’s wrong with it, and how can I fix it?
Thank you in advance!
• Hardware Platform (Jetson / GPU) AGX
• DeepStream Version Both 5.0 and 5.1
