However, now I’m wondering if applying this patch alone doesn’t fully resolve the issue —it looks like we also need to update the TOS image. So, 1) I’d like to know if that means the patch isn’t necessary once the TOS update is applied? 2) If we do need the TOS image fix, could you advise how to apply it on top of JetPack 5.1.4, is there a patch for that?
Please note that the fix is included in tos image(i.e. A_secure-os, B_secure-os partition) rather than UEFI binary(i.e. A_cpu-bootloader, B_cpu-bootloader partition).
You can simply update the tos image in BSP package(i.e. <Linux_for_Tegra>/bootloader/tos-optee_t234.img) and reflash the board or create the capsule payload for capsule update to apply the change.
Latest JP5.1.5 is a L4T 35.6.2.
The TOS image for 35.6.1 is from March, and the one for 35.6.2 is from May, as mentioned. Does that make any difference?
Dear Nvidia support team, Dear KevinFFF.
Is there a plan to include patch for assertion 3 error to Jetpack 5.1.X ?
I am using 5.1.6 and the problem is still here.
Thank you.
Are you using the Orin Nano devkit so you used SDK manager to flash?
If so, how did you reproduce the issue?
Could you share the detailed steps with us to verify?
Yes, I am using Orin Nano Devkit 8GB Ram.
Yes, I have used SDK manager to flash it. (SDK manager installation file : sdkmanager_2.4.0-13235_amd64.deb)
Assertion issue has occurred when I tried your method.: Select Device Manager → NVIDIA Configuration → Reset Setting. ; Go back top menu and press Reset to Exit ; repeat
