!tlt ssd train --gpus 4 --gpu_index=$GPU_INDEX \
-e $SPECS_DIR/ssd_train_resnet18_kitti.txt \
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned \
-k $KEY \
-m $USER_EXPERIMENT_DIR/pretrained_resnet18/tlt_pretrained_object_detection_vresnet18/resnet_18.hdf5
Throwing the error log mentioned below.
When I am using --gpus 4. I am having 4gpus (4 v100s).
When I used 1 training started, but not with 4.
Using TensorFlow backend.
File "/usr/local/bin/ssd", line 8, in <module>
sys.exit(main())
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/ssd/entrypoint/ssd.py", line 12, in main
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 315, in launch_job
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 224, in set_gpu_info_single_node
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 201, in check_valid_gpus
**AssertionError: The number of GPUs ([1]) must be the same as the number of GPU indices (4) provided.**
2021-06-18 10:54:49,490 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
The ssd_train_resnet18_kitti.txt looks like this:
training_config {
batch_size_per_gpu: 16
num_epochs: 2
enable_qat: false
learning_rate {
soft_start_annealing_schedule {
&& nvidia-smi
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| | | MIG M. |
| 0 Tesla V100-SXM2... On | 00000000:00:1B.0 Off | 0 |
| N/A 35C P0 37W / 300W | 0MiB / 16160MiB | 0% Default |
| | | N/A |
| 1 Tesla V100-SXM2... On | 00000000:00:1C.0 Off | 0 |
| N/A 35C P0 35W / 300W | 0MiB / 16160MiB | 0% Default |
| | | N/A |
| 2 Tesla V100-SXM2... On | 00000000:00:1D.0 Off | 0 |
| N/A 36C P0 41W / 300W | 0MiB / 16160MiB | 0% Default |
| | | N/A |
| 3 Tesla V100-SXM2... On | 00000000:00:1E.0 Off | 0 |
| N/A 36C P0 42W / 300W | 0MiB / 16160MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
