Hi, first post here, happy to be part of early access program
So to my question:
Most of our usd file uses the default AR (pixar asset resolver), to solve paths, using search paths
With other usd dccs and applications we use, we just set this env variable, and AR will solve the path
set PXR_AR_DEFAULT_SEARCH_PATH=/mnt/projects/kutoppen2;N:/kutoppen2
a path would look somthing like this,
prepend references = @output/cache_anim/q022.0/shots/q022.0_s001.0/v001/cache/_CAMERAS/_CAMERAS.usd@</Root__CAMERAS>
Hi @raymond ! I believe this was resolved when topic was moved to another thread…if not, my apologies! Please let me know if the latest version is still giving you trouble. Thank you!
he / him | LinkedIn | Discord ID: Prof E#2041
Omniverse: “A New Era of Collaboration and Simulation” (video)
Omniverse Create’s latest features show & tell: Twitch livestream.
As seen in VentureBeat | Physics Showcase
PLEASE NOTE: If you are reporting a bug/issue, please provide OS, GPU, GPU Driver, the version of the app, and full log file (if applicable). For crashes, please zip and provide a link to your logs → C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs
