Hi I’ve enabled the use of lsm6dsr module and I’ve noticed all hard IRQ handling (/proc/interrupts) are done in core 0. the problem is that when connecting USB camera + external SDD + M.2 WiFi adapter the core gets to busy and that affects the lsm6dsr interrupt calls.
I’ve tried to set the smp_affinity for the lsm6dsr IRQ but I get: bash: echo: write error: Input/output error.
I’m using main GPIO PCC.03. mapped to IRQ 294
any suggestion about how to set the GPIO IRQ core affinity ?
Hi tomer.rubinstein,
Are you using the devkit or custom board for Orin NX?
What’s your Jetpack version in use
Which interface are you using for LSM6DSR module?
Do you mean LSM6DSR work as expected if you don’t connect “USB camera + external SDD + M.2 WiFi adapter”?
It seems you have multiple peripherals connected.
Could you share the block diagram of your connections?
