Assigning explicit locations for in/out block members results in incorrect values computed in the ge
I’m trying to visualize the face normals for a mesh,
using the geometry shader to generate lines represeting the normal vectors. My intention was to draw that line from the triangles centroid, extenting a certain amount in the normal’s direction.
This is the vertex shader’s code :
#version 450 core
layout (location = 0) in vec3 vs_in_pos;
layout (location = 1) in vec3 vs_in_normal;
layout (location = 2) in vec2 vs_in_texc;
out VS_OUT_GS_IN {
    layout (location = 0) vec3 pos;
    layout (location = 1) vec3 normal;
    layout (location = 2) vec2 texc;
} vs_out;
void main() {
    gl_Position = vec4(vs_in_pos, 1.0f);
    vs_out.pos = vs_in_pos;
    vs_out.normal = vs_in_normal;
    vs_out.texc = vs_in_texc;
This is the geometry shader code :
#version 450 core
layout (row_major) uniform;
layout (triangles) in;
layout (line_strip, max_vertices = 2) out;
in VS_OUT_GS_IN {
} gs_in[];
out GS_OUT_PS_IN {
    layout (location = 0) vec4 color;
    layout (location = 1) vec3 pos;
} gs_out;
layout (binding = 0) uniform transform_pack {
    mat4 model_view_projection;
uniform float normal_length;
uniform vec4 start_point_color;
uniform vec4 end_point_color;
void main() {
    const vec3 avg_normal = normalize(
        gs_in[0].normal + gs_in[1].normal + gs_in[2].normal);
    const vec3 triangle_centroid =
        (gs_in[0].pos + gs_in[1].pos + gs_in[2].pos) / 3.0f;
        gl_Position = model_view_projection * vec4(triangle_centroid, 1.0f);
        gs_out.color = start_point_color;
        gs_out.pos = triangle_centroid;
        EmitVertex();
        const vec3 end_pt = triangle_centroid + avg_normal * normal_length;
        gl_Position = model_view_projection * vec4(end_pt, 1.0f);
        gs_out.pos = end_pt;
        gs_out.color = end_point_color;
        EmitVertex();
    EndPrimitive();
My problem is that the line representing the face normal has the origin at one of the triangle’s vertices (not the centroid) :http://imgur.com/Y3XaGiL. So the centroid’s value is incorrect.
If I remove the layout(location) qualifiers of the members in the in/out blocks, everything works as expected. Am I doing something wrong here assigning them locations by hand ?
