ASUS Ascent GX10 / DGX Spark: Nemotron 3 Super NIM fails with NGC entitlement / org context error, not a local hardware issue
I’m posting this here because NVIDIA customer support bounced me around and sent me to a generic Linux graphics forum, but after a lot of troubleshooting (2 Days) this does not appear to be a local graphics or hardware problem.
System:
  • ASUS Ascent GX10
  • NVIDIA GB10 / Spark-class system
  • Driver: 580.126.09
  • nvidia-smi works on host
  • Docker GPU access works
  • CUDA toolkit installed: 13.2
  • nvcc --version reports 13.2
  • nvidia-smi reports CUDA 13.0
What I was trying to run:
  • nvcr.io/nim/nvidia/nemotron-3-super-120b-a12b:latest
What I verified successfully:
  • Host GPU is visible with nvidia-smi
  • Docker GPU passthrough works with:
docker run --rm --gpus all ubuntu nvidia-smi
  • Running headless with display-manager stopped does not change the core failure
  • This does not appear to be low RAM, disk-full, or a basic Docker/CUDA issue
Important note:
  • Docker on this system does not use --runtime=nvidia
  • --gpus all works correctly
The actual failure:
The NIM container starts, reads cached files, then fails when requesting the manifest/file map from NGC for:
nemotron-3-super-120b-a12b:rl-030326-fp8
Container error:
ManifestDownloadError: Error downloading manifest: HTTP status client error (400 Bad Request) for url:
https://api.ngc.nvidia.com/v2/org/nim/team/nvidia/models/nemotron-3-super-120b-a12b/rl-030326-fp8/files
I also tested the NGC API directly with my API key.
Results:
  1. Model endpoint:
returns:
403 Forbidden
Access Denied
  1. File manifest endpoint:
returns:
400 Invalid Request
Validation failed - [Org contex missing in uam request for <GET ...>, API Key does not have correct permissions (or subscriptions) to perform <GET ...>]
What seems to be going on:
This looks like an NGC entitlement / org context / UAM mapping issue, not a local GX10 problem.
My API key is valid and loaded, but I am signed up as an individual account using my business email/business name. I suspect that may be part of the issue if this model requires access through a properly entitled NGC org/team rather than just an individual login.
Questions:
  1. Has anyone else on GX10 / DGX Spark hit this exact Org context missing / permissions error with Nemotron 3 Super NIM?
  2. Does this model require a specific NGC org entitlement beyond just generating a Personal API key?
  3. Is there a known issue with the nemotron-3-super-120b-a12b:rl-030326-fp8 profile or its NGC manifest path?
  4. Has anyone successfully run this exact NIM image on GX10 / DGX Spark, and if so, what account/org setup was required?
At this point, I’ve ruled out:
  • GPU not detected
  • Docker GPU runtime failure
  • display-manager / GUI crash as the root cause
  • simple RAM exhaustion
  • simple disk exhaustion
Any help from someone who has actually gotten this NIM running on GX10 / DGX Spark would be appreciated. Just spent 8K on Nvidia Grahics cards and computers and Installing Nemotron 3 Super on a G10 Spark should be way less difficult. Thanks in advance for your time.
nvidia-bug-report.log.gz (397.5 KB)
ANYONE from NVIDIA???
Hi jeremy153,
Sorry to see you’re running into this issue. Would you be able to generate a new API key and try one more time? Please let me know what you see after that.
Thanks. I can generate a new Personal API key and retry. Before I do, can you confirm which scopes/options the key must include for nemotron-3-super-120b-a12b, and whether access requires membership in a specifically entitled NGC org/team rather than an individual account? My current key is valid, but direct API tests return 403 Access Denied and Org context missing for this model.
Hi jeremy153,
After doing more investigation, I can report to you that the Nemotron 3 Super NIM is not yet supported on the DGX Spark.
You still have options to run this model, one such being vLLM. Take a look at the community build: GitHub - eugr/spark-vllm-docker: Docker configuration for running VLLM on dual DGX Sparks · GitHub
Please give this a try and don’t hesitate to reach out here if anything comes up.
Running it on the Spark on Ollama now… Any idea when it will be officially supported for DIM?
Has something changed? A few days ago I was able to pull/start it as I posted here, but it crashed after loading the weights. This seems like a different failure to what’s reported above.
I unfortunately can’t speak to a concrete time it will be supported. Along those lines, I don’t know if anything specifically changed, just that it is not supported on Spark yet.
