ASUS Ascent GX10: Errors when connecting both sparks with an QSPF56 cable
UPDATE: Fixed. A reboot on the new node had had a firmware update and took over half an hour to come up. That probably helped the situation. Then I swapped the cable out for the official ASUS QSPF112 cable and rebooted. I was only getting 26Gbps so after some googling, I found out that a cold boot is often required to get the interfaces to initialize correctly. After a cold boot, everything came up properly and I now get 185Gbps after configuring the cluster. Hopefully this information will help someone else.
Original post:
I purchased a QSFP56 cable from Amazon and when plugging it in, one of my ASUS Ascent GX10 computers has errors in demsg. I unplugged the cable and switched ends and tried again and I’m getting the same errors only on one machine - the other one is fine, with no errors. Could this be a bad cable or a bad port? Is it something that is serious? (I haven’t configured anything, just plugged the cables in at this point).
I first used the port next to the ethernet port (I think that’s port 0) then switched to the other port. I turned the cable around and plugged it in. No matter how the cable is plugged in, I’m getting the same errors on the same machine, so the errors do not follow the end of the cable that is plugged in or the port. They always happen on the same machine.
Errors:
[ 1388.169908] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1388.169937] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1388.169952] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1388.169954] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1390.510328] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1390.510343] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1390.510351] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1390.510353] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1426.793809] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1426.793836] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1426.793849] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1426.793852] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1441.051076] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1441.051102] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1441.051104] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1441.051106] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1446.468904] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1446.468932] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1446.468934] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1446.468936] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1449.231786] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1449.231815] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1449.231829] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1449.231831] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1449.940477] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1449.940501] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1449.940503] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1449.940505] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
[ 1482.638663] pcieport 0004:00:00.0: AER: Correctable error message received from 0004:00:00.0
[ 1482.638691] pcieport 0004:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[ 1482.638704] pcieport 0004:00:00.0:   device [10de:22ce] error status/mask=00000001/0000e000
[ 1482.638707] pcieport 0004:00:00.0:    [ 0] RxErr                  (First)
@Mecworks there’s another post tracking similar issue on the ASUS GX10. See details at AER Storm on GX10 - #10 by leafy-inn.0z
