Async thread in Nvidia thread
Getting this error
HandlePictureDisplay : cuvidMapVideoFrame(m_hDecoder, pDispInfo->picture_index, &dpSrcFrame, &nSrcPitch, &videoProcessingParameters) returned error 700 at …/…/NvCodec/NvDecoder/NvDecoder.cpp:505
when executing the code
extern “C” {
#include <libavformat/avformat.h>
#include <libavformat/avio.h>
#include <libavcodec/avcodec.h>
#include <cuda.h>
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <cudaProfiler.h>
#include <stdio.h>
#include
#include
#include
#include
#include
#include <string.h>
#include
#include
#include “NvDecoder/NvDecoder.h”
#include “…/Utils/NvCodecUtils.h”
#include “…/Utils/FFmpegDemuxer.h”
#include “…/Utils/ColorSpace.h”
#define N 2
std::vector<FFmpegDemuxer*> vDemuxer2;
#define NUMBER 5
class demuxing{
public:
FFmpegDemuxer *demuxer;
uint8_t * pVideo=NULL;
int nVideoBytes;
std::string s;
   void setvalue(std::string line){
char a[255];
    s=line;
    strcpy(a,line.c_str());
demuxer=new FFmpegDemuxer(a);
  void resetFuture()
demuxing demuxers[2];
simplelogger::Logger *logger = simplelogger::LoggerFactory::CreateConsoleLogger();
/* enum is to select the desired format(In our case bgra is used) */
enum OutputFormat
native = 0, bgrp, rgbp, bgra, rgba, bgra64, rgba64
int anSize = { 0, 3, 3, 4, 4, 8, 8 };
CUdeviceptr pTmpImage = 0;
OutputFormat eOutputFormat = bgra;
class Camera{
private:
std::string name;
std::string id;
int Width;
int Height;
std::string timestamp;
public:
std::string get_name(void){
return name;
std::string get_id(){
return id;
std::string get_timestamp(){
return timestamp;
/* This function below is used to get the image from the memory*/
void GetImage(CUdeviceptr dpSrc, uint8_t *pDst, int nWidth, int nHeight)
CUDA_MEMCPY2D m = { 0 };
m.WidthInBytes = nWidth;
m.Height = nHeight;
m.srcMemoryType = CU_MEMORYTYPE_DEVICE;
m.srcDevice = (CUdeviceptr)dpSrc;
m.srcPitch = m.WidthInBytes;
m.dstMemoryType = CU_MEMORYTYPE_HOST;
m.dstDevice = (CUdeviceptr)(m.dstHost = pDst);
m.dstPitch = m.WidthInBytes;
cuMemcpy2D(&m);
void DecProc(NvDecoder *pDec)
 int nHeight=demuxers[0].demuxer->GetHeight();
   int nWidth=demuxers[0].demuxer->GetWidth();
  int nFrameSize=nWidth*nHeight*anSize[eOutputFormat];
   cuMemAlloc(&pTmpImage, nWidth * nHeight * anSize[eOutputFormat]);
try
      int nFrameReturned = 0, nFrame = 0;
      uint8_t  **ppFrame = NULL;
     uint8_t *pImage= new uint8_t[nFrameSize];
       int frames=0;
  do{
    std::vector<std::future<bool>> fut(2);
    	fut[0] =std::async(&FFmpegDemuxer::Demux,&(*(demuxers[0].demuxer)),&(demuxers[0].pVideo),&(demuxers[0].nVideoBytes));
             	    	fut[1] =std::async(&FFmpegDemuxer::Demux,&(*(demuxers[1].demuxer)),&(demuxers[1].pVideo),&(demuxers[1].nVideoBytes));
       	    int loop=0;
  for(auto &e:fut)
     { e.get();
            pDec->Decode(demuxers[loop].pVideo, demuxers[loop].nVideoBytes, &ppFrame, &nFrameReturned);
            if (!nFrame && nFrameReturned)
         	LOG(INFO) << pDec->GetVideoInfo();
	    for (int i = 0; i < nFrameReturned; i++)
            	Nv12ToColor32<BGRA32>((uint8_t *)ppFrame[i], pDec->GetWidth(), (uint8_t*)pTmpImage, 4 * pDec->GetWidth(), pDec->GetWidth(), pDec->GetHeight());
            	GetImage(pTmpImage, reinterpret_cast<uint8_t*>(pImage), 4 * pDec->GetWidth(), pDec->GetHeight());
        	     cv::Mat image(nHeight,nWidth , CV_8UC4, reinterpret_cast<char*>(pImage));
		cv::imshow("image",image);
		cv::waitKey(30);
		cv::imwrite("image"+std::to_string(frames)+".jpg",image);
                              frames++;
	loop++;
            nFrame += nFrameReturned;
       std::cout<<"Hi";
}while(1);
catch (std::exception& ex)
    std::cout<<ex.what();
struct NvDecPerfData
uint8_t *pBuf;
std::vector<uint8_t *> *pvpPacketData;
std::vector *pvpPacketDataSize;
int CUDAAPI HandleVideoData(void *pUserData, CUVIDSOURCEDATAPACKET *pPacket) {
NvDecPerfData *p = (NvDecPerfData *)pUserData;
memcpy(p->pBuf, pPacket->payload, pPacket->payload_size);
p->pvpPacketData->push_back(p->pBuf);
p->pvpPacketDataSize->push_back(pPacket->payload_size);
p->pBuf += pPacket->payload_size;
return 1;
int main(int argc, char **argv)
char szInFilePath[255];
int iGpu = 0;
int nThread = 1;
bool bSingle = false;
bool bHost = false;
std::vectorstd::exception_ptr vExceptionPtrs;
try
    ck(cuInit(0));
    int nGpu = 0;
    ck(cuDeviceGetCount(&nGpu));
    if (iGpu < 0 || iGpu >= nGpu) {
        std::cout << "GPU ordinal out of range. Should be within [" << 0 << ", " << nGpu - 1 << "]" << std::endl;
        return 1;
    CUdevice cuDevice = 0;
    ck(cuDeviceGet(&cuDevice, iGpu));
    char szDeviceName[80];
    ck(cuDeviceGetName(szDeviceName, sizeof(szDeviceName), cuDevice));
    std::cout << "GPU in use: " << szDeviceName << std::endl;
CUcontext cuContext = NULL;
    ck(cuCtxCreate(&cuContext, 0, cuDevice));
    std::ifstream file(argv[1]);
std::string line;
    int i=0;
   while(std::getline(file,line)){
 	demuxers[i].setvalue(line);
	i++;
            if(demuxer.GetHeight()==720 && demuxer.GetHeight()==1280 && demuxer.GetVideoCodec()==AV_CODEC_ID_H)
                       vDemuxer1.push_back(demuxer);
	else if(demuxer.GetHeight()==720 && demuxer.GetHeight()==1280 && demuxer.GetVideoCodec()==AV_CODEC_ID_HEVC)
		 vDemuxer3.push_back(demuxer);
	else if(demuxer.GetHeight()==1080 && demuxer.GetHeight()==1920 && demuxer.GetVideoCodec()==AV_CODEC_ID_H264)
             	 vDemuxer2.push_back(demuxer);
	else if(demuxer.GetHeight()==1080 && demuxer.GetHeight()==1920 && demuxer.GetVideoCodec()==AV_CODEC_ID_HEVC)
		 vDemuxer4.push_back(demuxer);
	else
		 vDemuxer5.push_back(demuxer);            */
// NvDecoder dec1(new NvDecoder(cuContext, 1280, 720, true, FFmpeg2NvCodecId(AV_CODEC_ID_H264)));
std::unique_ptr dec2(new NvDecoder(cuContext, 1920, 1080, true, (cudaVideoCodec)cudaVideoCodec_H264));
// NvDecoder dec3(new NvDecoder(cuContext, 1280, 720, true, FFmpeg2NvCodecId(AV_CODEC_ID_HEVC)));
// NvDecoder dec4(new NvDecoder(cuContext, 1920, 1080, true, FFmpeg2NvCodecId(AV_CODEC_ID_HEVC)));
   std::vector<NvThread> gpuThread;
// gpuThread.push_back(NvThread(std::thread(DecProc, dec1, &vDemuxer1) ));
gpuThread.push_back(NvThread(std::thread(DecProc,dec2.get())));
// gpuThread.push_back(NvThread(std::thread(DecProc, dec3, &vDemuxer3) ));
// gpuThread.push_back(NvThread(std::thread(DecProc, dec4, &vDemuxer4) ));
// gpuThread1.join();
//gpuThread[0].join();
// gpuThread3.join();
// gpuThread4.join();
catch (const std::exception& ex)
    std::cout << ex.what();
    exit(1);
return 0;
Please help!!!
