Hi, below I have two similar simple codes. I would say that both should have the same behavior but maybe I’m missing something. The thing is that the former code builds and runs and the latter builds but gives an error. I wonder what the difference is.
program works
use iso_fortran_env, only : REAL64
implicit none
integer, parameter :: dp = REAL64
integer, parameter :: nx = 100
real(dp) :: accum = 0.0
character(len=nx) :: temp = 'F'
integer :: j
!$omp target map(tofrom:accum) map(to:temp)
do j = 1, nx
if(temp(j:j) == 'F') then
accum = accum + 1
end if
end do
!$omp end target
end program
program fails
implicit none
integer :: j
!$omp target enter data map(to:temp)
do j = 1, nx
accum = accum + 1
end if
end do
!$omp end target
!$omp target exit data map(delete:temp)
end program
My compiler is nvfortran 22.7, and the error output is:
Fatal error: Registered function 'nvkernel_MAIN__F1L13_2_' not found in the CUBIN, error 1
Aborted
