At the same time, when previewing 8 cameras, the system would freeze and then restart
Jetson Module: ORIN NX 8GB
L4T Version: R35.6.4
Board : Self-developed carrier board
We connected the MAX96712 to the CSI. When using a single preview camera, all 8 cameras could be previewed normally, and there was no lag on the system desktop. The system could also function normally.
Open and preview the video stream of the camera one by one. When opening up to the fifth one, the system begins to experience lag. After opening up to the eighth one, it will immediately freeze and then automatically restart the system after a period of time.
The command for previewing the video stream is as follows:
nvidia@tegra-ubuntu:~$ cat open_camera_1080.sh
#!/bin/bash
case $1 in
        0)
                gst-launch-1.0 -v v4l2src device="/dev/video0" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        1)
                gst-launch-1.0 -v v4l2src device="/dev/video1" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        2)
                gst-launch-1.0 -v v4l2src device="/dev/video2" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        3)
                gst-launch-1.0 -v v4l2src device="/dev/video3" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        4)
                gst-launch-1.0 -v v4l2src device="/dev/video4" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        5)
                gst-launch-1.0 -v v4l2src device="/dev/video5" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        6)
                gst-launch-1.0 -v v4l2src device="/dev/video6" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
        7)
                gst-launch-1.0 -v v4l2src device="/dev/video7" ! video/x-raw,framerate=30/1,width=1920,height=1080 ! xvimagesink
esac
The formats supported by each camera are all the same.
nvidia@tegra-ubuntu:~$ v4l2-ctl -d /dev/video3 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'UYVY' (UYVY 4:2:2)
                Size: Discrete 3840x2160
                        Interval: Discrete 0.033s (30.000 fps)
                        Interval: Discrete 0.020s (50.000 fps)
                        Interval: Discrete 0.017s (60.000 fps)
                Size: Discrete 1920x1536
                Size: Discrete 1920x1300
                Size: Discrete 1920x1080
                Size: Discrete 2592x1800
                Size: Discrete 2880x1860
        [1]: 'NV16' (Y/CbCr 4:2:2)
        [2]: 'UYVY' (UYVY 4:2:2)
All the equipment information is as follows:
nvidia@tegra-ubuntu:~$ v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
        /dev/media0
vi-output, camera_sensor 9-001b (platform:tegra-capture-vi:0):
        /dev/video0
        /dev/video1
        /dev/video2
        /dev/video3
vi-output, camera_sensor 10-002 (platform:tegra-capture-vi:2):
        /dev/video4
        /dev/video5
        /dev/video6
        /dev/video7
The complete device tree file is as follows:
tegra234-camera-max96712.zip (4.5 KB)
Below is the complete dmesg log when previewing 8 cameras simultaneously:
dmesg.log (2.4 MB)
The part of the log that I have selected before the crash is as follows:
[  372.625560] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  372.625717] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  375.263851] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.263854] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.263856] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.263861] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.263865] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.263867] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.263868] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.263871] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.263873] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.263877] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263878] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263880] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  375.263882] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263884] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263886] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  375.263887] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263890] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  375.263892] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  375.263893] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263895] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[  375.263896] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263898] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.263900] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[  375.264009] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.264016] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.264022] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.264023] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  375.264025] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.265764] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  375.265771] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.265775] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.265776] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  375.265778] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.273957] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  375.273977] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  375.273986] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  375.274000] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  375.274192] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  375.275277] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  375.275375] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  375.283918] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  375.293716] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  375.303641] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.303645] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  375.313600] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  375.315861] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 33 cannot set channel match configuration"
[  375.315864] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  375.315865] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 31 cannot set channel match configuration"
[  375.315866] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  375.315867] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 32 cannot set channel match configuration"
[  375.315868] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  375.315869] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 35 cannot set channel match configuration"
[  375.315870] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  375.315871] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 35 cannot set channel match configuration"
[  375.315872] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  375.315872] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 31 cannot set channel match configuration"
[  375.315873] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  375.323540] (NULL device *): vi_capture_control_message: NULL VI channel received
[  375.323545] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 2
[  375.325713] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  377.819867] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  377.819894] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  377.819900] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  377.819910] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  377.819921] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.819924] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  377.819928] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.819930] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[  377.820000] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  377.820010] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  377.820019] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.820022] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  377.820024] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.820027] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 3
[  377.820184] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  377.820191] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  377.820196] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.820197] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  377.820199] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.820201] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 2
[  377.820216] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  377.820223] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  377.820227] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.820229] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  377.820231] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.820233] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 3
[  377.829021] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  377.829029] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.829032] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  377.829034] (NULL device *): vi_capture_control_message: NULL VI channel received
[  377.829036] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[  378.079823] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  378.087946] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.095613] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  378.106179] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.106182] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.106201] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  378.106217] (NULL device *): vi_capture_control_message: NULL VI channel received
[  378.106251] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  378.106253] (NULL device *): vi_capture_control_message: NULL VI channel received
[  378.106255] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[  378.106702] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.107731] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.109691] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.115260] (NULL device *): vi_capture_control_message: NULL VI channel received
[  378.235614] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  378.246287] (NULL device *): vi_capture_control_message: NULL VI channel received
[  378.253989] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[  378.264845] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  378.591848] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  378.601021] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  378.610652] (NULL device *): vi_capture_control_message: NULL VI channel received
[  378.618452] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  378.629271] (NULL device *): vi_capture_control_message: NULL VI channel received
[  378.637086] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 2
[  378.648042] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.635817] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.635822] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.635827] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.635841] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.635844] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.635846] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.635857] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.635859] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.635863] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  380.635867] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  380.635869] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.635870] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.635873] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[  380.635876] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[  380.636786] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.636788] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.639813] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.639819] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.639822] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.639829] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.639832] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.639836] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  380.639838] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.639841] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.639844] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  380.639847] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 2
[  380.639849] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.641304] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.641350] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.645109] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.654232] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.663281] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.663288] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  380.663292] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.674121] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.682073] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[  380.691649] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  380.699614] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.707088] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.707092] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 3
[  380.895801] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  380.903432] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  380.912654] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  380.912662] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.912667] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  380.912669] (NULL device *): vi_capture_control_message: NULL VI channel received
[  380.912982] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  381.403796] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  381.412939] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  381.422545] (NULL device *): vi_capture_control_message: NULL VI channel received
[  381.430279] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  381.440945] (NULL device *): vi_capture_control_message: NULL VI channel received
[  382.459795] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[  382.468129] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_control_send_message: failed to send IVC control message
[  382.479716] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.195792] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.195809] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.195814] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.195830] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.195832] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.195841] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.195845] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.195849] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  383.195851] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.195853] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.195856] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  383.195858] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 3
[  383.195860] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.195863] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[  383.196420] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.196449] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.204954] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.204968] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.214128] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.214142] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.223307] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  383.232422] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  383.232428] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.232431] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[  383.235362] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.242101] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.259793] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 30 cannot set channel match configuration"
[  383.270088] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 2
[  383.277801] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  383.446139] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.451801] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.455727] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.464785] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.474040] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.483492] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.483501] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  383.493081] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.493084] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  383.500802] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.511449] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.511452] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[  383.511881] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.519600] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  383.574789] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 35 cannot set channel match configuration"
[  383.574791] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  383.707803] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  383.716943] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  383.726543] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.734497] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  383.745178] (NULL device *): vi_capture_control_message: NULL VI channel received
[  383.752889] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[  383.763701] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  385.243784] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  385.252929] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  385.262526] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.270259] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  385.280960] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.289061] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 2
[  385.299853] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  385.755773] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  385.755779] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  385.755795] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  385.755803] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  385.755819] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.755824] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  385.755828] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.755833] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[  385.765001] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  385.765005] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  385.765016] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.765021] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  385.765025] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.765030] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 3
[  385.765337] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  385.774049] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  385.774055] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.774058] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  385.774060] (NULL device *): vi_capture_control_message: NULL VI channel received
[  385.775218] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  385.939629] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 32 cannot set channel match configuration"
[  385.939632] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  386.011833] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  386.020994] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  386.030583] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.038322] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  386.048989] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.267756] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  386.267783] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  386.276901] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  386.286063] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  386.295661] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.305204] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.305210] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  386.312926] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  386.320622] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.320625] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 3
[  386.323550] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  386.331284] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.331287] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[  386.331608] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  386.523748] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  386.532891] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  386.542471] (NULL device *): vi_capture_control_message: NULL VI channel received
[  386.550182] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  386.560843] (NULL device *): vi_capture_control_message: NULL VI channel received
[  387.067751] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[  387.076090] tegra194-vi5 13e40000.host1x:vi1@14c00000: vi_capture_control_send_message: failed to send IVC control message
[  387.087972] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  387.579738] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[  387.588072] tegra194-vi5 13e40000.host1x:vi1@14c00000: vi_capture_control_send_message: failed to send IVC control message
[  387.599720] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  388.059774] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  388.068936] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  388.078537] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.086265] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  388.096962] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.104744] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 2
[  388.115516] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  388.315757] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  388.315762] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  388.315773] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  388.324948] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  388.324969] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.334219] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.343771] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  388.353462] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  388.361122] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.361129] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 3
[  388.368953] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.380618] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  388.390217] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 1
[  388.436392] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  388.571762] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  388.580958] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  388.590539] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.598269] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  388.608932] (NULL device *): vi_capture_control_message: NULL VI channel received
[  388.616646] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[  388.627494] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  389.083754] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  389.083762] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  389.083777] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  389.092910] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  389.102050] (NULL device *): vi_capture_control_message: NULL VI channel received
[  389.102055] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  389.102060] (NULL device *): vi_capture_control_message: NULL VI channel received
[  389.111663] (NULL device *): vi_capture_control_message: NULL VI channel received
[  389.121223] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 3
[  389.165583] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[  389.165662] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  389.175724] [RCE] ERROR: camera-ip/vi5/vi5.c:3893 [vi5_update_channel_match_data] "match configuration is already in use by by channel 34 cannot set channel match configuration"
[  389.175726] [RCE] ERROR: services/capture/capture-scheduler.c:3024 [capture_scheduler_thread] "Error processing event 0x100003"
[  389.176258] (NULL device *): vi_capture_control_message: NULL VI channel received
[  389.193558] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 1
[  389.204730] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[  389.851743] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  389.860880] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  389.870609] (NULL device *): vi_capture_control_message: NULL VI channel received
[  389.878423] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  389.889191] (NULL device *): vi_capture_control_message: NULL VI channel received
[  390.298008] usb 1-1: USB disconnect, device number 3
[  390.298013] usb 1-1.3: USB disconnect, device number 4
[  390.363714] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  390.372860] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  390.382455] (NULL device *): vi_capture_control_message: NULL VI channel received
[  390.390190] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[  390.400857] (NULL device *): vi_capture_control_message: NULL VI channel received
[  390.455756] usb 2-2: USB disconnect, device number 2
[  390.854144] tegra-xusb 3610000.xhci: entering ELPG done
[  390.875720] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  390.884875] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  390.894457] (NULL device *): vi_capture_control_message: NULL VI channel received
I’m not particularly proficient in camera calibration, so I hope to get your assistance.
hello chen.xi,
please give it a try to use V4L2 IOCTL to verify basic functionality
see-also Applications Using V4L2 IOCTL Directly by launching all 8-cam together via v4l2 standard IOCTL.
I attempted to use the following command to access the camera simultaneously. When it reached the sixth step, the system immediately crashed and automatically restarted within about one minute.
 v4l2-ctl --stream-mmap  -d /dev/video0 --verbose
 v4l2-ctl --stream-mmap  -d /dev/video1 --verbose
 v4l2-ctl --stream-mmap  -d /dev/video2 --verbose
 v4l2-ctl --stream-mmap  -d /dev/video4 --verbose
 v4l2-ctl --stream-mmap  -d /dev/video5 --verbose
 v4l2-ctl --stream-mmap  -d /dev/video6 --verbose
Thanks for the detailed logs and device tree configuration. The error signatures point to VI channel resource exhaustion or misconfiguration when scaling to 8 cameras. To narrow down the root cause, we need a few more diagnostics:
  1. Kernel version: Please confirm the exact kernel version (e.g., uname -r) running on your system with L4T R35.6.4.
  2. Device tree validation: Run dtc -I dts -O dtb tegra234-camera-max96712.dts -o /tmp/test.dtb and share any compiler warnings or errors.
  3. Incremental camera test: Can you successfully stream 4 cameras simultaneously? At what camera count does the VI channel allocation fail? This will help us isolate whether the issue is at 5, 6, 7, or 8 cameras.
  4. CSI lane configuration: Verify in your device tree that all 4 CSI lanes are properly configured for both VI instances (vi0 and vi2). Check that the lane assignments don’t conflict.
  5. RCE firmware logs: If available, share any debug output from the camera RCE processor (MAX96712 firmware logs) during the freeze/reboot sequence.
Once we have these details, we can determine whether this is a device tree mapping issue, VI channel scheduler problem, or firmware-level resource conflict.
Thank you for the detailed diagnostics and logs. The timeout errors and CSI stream errors in your dmesg suggest a resource or bandwidth bottleneck when scaling to 8 cameras. To help narrow down the root cause, I need a few more data points:
  1. Kernel logs during freeze: Please capture the last 100 lines of dmesg output from the moment you start the 8th camera until the system restarts. This will show us the exact sequence of failures.
  2. Resource usage at different camera counts: Run free -h and top -b -n 1 while previewing 1, 4, and 8 cameras separately. This will help us determine if memory or CPU is the limiting factor.
  3. Resolution and framerate variation: Test whether the system freezes at lower resolutions (1280x720) or framerates (15 fps) with all 8 cameras. This will tell us if it’s a bandwidth issue.
  4. Single-camera stress test: Try running a single camera at the highest supported resolution (3840x2160) to see if that alone causes a freeze.
These tests will help us determine whether the issue is CSI bandwidth saturation, memory exhaustion, CPU overload, or a device tree configuration problem.
About compiler DTS
mkdir workspace && cd workspace
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v6.4/sources/public_sources.tbz2
tar -xf public_sources.tbz2
mv Linux_for_Tegra/source/public/kernel_src.tbz2 .
rm Linux_for_Tegra -r
tar -xf kernel_src.tbz2
mv tegra234-camera-max96712.dts hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/
Then modify tegra234-p3768-0000-a0.dtsi
plink@plink-Vostro-3681:~/kernel/source/35.6.4/lightWheel/y-c27/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb$ diff -up tegra234-p3768-0000-a0.dtsi tegra234-p3768-0000-a0-c27.dtsi
--- tegra234-p3768-0000-a0.dtsi 2026-01-27 15:25:30.000000000 +0800
+++ tegra234-p3768-0000-a0-c27.dtsi     2026-07-09 10:38:45.606221697 +0800
@@ -16,8 +16,10 @@
 #include "tegra234-p3768-0000-a0-pcie.dtsi"
 #include "tegra234-p3768-0000-a0-fixed-regulator.dtsi"
 #include "tegra234-p3768-audio.dtsi"
-#include "tegra234-p3768-camera-rbpcv3-imx477.dtsi"
-#include "tegra234-p3768-camera-rbpcv2-imx219.dtsi"
+//#include "tegra234-p3768-camera-rbpcv3-imx477.dtsi"
+//#include "tegra234-p3768-camera-rbpcv2-imx219.dtsi"
+//#include "tegra234-camera-max96712-3564-c27.dtsi"
+#include "tegra234-camera-max96712.dtsi"
        gpio-keys {
@@ -264,7 +266,7 @@
        display@13800000 {
                status = "okay";
        tegra-capture-vi  {
                ports {
                        port@0 {
@@ -340,4 +342,5 @@
Finally, the compilation is carried out.
plink@plink-Vostro-3681:~/kernel/source/35.6.4/lightWheel/y-c27$ cat setting
export LOCALVERSION=-tegra
export CROSS_COMPILE=/home/plink/kernel/nvtools/3564/bootlin-toolchain-gcc-93/bin/aarch64-buildroot-linux-gnu-
export TEGRA_KERNEL_OUT=$PWD/../../kout/
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
make dtbs ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
About kernel version:
nvidia@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 5.10.216-tegra #8 SMP PREEMPT Thu Jul 9 14:39:07 CST 2026 aarch64 aarch64 aarch64 GNU/Linux
nvidia@tegra-ubuntu:~$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 6.4, GCID: 43803471, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan 27 08:01:21 UTC 2026
I just checked it again, and it seems to occur randomly. However, based on the test results for today, the probability of its occurrence is quite high. Moreover, after each restart, the camera must be powered off and unplugged before it can be accessed normally.
Without any error messages, the phenomenon is as follows. There will be a significant delay.
The device tree configuration is as follows:
	tegra-capture-vi  {
		num-channels = <8>;
		status = "okay";
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			port@0 {
				reg = <0>;
				status = "okay";
				max96712_a_vi_in0: endpoint {
					status = "okay";
					vc-id = <0>;
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&max96712_a_csi_out0>;
			port@1 {
				reg = <1>;
				status = "okay";
				max96712_a_vi_in1: endpoint {
					status = "okay";
					vc-id = <1>;
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&max96712_a_csi_out1>;
			port@2 {
				reg = <2>;
				status = "okay";
				max96712_a_vi_in2: endpoint {
					status = "okay";
					vc-id = <2>;
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&max96712_a_csi_out2>;
			port@3 {
				reg = <3>;
				status = "okay";
				max96712_a_vi_in3: endpoint {
					status = "okay";
					vc-id = <3>;
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&max96712_a_csi_out3>;
			port@4 {
				reg = <4>;
				status = "okay";
				max96712_b_vi_in0: endpoint {
					status = "okay";
					vc-id = <0>;
					port-index = <2>;
					bus-width = <4>;
					remote-endpoint = <&max96712_b_csi_out0>;
			port@5 {
				reg = <5>;
				status = "okay";
				max96712_b_vi_in1: endpoint {
					status = "okay";
					vc-id = <1>;
					port-index = <2>;
					bus-width = <4>;
					remote-endpoint = <&max96712_b_csi_out1>;
			port@6 {
				reg = <6>;
				status = "okay";
				max96712_b_vi_in2: endpoint {
					status = "okay";
					vc-id = <2>;
					port-index = <2>;
					bus-width = <4>;
					remote-endpoint = <&max96712_b_csi_out2>;
			port@7 {
				reg = <7>;
				status = "okay";
				max96712_b_vi_in3: endpoint {
					status = "okay";
					vc-id = <3>;
					port-index = <2>;
					bus-width = <4>;
					remote-endpoint = <&max96712_b_csi_out3>;
	host1x@13e00000 {
		nvcsi@15a00000 {
			status = "okay";
			num-channels = <8>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_a_csi_in0: endpoint@0 {
							status = "okay";
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&max96712_a_out0>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_a_csi_out0: endpoint@1 {
							status = "okay";
							remote-endpoint = <&max96712_a_vi_in0>;
			channel@1 {
				reg = <1>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_a_csi_in1: endpoint@2 {
							status = "okay";
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&max96712_a_out1>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_a_csi_out1: endpoint@3 {
							status = "okay";
							remote-endpoint = <&max96712_a_vi_in1>;
			channel@2 {
				reg = <2>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_a_csi_in2: endpoint@3 {
							status = "okay";
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&max96712_a_out2>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_a_csi_out2: endpoint@4 {
							status = "okay";
							remote-endpoint = <&max96712_a_vi_in2>;
			channel@3 {
				reg = <3>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_a_csi_in3: endpoint@5 {
							status = "okay";
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&max96712_a_out3>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_a_csi_out3: endpoint@6 {
							status = "okay";
							remote-endpoint = <&max96712_a_vi_in3>;
			channel@4 {
				reg = <4>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_b_csi_in0: endpoint@7 {
							status = "okay";
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&max96712_b_out0>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_b_csi_out0: endpoint@8 {
							status = "okay";
							remote-endpoint = <&max96712_b_vi_in0>;
			channel@5 {
				reg = <5>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_b_csi_in1: endpoint@9 {
							status = "okay";
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&max96712_b_out1>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_b_csi_out1: endpoint@10 {
							status = "okay";
							remote-endpoint = <&max96712_b_vi_in1>;
			channel@6 {
				reg = <6>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_b_csi_in2: endpoint@11 {
							status = "okay";
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&max96712_b_out2>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_b_csi_out2: endpoint@12 {
							status = "okay";
							remote-endpoint = <&max96712_b_vi_in2>;
			channel@7 {
				reg = <7>;
				status = "okay";
				ports {
					#size-cells = <0>;
					status = "okay";
					port@0 {
						reg = <0>;
						status = "okay";
						max96712_b_csi_in3: endpoint@13 {
							status = "okay";
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&max96712_b_out3>;
					port@1 {
						reg = <1>;
						status = "okay";
						max96712_b_csi_out3: endpoint@14 {
							status = "okay";
							remote-endpoint = <&max96712_b_vi_in3>;
I don’t know how to obtain this. I’m not a professional in camera driver development.I don’t know how to obtain this. I’m not a professional in camera driver development.
Later, I will export the log. I found the following information in the remote terminal via SSH:
Message from syslogd@tegra-ubuntu at Jul 21 09:07:54 ...
 kernel:[  947.737631] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
Message from syslogd@tegra-ubuntu at Jul 21 09:07:55 ...
 kernel:[  948.370881] Code: f9403261 b5000061 f9416a61 b4000061 (f9400023)
To check the syslog logs using VIM, do the following:
As shown in the following log, I have omitted the repetitive parts.
Jul 21 08:53:42 tegra-ubuntu kernel: [   95.313173] irq: IRQ307: trimming hierarchy from :pmc@c360000
Jul 21 08:53:42 tegra-ubuntu kernel: [   95.314819] irq: IRQ308: trimming hierarchy from :pmc@c360000
Jul 21 08:53:42 tegra-ubuntu PackageKit: get-details transaction /140_ceecedde from uid 1000 finished with success after 570ms
Jul 21 08:53:45 tegra-ubuntu snapd[2856]: daemon.go:548: gracefully waiting for running hooks
Jul 21 08:53:45 tegra-ubuntu snapd[2856]: daemon.go:550: done waiting for running hooks
Jul 21 08:53:48 tegra-ubuntu snapd[2856]: overlord.go:518: Released state lock file
Jul 21 08:53:48 tegra-ubuntu snapd[2856]: daemon stop requested to wait for socket activation
Jul 21 08:53:48 tegra-ubuntu systemd[1]: snapd.service: Succeeded.
Jul 21 08:54:00 tegra-ubuntu systemd[1]: systemd-timedated.service: Succeeded.
Jul 21 08:55:32 tegra-ubuntu kernel: [  205.718890] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:55:35 tegra-ubuntu kernel: [  208.296360] bwmgr API not supported   # open video0
Jul 21 08:55:35 tegra-ubuntu kernel: [  208.305485] camera_sensor 9-001b: mode id= 3
Jul 21 08:55:35 tegra-ubuntu kernel: [  208.349990] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:41 tegra-ubuntu kernel: [  214.150018] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:41 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:55:41 tegra-ubuntu kernel: [  214.183196] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:41 tegra-ubuntu kernel: [  214.416523] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:41 tegra-ubuntu systemd[1434]: Started VTE child process 3667 launched by gnome-terminal-server process 2815.
Jul 21 08:55:41 tegra-ubuntu kernel: [  214.449859] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:41 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3658.scope: Succeeded.
Jul 21 08:55:41 tegra-ubuntu kernel: [  214.483177] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:43 tegra-ubuntu kernel: [  216.249834] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:43 tegra-ubuntu kernel: [  216.256924] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:55:43 tegra-ubuntu kernel: [  216.283175] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:46 tegra-ubuntu kernel: [  219.116428] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:55:46 tegra-ubuntu kernel: [  219.145146] bwmgr API not supported  # open video1
Jul 21 08:55:46 tegra-ubuntu kernel: [  219.145372] camera_sensor 9-001c: mode id= 3
Jul 21 08:55:46 tegra-ubuntu kernel: [  219.149674] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:08 tegra-ubuntu kernel: [  241.017907] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:08 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:56:08 tegra-ubuntu kernel: [  241.049325] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:08 tegra-ubuntu kernel: [  241.251382] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:08 tegra-ubuntu systemd[1434]: Started VTE child process 3691 launched by gnome-terminal-server process 2815.
Jul 21 08:56:08 tegra-ubuntu kernel: [  241.282650] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:08 tegra-ubuntu kernel: [  241.288843] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:08 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3682.scope: Succeeded.
Jul 21 08:56:08 tegra-ubuntu kernel: [  241.315990] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:10 tegra-ubuntu kernel: [  242.984554] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:10 tegra-ubuntu kernel: [  242.989381] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:56:10 tegra-ubuntu kernel: [  243.015956] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:15 tegra-ubuntu kernel: [  248.317778] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:15 tegra-ubuntu kernel: [  248.331420] bwmgr API not supported  #open video2
Jul 21 08:56:15 tegra-ubuntu kernel: [  248.335823] camera_sensor 9-001d: mode id= 3
Jul 21 08:56:15 tegra-ubuntu kernel: [  248.349187] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:18 tegra-ubuntu kernel: [  251.853971] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:18 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:56:18 tegra-ubuntu kernel: [  251.882446] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:19 tegra-ubuntu kernel: [  252.153974] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:19 tegra-ubuntu systemd[1434]: Started VTE child process 3714 launched by gnome-terminal-server process 2815.
Jul 21 08:56:19 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3707.scope: Succeeded.
Jul 21 08:56:19 tegra-ubuntu kernel: [  252.182449] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:20 tegra-ubuntu kernel: [  253.920584] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:20 tegra-ubuntu kernel: [  253.932664] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:56:20 tegra-ubuntu kernel: [  253.949065] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:25 tegra-ubuntu kernel: [  258.120501] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:25 tegra-ubuntu kernel: [  258.136660] bwmgr API not supported  # open video3
Jul 21 08:56:25 tegra-ubuntu kernel: [  258.145485] camera_sensor 9-001e: mode id= 3
Jul 21 08:56:25 tegra-ubuntu kernel: [  258.148970] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:29 tegra-ubuntu kernel: [  261.992010] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:29 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:56:29 tegra-ubuntu kernel: [  262.015571] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:29 tegra-ubuntu kernel: [  262.322731] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:29 tegra-ubuntu systemd[1434]: Started VTE child process 3736 launched by gnome-terminal-server process 2815.
Jul 21 08:56:29 tegra-ubuntu kernel: [  262.350801] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:29 tegra-ubuntu kernel: [  262.357030] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:29 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3729.scope: Succeeded.
Jul 21 08:56:29 tegra-ubuntu kernel: [  262.382243] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:30 tegra-ubuntu kernel: [  263.789324] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:30 tegra-ubuntu kernel: [  263.811558] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:56:30 tegra-ubuntu kernel: [  263.884903] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:33 tegra-ubuntu kernel: [  266.391434] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:33 tegra-ubuntu kernel: [  266.400924] bwmgr API not supported  # open video4
Jul 21 08:56:33 tegra-ubuntu kernel: [  266.415479] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:33 tegra-ubuntu kernel: [  266.421027] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:33 tegra-ubuntu kernel: [  266.421600] camera_sensor 10-002b: mode id= 3
Jul 21 08:56:33 tegra-ubuntu kernel: [  266.422704] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:54 tegra-ubuntu kernel: [  287.062995] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:54 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:56:54 tegra-ubuntu kernel: [  287.072542] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:54 tegra-ubuntu kernel: [  287.355461] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:54 tegra-ubuntu systemd[1434]: Started VTE child process 3776 launched by gnome-terminal-server process 2815.
Jul 21 08:56:54 tegra-ubuntu kernel: [  287.374084] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:54 tegra-ubuntu kernel: [  287.388795] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:54 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3767.scope: Succeeded.
Jul 21 08:56:54 tegra-ubuntu kernel: [  287.635077] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:56 tegra-ubuntu kernel: [  289.311642] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:56 tegra-ubuntu kernel: [  289.312510] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:56:56 tegra-ubuntu kernel: [  289.323171] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:59 tegra-ubuntu kernel: [  292.055340] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:59 tegra-ubuntu kernel: [  292.065736] bwmgr API not supported   # open video5
Jul 21 08:56:59 tegra-ubuntu kernel: [  292.229797] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:59 tegra-ubuntu kernel: [  292.229931] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:56:59 tegra-ubuntu kernel: [  292.234046] camera_sensor 10-002c: mode id= 3
Jul 21 08:56:59 tegra-ubuntu kernel: [  292.243277] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:04 tegra-ubuntu kernel: [  296.957807] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:03 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:57:04 tegra-ubuntu kernel: [  296.967469] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:04 tegra-ubuntu kernel: [  297.528763] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:04 tegra-ubuntu systemd[1434]: Started VTE child process 3799 launched by gnome-terminal-server process 2815.
Jul 21 08:57:04 tegra-ubuntu kernel: [  297.540532] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:04 tegra-ubuntu kernel: [  297.559416] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:04 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3792.scope: Succeeded.
Jul 21 08:57:04 tegra-ubuntu kernel: [  297.573862] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:06 tegra-ubuntu kernel: [  299.288521] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:06 tegra-ubuntu kernel: [  299.297013] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:57:06 tegra-ubuntu kernel: [  299.307149] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:10 tegra-ubuntu kernel: [  303.388425] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:10 tegra-ubuntu kernel: [  303.398728] bwmgr API not supported  #open video6
Jul 21 08:57:10 tegra-ubuntu kernel: [  303.407082] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:10 tegra-ubuntu kernel: [  303.416462] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:10 tegra-ubuntu kernel: [  303.419818] camera_sensor 10-002d: mode id= 3
Jul 21 08:57:10 tegra-ubuntu kernel: [  303.421730] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:18 tegra-ubuntu kernel: [  310.992085] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:18 tegra-ubuntu systemd[1434]: Started Application launched by gsd-media-keys.
Jul 21 08:57:18 tegra-ubuntu kernel: [  311.002624] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:18 tegra-ubuntu kernel: [  311.609872] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:18 tegra-ubuntu systemd[1434]: Started VTE child process 3821 launched by gnome-terminal-server process 2815.
Jul 21 08:57:18 tegra-ubuntu kernel: [  311.614538] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:18 tegra-ubuntu kernel: [  311.633961] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:18 tegra-ubuntu systemd[1434]: gnome-launched-x-terminal-emulator-3814.scope: Succeeded.
Jul 21 08:57:18 tegra-ubuntu kernel: [  311.810952] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:21 tegra-ubuntu kernel: [  314.474811] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:21 tegra-ubuntu kernel: [  314.475536] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 08:57:21 tegra-ubuntu kernel: [  314.476470] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:28 tegra-ubuntu kernel: [  321.387960] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:28 tegra-ubuntu kernel: [  321.388254] bwmgr API not supported # open video7
Jul 21 08:57:28 tegra-ubuntu kernel: [  321.388480] camera_sensor 10-002e: mode id= 3
Jul 21 08:57:28 tegra-ubuntu kernel: [  321.407949] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:43 tegra-ubuntu kernel: [  336.278443] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:44 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:57:44 tegra-ubuntu kernel: [  336.988327] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:52 tegra-ubuntu kernel: [  345.885095] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:57:54 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: message repeated 2 times: [ (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.]
Jul 21 08:57:54 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-468ms), your system is too slow
Jul 21 08:57:54 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-481ms), your system is too slow
Jul 21 08:57:54 tegra-ubuntu kernel: [  347.422552] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:01 tegra-ubuntu kernel: [  354.413267] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:01 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-14ms), your system is too slow
Jul 21 08:58:01 tegra-ubuntu kernel: [  354.423076] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:03 tegra-ubuntu kernel: [  356.208853] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:05 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:58:05 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-1680ms), your system is too slow
Jul 21 08:58:05 tegra-ubuntu kernel: [  358.730290] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:06 tegra-ubuntu kernel: [  359.580131] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:07 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:58:07 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
Jul 21 08:58:07 tegra-ubuntu kernel: [  360.456169] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:12 tegra-ubuntu kernel: [  365.813320] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:14 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:58:14 tegra-ubuntu kernel: [  367.142375] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  397.993104] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:35 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: message repeated 2 times: [ (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.]
Jul 21 08:58:45 tegra-ubuntu PackageKit: daemon quit
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.005040] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.006221] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.007899] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.010317] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.012601] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.014127] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.017150] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.019425] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu systemd[1]: packagekit.service: Succeeded.
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.038370] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:45 tegra-ubuntu kernel: [  398.483794] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:58:46 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:58:46 tegra-ubuntu kernel: [  399.477879] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:29 tegra-ubuntu kernel: [  442.898540] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:00 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:59:29 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-499ms), your system is too slow
Jul 21 08:59:29 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-512ms), your system is too slow
Jul 21 08:59:29 tegra-ubuntu kernel: [  442.898581] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:39 tegra-ubuntu kernel: [  452.414923] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:39 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 08:59:39 tegra-ubuntu kernel: [  452.423900] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:45 tegra-ubuntu kernel: [  458.617269] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:43 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: message repeated 2 times: [ (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.]
Jul 21 08:59:45 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-331ms), your system is too slow
Jul 21 08:59:45 tegra-ubuntu kernel: [  458.617732] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:47 tegra-ubuntu kernel: [  460.808840] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 08:59:48 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-192ms), your system is too slow
Jul 21 08:59:48 tegra-ubuntu kernel: [  461.083678] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:00:26 tegra-ubuntu kernel: [  499.503243] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:00:27 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 09:00:27 tegra-ubuntu kernel: [  500.775508] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:00:50 tegra-ubuntu kernel: [  523.181314] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:00:51 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: message repeated 2 times: [ (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.]
Jul 21 09:00:51 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-183ms), your system is too slow
Jul 21 09:00:51 tegra-ubuntu kernel: [  524.769317] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:00:59 tegra-ubuntu kernel: [  532.452115] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:00:59 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.
Jul 21 09:00:59 tegra-ubuntu kernel: [  532.461952] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:01:13 tegra-ubuntu kernel: [  546.465842] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:01:13 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: message repeated 4 times: [ (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: SYN_DROPPED event - some input events have been lost.]
Jul 21 09:01:13 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
Jul 21 09:01:13 tegra-ubuntu kernel: [  546.474280] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:01:17 tegra-ubuntu kernel: [  550.745556] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:01:17 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-134ms), your system is too slow
Jul 21 09:01:17 tegra-ubuntu /usr/lib/gdm3/gdm-x-session[1702]: (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-147ms), your system is too slow
Jul 21 09:01:17 tegra-ubuntu kernel: [  550.758470] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.133867] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu systemd[1]: Started Session 5 of user nvidia.
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.164635] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.346582] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu dbus-daemon[1802]: [session uid=1000 pid=1802] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.75' (uid=1000 pid=2651 comm="/usr/libexec/tracker-miner-fs " label="kernel")
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.363810] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.364621] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.366228] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.368700] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.371704] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.375392] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:04:49 tegra-ubuntu systemd[1434]: Starting Tracker metadata database store and lookup manager...
Jul 21 09:04:49 tegra-ubuntu dbus-daemon[1802]: [session uid=1000 pid=1802] Successfully activated service 'org.freedesktop.Tracker1'
Jul 21 09:04:49 tegra-ubuntu systemd[1434]: Started Tracker metadata database store and lookup manager.
Jul 21 09:04:49 tegra-ubuntu kernel: [  762.538452] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:05:19 tegra-ubuntu kernel: [  792.334289] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:05:20 tegra-ubuntu tracker-store[3924]: OK
Jul 21 09:05:20 tegra-ubuntu systemd[1434]: tracker-store.service: Succeeded.
Jul 21 09:05:20 tegra-ubuntu kernel: [  793.220205] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:05:56 tegra-ubuntu kernel: [  829.836260] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:05:57 tegra-ubuntu systemd-resolved[335]: Grace period over, resuming full feature set (UDP+EDNS0) for DNS server 192.168.10.1.
Jul 21 09:05:57 tegra-ubuntu kernel: [  830.759466] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:27 tegra-ubuntu kernel: [  920.537568] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:27 tegra-ubuntu systemd[1]: Starting Cleanup of Temporary Directories...
Jul 21 09:07:27 tegra-ubuntu systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Jul 21 09:07:27 tegra-ubuntu systemd[1]: Finished Cleanup of Temporary Directories.
Jul 21 09:07:28 tegra-ubuntu kernel: [  921.559628] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:37 tegra-ubuntu kernel: [  930.270666] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869836] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869854] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869861] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869864] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869872] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869874] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869877] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869879] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869885] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869890] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869895] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869897] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869899] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869903] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869905] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.869906] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872069] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872071] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872073] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872075] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872077] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872079] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872081] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872082] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872085] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.872087] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.873721] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.873724] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.873728] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.873729] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.873731] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879291] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879388] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879390] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879527] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879530] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879533] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879542] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.879547] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.889056] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.933971] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.934068] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.937268] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.938258] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.938262] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.967306] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.967399] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.967845] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 09:07:39 tegra-ubuntu kernel: [  932.970598] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:40 tegra-ubuntu kernel: [  933.000673] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:40 tegra-ubuntu kernel: [  933.000761] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:40 tegra-ubuntu kernel: [  933.003930] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:40 tegra-ubuntu kernel: [  933.008031] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Jul 21 09:07:40 tegra-ubuntu kernel: [  933.033984] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
Jul 21 09:07:42 tegra-ubuntu kernel: [  935.150265] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
The complete syslog file:
syslog.zip (13.9 MB)
open-1-camera.txt (24.9 KB)
open-4-camera.txt (25.7 KB)
open-5-camera.txt (24.5 KB)
open-6-camera.txt (24.9 KB)
open-7-camera.txt (25.2 KB)
open-8-camera.txt (55.4 KB)
It is similar to the situation with 1920x1080.
It will immediately crash and no screen will be displayed.
Jul 21 10:28:40 tegra-ubuntu systemd[1]: systemd-timedated.service: Succeeded.
Jul 21 10:30:01 tegra-ubuntu CRON[3588]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
Jul 21 10:30:16 tegra-ubuntu systemd[1]: Started Run anacron jobs.
Jul 21 10:30:16 tegra-ubuntu anacron[3589]: Anacron 2.3 started on 2026-07-21
Jul 21 10:30:16 tegra-ubuntu anacron[3589]: Normal exit (0 jobs run)
Jul 21 10:30:16 tegra-ubuntu systemd[1]: anacron.service: Succeeded.
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Jul 21 10:32:07 tegra-ubuntu gnome-shell[2109]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: Started Application launched by gsd-media-keys.
Jul 21 10:32:08 tegra-ubuntu dbus-daemon[1685]: [session uid=1000 pid=1685] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.82' (uid=1000 pid=3611 comm="/usr/bin/gnome-terminal.real " label="kernel")
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: Created slice apps.slice.
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: Created slice apps-org.gnome.Terminal.slice.
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: Starting GNOME Terminal Server...
Jul 21 10:32:08 tegra-ubuntu dbus-daemon[1685]: [session uid=1000 pid=1685] Successfully activated service 'org.gnome.Terminal'
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: Started GNOME Terminal Server.
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: Started VTE child process 3622 launched by gnome-terminal-server process 3614.
Jul 21 10:32:08 tegra-ubuntu systemd[1394]: gnome-launched-x-terminal-emulator-3608.scope: Succeeded.
Jul 21 10:32:15 tegra-ubuntu kernel: [  327.881201] irq: IRQ307: trimming hierarchy from :pmc@c360000
Jul 21 10:32:15 tegra-ubuntu kernel: [  327.882154] irq: IRQ308: trimming hierarchy from :pmc@c360000
Jul 21 10:32:36 tegra-ubuntu systemd[1394]: Started Application launched by gsd-media-keys.
Jul 21 10:32:36 tegra-ubuntu systemd[1394]: Started VTE child process 3657 launched by gnome-terminal-server process 3614.
Jul 21 10:32:36 tegra-ubuntu systemd[1394]: gnome-launched-x-terminal-emulator-3648.scope: Succeeded.
Jul 21 10:32:38 tegra-ubuntu kernel: [  350.810083] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 10:33:05 tegra-ubuntu systemd[1394]: Started Application launched by gsd-media-keys.
Jul 21 10:33:05 tegra-ubuntu systemd[1394]: Started VTE child process 3683 launched by gnome-terminal-server process 3614.
Jul 21 10:33:05 tegra-ubuntu systemd[1394]: gnome-launched-x-terminal-emulator-3674.scope: Succeeded.
Jul 21 10:33:13 tegra-ubuntu kernel: [  386.257755] bwmgr API not supported
Jul 21 10:33:13 tegra-ubuntu kernel: [  386.266262] camera_sensor 10-002e: mode id= 0
Jul 21 10:33:16 tegra-ubuntu kernel: [  388.822988] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
Jul 21 10:33:16 tegra-ubuntu kernel: [  388.832142] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Jul 21 10:33:16 tegra-ubuntu kernel: [  388.841745] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 10:33:16 tegra-ubuntu kernel: [  388.849479] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
Jul 21 10:33:16 tegra-ubuntu kernel: [  388.860212] (NULL device *): vi_capture_control_message: NULL VI channel received
Jul 21 10:33:17 tegra-ubuntu kernel: [  389.879104] X<95><8b>
Jul 21 10:33:17 tegra-ubuntu kernel: [  389.879104] 5%ÿÿX<95><8b>
Jul 21 10:33:17 tegra-ubuntu kernel: [  389.879104] 5%ÿÿ (null): capture control message timed out
Jul 21 10:33:17 tegra-ubuntu kernel: [  389.888684] X<95><8b>
Jul 21 10:33:17 tegra-ubuntu kernel: [  389.888684] 5%ÿÿX<95><8b>
Jul 21 10:33:17 tegra-ubuntu kernel: [  389.888684] 5%ÿÿ (null): vi_capture_control_send_message: failed to send IVC control message
Jul 21 10:33:18 tegra-ubuntu kernel: [  390.903211] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
Jul 21 10:33:18 tegra-ubuntu kernel: [  390.911601] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
Jul 21 10:33:18 tegra-ubuntu kernel: [  390.918957] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
Jul 21 10:33:21 tegra-ubuntu dbus-daemon[1685]: [session uid=1000 pid=1685] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.75' (uid=1000 pid=2619 comm="/usr/libexec/tracker-miner-fs " label="kernel")
Jul 21 10:33:21 tegra-ubuntu systemd[1394]: Starting Tracker metadata database store and lookup manager...
Jul 21 10:33:21 tegra-ubuntu dbus-daemon[1685]: [session uid=1000 pid=1685] Successfully activated service 'org.freedesktop.Tracker1'
Jul 21 10:33:21 tegra-ubuntu systemd[1394]: Started Tracker metadata database store and lookup manager.
Jul 21 10:33:21 tegra-ubuntu kernel: [  393.977829] tlv320aic32x4 0-0018: plink aic32x4_hw_params begine!
Jul 21 10:33:21 tegra-ubuntu dbus-daemon[1685]: [session uid=1000 pid=1685] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.75' (uid=1000 pid=2619 comm="/usr/libexec/tracker-miner-fs " label="kernel")
Jul 21 10:33:21 tegra-ubuntu systemd[1394]: Starting Tracker metadata extractor...
Jul 21 10:33:21 tegra-ubuntu tracker-extract[3711]: Set scheduler policy to SCHED_IDLE
Jul 21 10:33:21 tegra-ubuntu tracker-extract[3711]: Setting priority nice level to 19
Jul 21 10:33:21 tegra-ubuntu dbus-daemon[1685]: [session uid=1000 pid=1685] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 21 10:33:21 tegra-ubuntu systemd[1394]: Started Tracker metadata extractor.
Jul 21 10:33:25 tegra-ubuntu PackageKit: daemon quit
Jul 21 10:33:25 tegra-ubuntu systemd[1]: packagekit.service: Succeeded.
Jul 21 10:33:32 tegra-ubuntu systemd[1394]: tracker-extract.service: Succeeded.
Jul 21 10:33:35 tegra-ubuntu gnome-shell[2109]: ../clutter/clutter/clutter-actor.c:10558: The clutter_actor_set_allocation() function can only be called from within the implementation of the ClutterActor::allocate() virtual function.
Please provide the model of the camera.
SG3S-ISX031C-GMSL2F
[3MP] SG3S-ISX031C-GMSL2F - SENSING
hello chen.xi,
according to above,
it’s the failure from sensor side since you reproduce this by using V4L2 IOCTL as well.
this is crucial.
according to the logs.. it’s attempting to reset the capture channel, but there’s NULL VI channel received in the end. it means a video node register to linux kernel has gone.
since this is customize carrier board with serdes chip, you may double check whether there’s a loose camera connector.
This can be confirmed: the camera is not loose. Once it is connected, it is already securely fixed. If there is an error or the system freezes, it will automatically restart. However, after that, it is no longer possible to preview the video stream data from the camera. The entire device needs to be powered off and reconnected to the power supply before the camera can function normally.
hello chen.xi,
please see-also below forum topics to apply patches which fix kernel panic when VI trying to recover camera stream.
for instance, Vi_capture_release causes kernel panic - #8 by JerryChang and Capture-ivc: fix multi-cam race condition.
The patch file 0001-capture-ivc-fix-multi-cam-race-condition.patch has been incorporated into the driver source code of version R35.6.4.
This is the phenomenon of previewing 6 cameras simultaneously after applying the patches. There will be a few milliseconds of lag and delay.
let’s have a new discussion thread for this issue.
It’s still the same issue. When previewing 8 cameras simultaneously, the system will immediately restart. I’m currently sorting through the syslog logs and will send them later.
syslog.txt (350.4 KB)
I deleted the unnecessary logs and only kept the logs from the moment I opened the first camera until the system restarted. I also replaced the frequently repeated content tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64 in the logs with '...'
I’d like to report a good news. After applying the patch, I was able to preview 8-channel 1280x720, 30-frame video streams without any lag.
I commented out the following content in the driver to prevent dmesg from repeatedly printing the same information.
File : vi5_fops.c
static void vi5_capture_dequeue(struct tegra_channel *chan,
        struct tegra_channel_buffer *buf)
                                        descr->status.flags, descr->status.err_data);
                        } else {
#if 0   /* Delete to disable log */
                                dev_warn(vi->dev,
                                        "corr_err: discarding frame %d, flags: %d, "
                                        "err_data %d\n",
                                        descr->status.frame_id, descr->status.flags,
#endif
                                frame_err = true;
However, when previewing the 8-channel 1080p video stream now, the system still experiences a phenomenon of freezing and then restarting.
https://forums.developer.nvidia.com/secure-uploads/nvidia/original/4X/4/3/2/432c8d2f6814f010492b1e73d18e5479bac56ed8.txt
It has been resolved. It seems to be a warning message about frequent departures that caused the system to crash. Just add the comments in the code.
