I am trying to update tegra X1 in production environment from L4T 24.2.1 to L4T 32.6.1.
I was able to write BFS1 to boot 1
NXC-1
PT-1
TXC-1
RP1-1
EBT-1
WX0-1
BXF-1
And then I wrote KFS1 to user
DTB-1
TOS-1
EKS-1
LNX-1
Now when I write BCT it boots TBoot from NXC-1, which is good.
But then TBoot sees a RP1 partition on emmc uses GPT, and completely ignores BFS1 and RP1-1 partition on mmcblk0boot1, and just fails to validate bootloader DTB.
I can easily replicate this behavior on vanilla L4T - flash the device, than rename any partition(EX: UDA) to RP1. It will fail to boot both BFS0 and BFS1, and will be stuck in recovery.
So I am unable to do an atomic bootloader update because I simultaneously need to update BCT to use NXC-1, and update GPT to remove RP1 partition, which confuses TBoot.
Maybe there is some configuration option for TBoot, to ignore GPT table, and use the PT-1 in boot1? Or at least ignore RP1 and use RP1-1 according to its BFS number?
I clearly see some configuration in Customer data of BCT, but there is no documentation.
UPD: It is reproducing on latest L4T: 32.7.2
- sudo ./flash.sh -u secure-boot-rsa-2048bit-private.pem jetson-tx1 mmcblk0p1
- ssh to device
- sudo sgdisk /dev/mmcblk0 -c 22:RP1
- reboot
Result:
[0000.382] Using GPT Primary to query partitions
[0000.387] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.393] Read PT from (0:3)
[0000.428] PT crc32 and magic check passed.
[0000.432] Using BFS PT to query partitions
[0000.437] PT: Partition RP5 NOT found !
[0000.440] Warning: Find Partition via PT Failed
[0000.445] Load RPB failed, skip RPB.
[0000.448] *** Booting BFS0.
[0000.451] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.457] PT: Partition LNX NOT found !
[0000.461] *** Booting KFS0.
[0000.463] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.469] Rail not supported
[0000.472] BoardID = 2180, SKU = 0x3e8
[0000.475] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.481] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.488] Loading Tboot-CPU binary
[0000.495] Verifying TBC in SecurePKC mode
[0000.504] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.511] Bootloader downloaded successfully.
[0000.515] Downloaded Tboot-CPU binary to 0xa0000258
[0000.520] MAX77620_GPIO1 Configured.
[0000.524] MAX77620_GPIO5 Configured.
[0000.527] CPU power rail is up
[0000.530] CPU clock enabled
[0000.534] Performing RAM repair
[0000.537] Updating A64 Warmreset Address to 0xa00002e9
[0000.542] BoardID = 2180, SKU = 0x3e8
[0000.545] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.551] Loading NvTbootBootloaderDTB
[0000.568] NvTbootBootloaderDTB is not valid
[0000.572] NvTbootBootloaderDTB partition is corrupted!
[0000.576] *** Set to failover in the next boot ***
[0000.581] NvTbootFailControlSetClobber:
[0000.585] *** Rebooting ***
[0000.179] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.184] Processing in cold boot mode Bootloader 2
[0000.189] A02 Bootrom Patch rev = 255
[0000.192] Power-up reason: software reset
[0000.196] No Battery Present
[0000.199] pmic max77620 reset reason
[0000.202] pmic max77620 NVERC : 0x0
[0000.205] RamCode = 0
[0000.208] Platform has Ddr4 type ram
[0000.211] max77620 disabling SD1 Remote Sense
[0000.215] Setting Ddr voltage to 1125mv
[0000.219] Serial Number of Pmic Max77663: 0x220fed
[0000.227] Entering ramdump check
[0000.230] Get RamDumpCarveOut = 0x0
[0000.233] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.238] Last reboot was clean, booting normally!
[0000.243] Sdram initialization is successful
[0000.247] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.253] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.259] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.265] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.270] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.276] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.282] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.288] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.304] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.310] Platform-DebugCarveout: 0
[0000.313] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.319] BoardID = 2180, SKU = 0x3e8
[0000.323] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.328] Read GPT from (0:3)
[0000.374] Csd NumOfBlocks=0
[0000.387] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 5 is corrupted (ec=0x14).
[0000.396] NvTbootFailControlDoClobber:
[0000.399] Current BFS=0
[0000.401] Clobber: Current BFS starts at 2048
[0000.406] *** Will failover to BFS 1.
[0000.410] *** Invert Offset 0 from 0x30 to 0xffffffcf
[0000.437] Clobber: returns e=0x0
[0000.440] - failover successful; Rebooting ...
[0000.228] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.233] Processing in cold boot mode Bootloader 2
[0000.238] A02 Bootrom Patch rev = 255
[0000.242] Power-up reason: software reset
[0000.245] No Battery Present
[0000.248] pmic max77620 reset reason
[0000.251] pmic max77620 NVERC : 0x0
[0000.255] RamCode = 0
[0000.257] Platform has Ddr4 type ram
[0000.260] max77620 disabling SD1 Remote Sense
[0000.264] Setting Ddr voltage to 1125mv
[0000.268] Serial Number of Pmic Max77663: 0x220fed
[0000.276] Entering ramdump check
[0000.279] Get RamDumpCarveOut = 0x0
[0000.282] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.287] Last reboot was clean, booting normally!
[0000.292] Sdram initialization is successful
[0000.296] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.302] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.308] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.314] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.320] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.326] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.331] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.337] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.353] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.360] Platform-DebugCarveout: 0
[0000.363] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.369] BoardID = 2180, SKU = 0x3e8
[0000.372] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.378] Read GPT from (0:3)
[0000.423] Csd NumOfBlocks=0
[0000.432] Using GPT Primary to query partitions
[0000.436] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.442] Read PT from (0:3)
[0000.478] PT crc32 and magic check passed.
[0000.482] Using BFS PT to query partitions
[0000.486] PT: Partition RP5 NOT found !
[0000.490] Warning: Find Partition via PT Failed
[0000.494] Load RPB failed, skip RPB.
[0000.497] *** Booting BFS1.
[0000.500] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.506] PT: Partition LNX NOT found !
[0000.510] *** Booting KFS1.
[0000.513] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.519] Rail not supported
[0000.521] BoardID = 2180, SKU = 0x3e8
[0000.525] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.531] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.538] Loading Tboot-CPU binary
[0000.544] Verifying TBC in SecurePKC mode
[0000.553] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.560] Bootloader downloaded successfully.
[0000.564] Downloaded Tboot-CPU binary to 0xa0000258
[0000.570] MAX77620_GPIO1 Configured.
[0000.573] MAX77620_GPIO5 Configured.
[0000.576] CPU power rail is up
[0000.579] CPU clock enabled
[0000.583] Performing RAM repair
[0000.586] Updating A64 Warmreset Address to 0xa00002e9
[0000.591] BoardID = 2180, SKU = 0x3e8
[0000.595] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.600] Loading NvTbootBootloaderDTB
[0000.617] NvTbootBootloaderDTB is not valid
[0000.621] NvTbootBootloaderDTB partition is corrupted!
[0000.626] *** Set to failover in the next boot ***
[0000.631] NvTbootFailControlSetClobber:
[0000.634] *** Rebooting ***
[0000.436] NvTbootFailControlDoFailover: Doing failover: NvTboot partition 5 is corrupted (ec=0x14).
[0000.445] NvTbootFailControlDoClobber:
[0000.449] Current BFS=1
[0000.451] Clobber: Current BFS starts at 8192
[0000.455] *** Will failover to BFS 2.
[0000.459] *** Invert Offset 0 from 0x30 to 0xffffffcf
[0000.494] Clobber: returns e=0x0
[0000.497] - failover successful; Rebooting ...
