I am trying to add an integer to a (signed) long long global variable using the atomicAdd function using Cuda 3.2. Unfortunately atomicAdd takes unsigned long long types and no signed long long types. The Cuda C Programming Guide says that any atomic operation can be implemented based on atomicCAS(). Which is what I am trying, but I am not succesfull. Below is my code:
__device__ long long atomicAdd(long long* address, int val)
unsigned long long int* address_as_ull = (unsigned long long int*)address;
unsigned long long int old = *address_as_ull, assumed;
do
assumed = old;
old = atomicCAS(address_as_ull, assumed, val + assumed);
} while (assumed != old);
return old;
I am also unable to print long long variables to my console. I have tried cuPrintf("%lld", long_value), cuPrintf("%d", long_value) and cuPrintf("%1f", long_value) but none of them are working.
Can anyone suggest a function that does work or another way to add an integer to a signed long long variable in global memory in an atomic fashion. Thank you very much in advance.
Kind regards,
Nick
