AtomicMax Im getting error while compiling my code due to atomicMax
Hi this is Gururaj and Im new to CUDA,
recently I wrote a simple CUDA program to find the Max element in an array using atomicMax.
But Im getting an error as mentioned below:
error: no instance of overloaded function “atomicMax” matches the argument list
argument types are: (float, float).
Can anybody pls help me to solve this problem?
Thanks in advance
Guruaj
Thanks in advance
Guruaj
atomicMax doesn’t support floating point types. There are tricks to convert floats into a 32 bit representation which will compare correctly using integer logic, however if you want to find the maximum of a non-trivial number of floats, use a parallel reduction instead. It will be appreciably faster.
