Attach_metadata_detector sequence
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.0.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) question
I have a question about gstnvinfer_meta_utils.cpp
When using the following pipeline,
PGIE(w/ custom parser) - Tracker,
when does the function "attach_metadata_detector"called?
Between PGIE and tracker or after tracker?
It was called in the nvinfer(PGIE):gst_nvinfer_output_loop in the sources\gst-plugins\gst-nvinfer\gstnvinfer.cpp file.
