Attach URI of file source to metadata
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• Issue Type( questions, new requirements, bugs) Question
I need to know which URI a frame is connected to, is there a way to access the URI of the source later on in the pipeline?
For example, is there is a way to, when creating a uridecodebin, attach the information of which URI is streamed to each frame meta of the stream?
I need the URI rather than the “source id”. Alternatively, is it possible to give a custom value as source_id when creating the uridecodebin?
I might be missing how to do this in a better way and would gladly take input if that’s the case!
You can map the uri to the source_id yourself. When you get the source_id of the frame, you can check it in your map.
Yeah of course, but I was wondering if there is another way which does not require me to add extra logic to keep track of which source IDs are connected to which URI. But I guess there is not then?
Yes. For now, you can record this value yourself.
Okay thanks!
