I followed the tutorial 2.5. Add Camera and Sensors β Omniverse IsaacSim latest documentation and added 2 cameras under 2 Xforms in the robot USD which I created and saved the USD for simulation.
Robot I am using is ridgeback_franka robot.
I checked using the viewport 2 to see the camera is moving with the mobile robot Check the video here.
But during Simulation the camera is not moving with the robot. Check the video here.
How to attach the camera to the robot in such a way that the camera moves with the robotβs frame in the simulation or in a RL environment ?
ridgeback_franka_v3.zip (37.3 KB)
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless" : False})
from omni.isaac.core.utils import rotations, prims
from omni.isaac.core import World
from omni.isaac.core.objects import VisualCuboid, DynamicCuboid
from omni.isaac.core import SimulationContext
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.utils.types import ArticulationAction
from omni.isaac.sensor import Camera
from ridgeback_controller import RidgebackController
from ridgeback_panda import Ridgeback_Panda
test_posture = np.array([ 0.0263547, 1.13884234, 0.03276233, 0.74701278, 0.01650456, 1.09152202, -0.04337771])
posture = np.array([0.239, -0.207, -0.191, -1.681, 0, 2.178, -0.048])
finger_posture = np.array([0.004,0.003])
posture2 = np.array([0, -1.00401, -0.95699, 0.087, -1.436, 1.257, -1.675])
vel = 0.5*np.ones((7,))
my_world = World(stage_units_in_meters=1.0)
my_robot = my_world.scene.add(
Ridgeback_Panda(
prim_path = "/World/Robot",
usd_path = "./ridgeback_franka_v3.usd",
name = "robot",
end_effector_name = "endeffector",
position = np.array([0,0,0]),
orientation = np.array([1,0,0,0]),
# camera = prims.create_prim(
# "/World/Robot",
# "Camera",
# translation=np.array([0.03721, 0.13557, 1.9807]),
# orientation=np.array([0.6816, 0.154, -0.20498, -0.68519]),
# # attributes={
# # "focusDistance": FOCUS_DIST,
# # "focalLength": FOCAL_LEN,
# # "horizontalAperture": HORIZONTAL_APERTURE,
# # "verticalAperture": VERTICAL_APERTURE,
# camera = my_world.scene.add(Camera(
# prim_path="/World/Robot/workspace_cam/workspace_camera",
# position=np.array([0.03721, 0.13557, 1.9807]),
# frequency=20,
# resolution=(256, 256),
# orientation=np.array([0.6816, 0.15438, -0.20498, -0.68519])),
base_controller = RidgebackController(name="ridgeback_controller")
# my_target = my_world.scene.add(
# VisualCuboid(
my_world.scene.add_default_ground_plane()
my_world.reset()
my_robot.initialize()
# camera.initialize()
# camera.add_motion_vectors_to_frame()
i = 0
while simulation_app.is_running():
my_world.step(render = True)
# my_robot.set_joint_positions(positions = test_posture, joint_indices = my_robot.panda_dof_indices)
# my_robot.set_joint_positions(positions = finger_posture, joint_indices = my_robot.panda_finger_dof_indices)
# print(my_robot.get_joint_positions(joint_indices = my_robot.panda_dof_indices))
# print(my_robot.get_joint_positions(joint_indices = my_robot.panda_finger_dof_indices))
my_robot.apply_wheel_actions(base_controller.move_robot(
linear_velocity=0.4,
linear_command="Y",
angular_velocity=0,
simulation_app.close()
This the running python code for the running simulation in the second video.
Thanks and regards,
T.
