Update : fetching from pypi on the builddoesnt work.
If i manually put the python net folder in pip_prebundle it sees them in the editor
But itdoes NOT see the package at run time. I get this error:
2024-04-11 19:40:15 [46,105ms] [Error] [omni.ext._impl.custom_importer] Failed to im
mport python module purdue.profk.omnidotnet. Error: No module named 'pythonnet'. Traceback:
File “d:\projects/omniverse/omnidotnet/build/windows-x86_64/release/kit/kernel/py\omni\ext_impl\custom_importer.py", line 76, in import_module
return importlib.import_module(name)
File "d:\projects\omniverse\omnidotnet_build\windows-x86_64\release\kit\python\lib\importlib_init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/exts/purdue.profk.omnidotnet/purdue/profk/omnidotnet/init.py”, line 1, in
from .python_ext import *
File “d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/exts/purdue.profk.omnidotnet/purdue/profk/omnidotnet/python_ext.py”, line 2, in
from pythonnet import load
ModuleNotFoundError: No module named ‘pythonnet’
2024-04-11 19:40:15 [46,107ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘purdue.profk.omnidotnet’ in ‘d:\projects\omniverse\omnidotnet_build\windows-x86_64\release\exts\purdue.profk.omnidotnet’ failed to load.
At:
d:\projects/omniverse/omnidotnet/_build/windows-x86_64/release/kit/kernel/py\omni\ext_impl_internal.py(213): startup
d:\projects/omniverse/omnidotnet/_build/windows-x86_64/release/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/extscache/omni.kit.window.extensions-1.3.0+de96b556/omni/kit/window/extensions/ext_commands.py(29): do
d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/extscache/omni.kit.commands-1.4.6+de96b556.wx64.r.cp310/omni/kit/undo/undo.py(80): execute
d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/extscache/omni.kit.commands-1.4.6+de96b556.wx64.r.cp310/omni/kit/commands/command.py(463): execute
d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/extscache/omni.kit.window.extensions-1.3.0+de96b556/omni/kit/window/extensions/common.py(288): toggle_extension
d:/projects/omniverse/omnidotnet/_build/windows-x86_64/release/extscache/omni.kit.window.extensions-1.3.0+de96b556/omni/kit/window/extensions/ext_components.py(93): toggle
2024-04-11 19:40:15 [46,109ms] [Error] [omni.ext.plugin] [ext: purdue.profk.omnidotnet-0.1.0] Failed to startup python extension.
