The cameras work once on startup using a gstreamer pipeline -
“gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=1280,height=720,framerate=15/1’ ! nvvidconv flip-method=2 ! tee name=t1 t1. ! queue silent=true ! nvv4l2h264enc bitrate=8000000 ! h264parse config-interval=1 ! queue silent=true leaky=downstream ! rndbuffersize max=65000 ! udpsink host=127.0.0.1 port=5001 sync=false t1. ! queue silent=true ! nvjpegenc ! rtpjpegpay ! udpsink host=127.0.0.1 port=5000 sync=false”
and
“nvarguscamerasrc sensor-id=1 ! video/x-raw(memory:NVMM),width=1280,height=720,framerate=15/1, format=NV12, framerate=15/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)BGRx ! videoconvert”
as well as the default provided nvargus command.
After launching a few times, they log “Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:543 Failed to create CaptureSession” every subsequent connection attempt. This is fixed by restarting the nano.
Please share your release version( $ head -1 /etc/nv_tegra_release ) and steps for reproducing the issue, such as running gst-launch command or a simple test code.
And information of the camera board(Raspberry Pi camera V2 or others).
Release Version: # R32 (release), REVISION: 3.1, GCID: 18186506, BOARD: t210ref, EABI: aarch64, DATE: Tue Dec 10 06:58:34 UTC 2019
Steps to Reproduce Issue:
- Run
gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM),width=1280,height=720,framerate=15/1, format=NV12, framerate=15/1' ! nvvidconv flip-method=2 ! video/x-raw, format=BGRx ! videoconvert
Logs:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=3024000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason not-linked (-1)
Execution ended after 0:00:01.108775515
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
GST_ARGUS:
PowerServiceHwVic::cleanupResources
- ROS2:
Setup and install ROS GSCAM2.
Run
export gscam_config='nvarguscamerasrc sensor-id=1 ! video/x-raw(memory:NVMM), width=1280, height=720, format=NV12, framerate=15/1 ! nvvidconv flip-method=2 ! video/x-raw, format=BGRx ! videoconvert' && ros2 launch gscam gscam_main
The sensor-id looks not right. It should be 0 Or you have two cameras being connected?
And the pipeline should be with sink such as fakesink
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1280,height=720,framerate=15/1, format=NV12, framerate=15/1' ! nvvidconv flip-method=2 ! video/x-raw, format=BGRx ! videoconvert ! fakesink
Yes, we have two cameras connected. The pipeline is appended into the ROS Gstream node, which apends its own sink. That being said, the behavior still occurs with a autovideosink or udpsink appended. I’ve noticed that it consistently occurs with this commands:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=512,height=288,framerate=15/1' ! nvvidconv flip-method=2 ! tee name=t1 t1. ! queue silent=true ! nvv4l2h264enc bitrate=8000000 ! h264parse config-interval=1 ! queue silent=true leaky=downstream ! rndbuffersize max=65000 ! udpsink host=127.0.0.1 port=5001 sync=false t1. ! queue silent=true ! nvjpegenc ! rtpjpegpay ! udpsink host=127.0.0.1 port=5000 sync=false`
It should be an issue in nvjpegenc. Please take a look at:
https://elinux.org/L4T_Jetson/r32.3.x_patch
[GSTREAMER]streaming using jpegenc halts after a short delay
And apply the prebuilt lib.
After applying that patch, the gstreamer behavior is a bit more consistent, but it still fails sporadically (around every 10 launches).
Please share how we can reproduce the failure. Do you run
- Excute
Ctrl +C to exit the pipeline
- Do step 1 2 repeatedly and the issue is hit once ~10 trials.
Correct, it actually fails every other time with that command now, the behavior is inconsistent. It seems to be that pipeline specifically, as I’m now using a different pipeline in code which hasn’t had any problems yet.
I tried 1 and 2. For 3, what do you meaning using nvvid conv to convert NV12 to I420?
Yes this is what I meant. However, I have just tried your command and it seems it is rather related to previous gstreamer pipeline failing to close properly.
I can reliably launch and stop your pipeline many times with EOS (use -e with gst-launch-1.0).
Yeah it seems to be working consistently now after a few restarts, thanks for the help!
