AttributedError: module 'pyrealsense2' has no attributed 'pipeline' fault on jetson nano with realsense
Hello everyone,
I am newbie and triying stream on realsense D455 cam to jetson nano 4gb hardware. I got " AttributedError: module ‘pyrealsense2’ has no attributed ‘pipeline’" error message.
I tried several method from internet and forum but I couldn’t find the way.
Can you light me?
Ubuntu 18.04
python3.6
I checked and changed the with ./bash export pythondatapath /usr/local/lib/python3.6
By default we support UVC driver. Please try the steps:
Jetson Nano FAQ
Q: I have a USB camera. How can I launch it on Jetson Nano?
And you may also try the driver:
https://github.com/IntelRealSense/librealsense/archive/refs/tags/v2.50.0.tar.gz
I downloaded but I cannot set up this document. Because this folder is different folder structure. I used to buildrealsense.sh but now I cannot find.
We have seen an issue due to old firmware:
RealSenseD400 Camera can not work on Jetson Xavier NX - #17 by ShaneCCC
Please upgrade the firmware and try again.
Hello, I fixed this problem with this link. librealsense/wrappers/python at master · IntelRealSense/librealsense · GitHub.
After installation, I needed to change the two document locations.
