Jetson Xavier NX
• DeepStream Version
DeepStream 6.0
4.6.1-b110
• TensorRT Version
8.2.1.8
I am trying to run deepstream by python. To install, I follow this instruction. Initially, it returned
No module named ‘pyds’
so I installed by
pip3 install pyds
Afterwards, I got this error when I ran deepstream_test_1_usb.py(https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/blob/master/apps/deepstream-test1-usbcam/deepstream_test_1_usb.py):
AttributeError: module ‘pyds’ has no attribute ‘gst_buffer_get_nvds_batch_meta’ SYNC_IOC_FENCE_INFO ioctl failed with 9 0:01:39.756706843 15773 0x3e7a3b20 ERROR nvvideoconvert gstnvvideoconvert.c:3488:gst_nvvideoconvert_transform: buffer transform failed
It seems very similar to this topic, but the version of deepstream is different.
I searched the solution but I couldn’t find… How could I solve this?
Thank you in advance for your support.
