AttributeError: 'NoneType' object has no attribute '_physx_interface
I’m still working with my linear motor plane.
Now I can apply a force on it, but I can get its postition callback.Below is my code now:
import omni.usd
import omni.physx.scripts.physicsUtils as physicsUtils
from pxr import Usd, UsdPhysics, Gf, UsdGeom
from isaacsim.core.api import SimulationContext
import carb
cad_prim_path = "/World/Move/Stage/Mesh_016"
simulation_context = SimulationContext()
cad_prim = stage.GetPrimAtPath(cad_prim_path)
if not cad_prim.IsValid():
    carb.log_error(f"Prim at path {cad_prim_path} is not valid. Please ensure the USD stage is loaded correctly.")
    exit()
xform_api = UsdGeom.Xformable(cad_prim)
def get_prim_position_callback(step_size):
    world_transform = xform_api.GetLocalTransformation()
    position = world_transform.ExtractTranslation()
    carb.log_info(f"Prim '{cad_prim_path}' current position: {position}")
rigid_body_api = UsdPhysics.RigidBodyAPI.Get(stage, cad_prim_path)
force_to_apply = Gf.Vec3f(0.0, 20.0, 0.0)
torque_to_apply = Gf.Vec3f(0.0, 0.0, 0.0)
physicsUtils.add_force_torque(
        stage=stage,
        path=cad_prim_path,
        force=force_to_apply,
        torque=torque_to_apply,
        mode="force",
        isWorldSpace=True
carb.log_info(f"Force applied to {cad_prim_path}. Start simulation by pressing 'Play' in the GUI to see position             updates.")
simulation_context.play()
simulation_context.add_physics_callback("cad_prim_position_logger", get_prim_position_callback)
And I got this error:
Traceback (most recent call last) Traceback (most recent call last):
File “c:/isaacsim/exts/isaacsim.code_editor.vscode/isaacsim/code_editor/vscode/executor.py”, line 78, in execute
result = eval(code, self._globals, self._locals)
File “”, line 54, in
File “c:/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/simulation_context/simulation_context.py”, line 967, in add_physics_callback
] = self._physics_context._physx_interface.subscribe_physics_step_events(callback_fn)
AttributeError: ‘NoneType’ object has no attribute '_physx_interface
@chesterhsu0923 not sure if this thread is relevant?
Thanks for reply!But it still can’t work.
It looks like it still not subscribed to my PhysicScene
import omni.usd
import carb
physics_scene_prim_path = "/World/PhysicsScene"
simulation_context = SimulationContext(physics_prim_path=physics_scene_prim_path)
simulation_context.initialize_physics()
print(simulation_context)
   exit()
force_to_apply = Gf.Vec3f(0.0, 15.0, 0.0)
        stage=stage,
        path=cad_prim_path,
        mode="force",
        isWorldSpace=True
It still the same error AttributeError: ‘NoneType’ object has no attribute '_physx_interface
but when I print(simulation_context), it gets
<isaacsim.core.api.simulation_context.simulation_context.SimulationContext object at 0x000001EAF7BB7A00>
I don’t understand where is my falut
Hi @chesterhsu0923, thanks for reaching out. Could you please share the usd file shown in the image?
I am unable to reproduce the error you shared, this is my script (I’ve replaced the Mesh with a TestCube for now)
from isaacsim import SimulationApp
simulation_app = SimulationApp({"headless": False})
import omni.usd
import carb
# Ensure physics scene exists
if not stage.GetPrimAtPath(physics_scene_prim_path).IsValid():
    UsdPhysics.Scene.Define(stage, physics_scene_prim_path)
    print(f"Original prim not found. Creating test cube...")
    # Create a simple test cube
    cad_prim_path = "/World/TestCube"
    cube_geom = UsdGeom.Cube.Define(stage, cad_prim_path)
    cube_geom.CreateSizeAttr(1.0)
    cube_geom.AddTranslateOp().Set(Gf.Vec3f(0.0, 0.0, 2.0))
    # Add physics
    UsdPhysics.RigidBodyAPI.Apply(cube_geom.GetPrim())
    UsdPhysics.CollisionAPI.Apply(cube_geom.GetPrim())
    UsdPhysics.MeshCollisionAPI.Apply(cube_geom.GetPrim())
    print(f"Created test cube at {cad_prim_path}")
   # Use print instead of carb.log_info to see output in console
   print(f"Prim '{cad_prim_path}' current position: {position}")
        stage=stage,
        path=cad_prim_path,
        mode="force",
        isWorldSpace=True
simulation_context.add_physics_callback("cube_position_logger", get_prim_position_callback)
print("Simulation running... Close the window to exit.")
while simulation_app.is_running():
    simulation_context.step(render=True)
Try this:
from isaacsim.core.api.physics_context import PhysicsContext
# set your own prim_path path here:
PhysicsContext_instance = PhysicsContext(prim_path="/World/PhysicsScene")
simulation_context._physics_context = PhysicsContext_instance # weird insertion to assure _physics_context, I think it is a bug.
