I’ve a tensorflow model which I’d like to convert to uff. When I run:
uff_model = uff.from_tensorflow(Ava_SSL_GAN_NCHW, ["Discriminator/Softmax"])
I get the following error:
AttributeError Traceback (most recent call last)
<ipython-input-71-9034f49554a9> in <module>()
----> 1 uff_model = uff.from_tensorflow(Ava_SSL_GAN_NCHW, ["Discriminator/Softmax"])
2 print(uff_model)
/usr/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py in from_tensorflow(graphdef, output_nodes, **kwargs)
47 for i, name in enumerate(output_nodes):
48 output_nodes[i] = tf2uff.convert_node_name_or_index_to_name(
---> 49 name, graphdef.node)
50 if not quiet:
51 print("Using output node", output_nodes[i])
AttributeError: 'Tensor' object has no attribute 'node'
Can someone help me please? I can’t find anything explaining why I’m getting this error.
If it helps, my tensorflow model is the discriminator in a GAN’s setup which I isolated from the whole architecture after trained my GAN.
