When recording, use the terminal command:
amixer -c APE cset name=“I2S2 Mux” “ADMAIF1”
amixer -c APE cset name=“ADMAIF1 Mux” “I2S2”
amixer -c APE cset name=“CVB-RT RECMIXL BST1 Switch” “on”
amixer -c APE cset name=“CVB-RT RECMIXR BST2 Switch” “on”
amixer -c APE cset name=“CVB-RT RECMIXR BST1 Switch” “1”
amixer -c APE cset name=“CVB-RT IN1 Boost” 8
amixer -c APE cset name=“CVB-RT IN2 Boost” 8
amixer -c APE cset name=“CVB-RT Stereo ADC1 Mux” “ADC”
amixer -c APE cset name=“CVB-RT Stereo ADC MIXL ADC1 Switch” “on”
amixer -c APE cset name=“CVB-RT Stereo ADC MIXR ADC1 Switch” “on”
arecord -Dhw:APE,1 -c 2 -r 48000 -f S16_LE -d 15 out.wav
Orin Nano has MCLK output; However, there is no signal from others, and there is no sound in the recorded file outwav
Using Single-End Mode
kernel_log.txt (60.2 KB)
pinmux.txt (31.5 KB)
clock.txt (40.5 KB)
codec_regdump.txt (2.9 KB)
dt.log (315.7 KB)
reg_dump.txt (585 Bytes)
settings.txt (324.9 KB)
