Audio in on the tx1?
Is there anyway to get audio in on the tx1? If not then will a usb audio adapter work to add both microphone and speaker?
No physical connection is available for directly connecting audio, aside from the stereo out which is tied to the HDMI cable. Everything needed to process audio is already there, I’ve used USB headphones (7.1 surround sound plus mic, tested on “mumble” and 7.1 demo files) without any need to adjust anything. Most Linux capable USB sound cards should also work if they have support in the current kernel (which pretty much means most popular sound cards, but you can look up their chipset and research).
