Hi there,
What are the options for audio input/output processing on Drive AGX?
Thanks,
B.
Hi there,
Thanks,
B.
Hi bogdan0kg3v,
For audio input/output. There is no formally supported method, but USB audio should be possible as it is used by Drive IX.
You would need to utilize a USB audio device, such as a USB Audio adapter: https://www.audio-technica.com/cms/accessories/de806038b48c13d7/index.html or a device like a USB headset.
Then you’ll need to work through the alsamixer settings to get audio to work properly for the USB device.
Hope it helps!
FYI: I have tried to play sound on Drive AGX with USB audio interface. I could not configure sound on Ubuntu setting screen. After starting pulseaudio, I could configure from the setting screen and played sound as usual Ubuntu.
I used following command (or added the line on .bashrc).
pulseaudio -D
I suppose I should use systemctl to launch pulseaudio but I could not start user service. I have not investigated about it and bashrc is enough for my temporal use.
This may be different from original intention but it may be helpful for other Drive AGX users.
