Audio problem cracking/poping when I2C transaction timeout
I am using the audio I2S bus on the 40-pin connector, configured as a TDM 16x.
All 16 channels seem to be working well.
But I noticed that the audio crack/pop when I initiated an I2C transaction that is not acknowledged because the slave is not ready.
The easiest way to reproduce this problem is to type: “i2cdetect -y -r 0”.
These are caused by XRUNs, audio frames that are finished to be processed before the realtime dead line.
I also noticed some cracks/pops when plugging/unplugging the HDMI cable.
To enable audio I type:
“mw 0x6000a204 0” at the U-Boot prompt
And configure ALSA with:
amixer -c tegrasndt210ref -q sset ‘ADMAIF1 Mux’ I2S4
amixer -c tegrasndt210ref -q sset ‘I2S4 codec frame mode’ dsp-a
amixer -c tegrasndt210ref -q sset ‘I2S4 fsync width’ 256
amixer -c tegrasndt210ref -q sset ‘ADMAIF1 Channels’ 16
amixer -c tegrasndt210ref -q sset ‘I2S4 Channels’ 16
amixer -c tegrasndt210ref -q sset ‘I2S4 Sample Rate’ 44100
amixer -c tegrasndt210ref -q sset ‘I2S4 codec bit format’ 32
amixer -c tegrasndt210ref -q sset ‘I2S4 input bit format’ 32
Hello!
We have added a section on XRUNs to the L4T audio documentation. Can you take a look at the suggestions and see if any of these make a difference …
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fasoc_driver.html%23wwpID0E0SH0HA
Regards,
Jon
Hi Jon,
Thanks for the link, I tried the suggestions but no change.
I am using the JACK Low latency Audio Framework with ALSA backend and I am playing audio signals directly from memory so no filesystem involved.
I am using the MAXN power mode, maximum clock speed, performance governor and all my processes have realtime priority.
I tested audio frame size of 64, 128 and 256 at 44.1khz and 48KHz.
The problem sound worse with smaller audio frame size but is still very noticeable with 256 frame size.
My application requires an analog loopback latency of ~10ms maximum.
The latencies I am measuring are very good, going out off the JACK framework to the TDM16x converted with an FPGA to eight I2S busses, going to a stereo DAC, looped back analog to a stereo ADC, to I2S, to TDM16x and back in the JACK framework, I measure at 44.1KHz:
  • 3.78ms with buffer size of 64
  • 6.64ms with buffer size of 128
  • 12.48ms with buffer size of 256
    The maximum frame size I can use is 256 to meet my requirements.
The Jetson Nano board is working very well, seems very stable playing audio reliably with low latencies.
Seems like there is only problems with:
  • I2C transactions that timeout
  • Plugging/Unplugging the HDMI connector
Hello!
Thanks for the feedback. I will take a look at this and see if I can reproduce the problem.
I assume that on Nano you are outputing 16x16-bit channels @ 44.1kHz from one I2S interface that is connected to an FPGA?
Jon
Hello!
Just to confirm, what Jetpack/L4T release are you using?
Jon
My version is:
dpkg-query --show nvidia-l4t-core
Nvidia-l4t-core 32.2.1-20190812212815
I am using the I2S on the 40-pin connector (pin 12,19,38,40)
It is configure as a TDM 16x (16ch in and out) with 32-bit integer little-endian format for both capture and playback
I usually run at 16KHz, 32KHz, 44.1KHz and 48KHz.
You are correct the 40 pin connector I2S (really a TDM16) goes to an FPGA that convert it to Eight true I2S busses each with 2 channels in and out.
Thanks for looking into this.
Hello!
For the issue “I also noticed some cracks/pops when plugging/unplugging the HDMI cable.” Can you try applying the below change. Please build the kernel image and flash.
diff --git a/drivers/video/tegra/dc/hda_dc.c b/drivers/video/tegra/dc/hda_dc.c
index de250de..80857df 100644
--- a/drivers/video/tegra/dc/hda_dc.c
+++ b/drivers/video/tegra/dc/hda_dc.c
@@ -1,7 +1,7 @@
  * hda_dc.c: tegra dc hda dc driver.
- * Copyright (c) 2015-2018, NVIDIA CORPORATION, All rights reserved.
+ * Copyright (c) 2015-2019, NVIDIA CORPORATION, All rights reserved.
  * Author: Animesh Kishore <ankishore@nvidia.com>
  * Author: Rahul Mittal <rmittal@nvidia.com>
@@ -46,14 +46,14 @@
 	tegra_unpowergate_partition(sor->powergate_id);
 	tegra_sor_safe_clk_enable(sor);
-	if (!tegra_is_bl_display_initialized(sor->dc->ctrl_num))
+	if (!sor->dc->initialized)
 		tegra_sor_clk_enable(sor);
 	tegra_dc_io_start(sor->dc);
 	dev_id = tegra_sor_readl_ext(sor, NV_SOR_AUDIO_GEN_CTRL);
 	dev_id = (dev_id >> NV_SOR_AUDIO_GEN_CTRL_DEV_ID_SHIFT) &
 			NV_SOR_AUDIO_GEN_CTRL_DEV_ID_MASK;
 	tegra_dc_io_end(sor->dc);
 		tegra_sor_clk_disable(sor);
 	tegra_sor_safe_clk_disable(sor);
 	tegra_powergate_partition(sor->powergate_id);
mkumard,
Thanks a lot, unplugging/plugging the HDMI cable does not created XRUNs anymore, audio sound clean.
Hello!
That’s great to hear about XRUNs issue has been resolved on your end.
Also regarding the I2C timeout issue, Please cross check your configurations and provide the kernel log if the issue still exists.
Sorry, looks like my post was not clear.
The patch you provided fixed the XRUNs caused by unplugging/plugging HDMI, thanks very much for this.
But the XRUNs caused by the I2C timeout are still present.
I am not sure I understand what you mean by “cross check your configurations and provide the kernel log”?
Hello!
For the XRUNs due to I2C timeout. Indeed I tried with the step mentioned in your earlier comment i.e to use “i2cdetect -y -r 0” command. But unfortunately not able to hit the issue on our side. So it would be great if you can provide the full kernel log dump to analyze the root cause.
Thanks for looking into this, here is the log:
Nov 4 19:13:06 bionic kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Nov 4 19:13:06 bionic kernel: [ 0.000000] Linux version 4.9.140-tegra (preq@pulaski) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Fri Nov 1 17:06:52 EDT 2019
Nov 4 19:13:06 bionic kernel: [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: fdt: - 80000000 , 7ee00000
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: fdt: - 100000000 , 7f200000
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
Nov 4 19:13:06 bionic kernel: [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Nov 4 19:13:06 bionic kernel: [ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
Nov 4 19:13:06 bionic kernel: [ 0.000000] On node 0 totalpages: 1039872
Nov 4 19:13:06 bionic kernel: [ 0.000000] DMA zone: 8192 pages used for memmap
Nov 4 19:13:06 bionic kernel: [ 0.000000] DMA zone: 0 pages reserved
Nov 4 19:13:06 bionic kernel: [ 0.000000] DMA zone: 519168 pages, LIFO batch:31
Nov 4 19:13:06 bionic kernel: [ 0.000000] Normal zone: 8136 pages used for memmap
Nov 4 19:13:06 bionic kernel: [ 0.000000] Normal zone: 520704 pages, LIFO batch:31
Nov 4 19:13:06 bionic kernel: [ 0.000000] psci: probing for conduit method from DT.
Nov 4 19:13:06 bionic kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Nov 4 19:13:06 bionic kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Nov 4 19:13:06 bionic kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Nov 4 19:13:06 bionic kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Nov 4 19:13:06 bionic kernel: [ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb5000 s61592 r8192 d32616 u102400
Nov 4 19:13:06 bionic kernel: [ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
Nov 4 19:13:06 bionic kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Nov 4 19:13:06 bionic kernel: [ 0.000000] CPU features: enabling workaround for ARM erratum 832075
Nov 4 19:13:06 bionic kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
Nov 4 19:13:06 bionic kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
Nov 4 19:13:06 bionic kernel: [ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Nov 4 19:13:06 bionic kernel: [ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
Nov 4 19:13:06 bionic kernel: [ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
Nov 4 19:13:06 bionic kernel: [ 0.000000] log_buf_len min size: 32768 bytes
Nov 4 19:13:06 bionic kernel: [ 0.000000] log_buf_len: 131072 bytes
Nov 4 19:13:06 bionic kernel: [ 0.000000] early log buf free: 29512(90%)
Nov 4 19:13:06 bionic kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.000000] Memory: 3570240K/4159488K available (15230K kernel code, 2914K rwdata, 6716K rodata, 8576K init, 609K bss, 114112K reserved, 475136K cma-reserved)
Nov 4 19:13:06 bionic kernel: [ 0.000000] Virtual kernel memory layout:
Nov 4 19:13:06 bionic kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff8009600000 ( 6784 KB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a138808 ( 2915 KB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] .bss : 0xffffff800a138808 - 0xffffff800a1d0dbc ( 610 KB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Nov 4 19:13:06 bionic kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
Nov 4 19:13:06 bionic kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
Nov 4 19:13:06 bionic kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Nov 4 19:13:06 bionic kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Nov 4 19:13:06 bionic kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
Nov 4 19:13:06 bionic kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
Nov 4 19:13:06 bionic kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
Nov 4 19:13:06 bionic kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Nov 4 19:13:06 bionic kernel: [ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
Nov 4 19:13:06 bionic kernel: [ 0.000000] t210 clock and reset probe
Nov 4 19:13:06 bionic kernel: [ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
Nov 4 19:13:06 bionic kernel: [ 0.000000] clk_cbus_recalc_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
Nov 4 19:13:06 bionic kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Nov 4 19:13:06 bionic kernel: [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Nov 4 19:13:06 bionic kernel: [ 0.001737] Console: colour dummy device 80x25
Nov 4 19:13:06 bionic kernel: [ 0.001757] console [tty0] enabled
Nov 4 19:13:06 bionic kernel: [ 0.001774] kmemleak: Kernel memory leak detector disabled
Nov 4 19:13:06 bionic kernel: [ 0.001794] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
Nov 4 19:13:06 bionic kernel: [ 0.001807] pid_max: default: 32768 minimum: 301
Nov 4 19:13:06 bionic kernel: [ 0.002255] Security Framework initialized
Nov 4 19:13:06 bionic kernel: [ 0.002473] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.002482] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.003581] ftrace: allocating 46938 entries in 184 pages
Nov 4 19:13:06 bionic kernel: [ 0.173265] sched-energy: CPU device node has no sched-energy-costs
Nov 4 19:13:06 bionic kernel: [ 0.173299] ASID allocator initialised with 65536 entries
Nov 4 19:13:06 bionic kernel: [ 0.211575] tegra-id: chipid=22117.
Nov 4 19:13:06 bionic kernel: [ 0.211587] tegra-id: opt_subrevision=0.
Nov 4 19:13:06 bionic kernel: [ 0.211603] Tegra Speedo/IDDQ fuse revision 4
Nov 4 19:13:06 bionic kernel: [ 0.211608] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
Nov 4 19:13:06 bionic kernel: [ 0.211612] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
Nov 4 19:13:06 bionic kernel: [ 0.211618] Tegra: CPU Speedo Value 2083, SoC Speedo Value 1966, GPU Speedo Value 2088
Nov 4 19:13:06 bionic kernel: [ 0.211622] Tegra: CPU IDDQ Value 2092, SoC IDDQ Value 2316, GPU IDDQ Value 2795
Nov 4 19:13:06 bionic kernel: [ 0.211641] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
Nov 4 19:13:06 bionic kernel: [ 0.211655] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
Nov 4 19:13:06 bionic kernel: [ 0.211661] DTB Build time: Aug 12 2019 21:21:24
Nov 4 19:13:06 bionic kernel: [ 0.261046] CPU1: Booted secondary processor [411fd071]
Nov 4 19:13:06 bionic kernel: [ 0.292970] CPU2: Booted secondary processor [411fd071]
Nov 4 19:13:06 bionic kernel: [ 0.324949] CPU3: Booted secondary processor [411fd071]
Nov 4 19:13:06 bionic kernel: [ 0.325039] Brought up 4 CPUs
Nov 4 19:13:06 bionic kernel: [ 0.325047] SMP: Total of 4 processors activated.
Nov 4 19:13:06 bionic kernel: [ 0.325055] CPU features: detected feature: 32-bit EL0 Support
Nov 4 19:13:06 bionic kernel: [ 0.325314] CPU: All CPU(s) started at EL2
Nov 4 19:13:06 bionic kernel: [ 0.325331] alternatives: patching kernel code
Nov 4 19:13:06 bionic kernel: [ 0.333414] devtmpfs: initialized
Nov 4 19:13:06 bionic kernel: [ 0.371068] Initilizing CustomIPI irq domain
Nov 4 19:13:06 bionic kernel: [ 0.371461] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Nov 4 19:13:06 bionic kernel: [ 0.371482] futex hash table entries: 1024 (order: 4, 65536 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.381951] pinctrl core: initialized pinctrl subsystem
Nov 4 19:13:06 bionic kernel: [ 0.382577] OS set in device tree is not L4T.
Nov 4 19:13:06 bionic kernel: [ 0.382975] regulator-dummy: no parameters
Nov 4 19:13:06 bionic kernel: [ 0.383255] Initializing plugin-manager
Nov 4 19:13:06 bionic kernel: [ 0.383360] Plugin module not found
Nov 4 19:13:06 bionic kernel: [ 0.383584] node /plugin-manager/fragement@0 match with board >=3448-0000-100
Nov 4 19:13:06 bionic kernel: [ 0.384142] node /plugin-manager/fragment@1 match with board >=3448-0000-101
Nov 4 19:13:06 bionic kernel: [ 0.384997] node /plugin-manager/fragment@5 match with board 3449-0000-200
Nov 4 19:13:06 bionic kernel: [ 0.385474] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
Nov 4 19:13:06 bionic kernel: [ 0.385881] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
Nov 4 19:13:06 bionic kernel: [ 0.386264] node /plugin-manager/fragement@9 match with board <3448-0000-300
Nov 4 19:13:06 bionic kernel: [ 0.390757] NET: Registered protocol family 16
Nov 4 19:13:06 bionic kernel: [ 0.392272] pstore: using zlib compression
Nov 4 19:13:06 bionic kernel: [ 0.392312] console [pstore-1] enabled
Nov 4 19:13:06 bionic kernel: [ 0.392317] pstore: Registered ramoops as persistent store backend
Nov 4 19:13:06 bionic kernel: [ 0.392323] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
Nov 4 19:13:06 bionic kernel: [ 0.409062] cpuidle: using governor menu
Nov 4 19:13:06 bionic kernel: [ 0.413301] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
Nov 4 19:13:06 bionic kernel: [ 0.414952] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e64000)
Nov 4 19:13:06 bionic kernel: [ 0.414975] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Nov 4 19:13:06 bionic kernel: [ 0.417517] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
Nov 4 19:13:06 bionic kernel: [ 0.420153] tegra_powergate_init: DONE
Nov 4 19:13:06 bionic kernel: [ 0.420170] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
Nov 4 19:13:06 bionic kernel: [ 0.420177] DTB Build time: Aug 12 2019 21:21:24
Nov 4 19:13:06 bionic kernel: [ 0.421926] Tegra reboot handler registered.
Nov 4 19:13:06 bionic kernel: [ 0.426337] iommu: Adding device tegra-carveouts to group 0
Nov 4 19:13:06 bionic kernel: [ 0.426473] platform tegra-carveouts: domain=ffffffc0f9bb63d8 allocates as[0]=ffffffc0f94300a8
Nov 4 19:13:06 bionic kernel: [ 0.426825] iommu: Adding device smmu_test to group 1
Nov 4 19:13:06 bionic kernel: [ 0.426870] platform smmu_test: domain=ffffffc0f9bb6618 allocates as[0]=ffffffc0f9430110
Nov 4 19:13:06 bionic kernel: [ 0.427679] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
Nov 4 19:13:06 bionic kernel: [ 0.427737] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
Nov 4 19:13:06 bionic kernel: [ 0.427793] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
Nov 4 19:13:06 bionic kernel: [ 0.427802] nv-tegra-mc 70019000.mc: No mssnvlink node
Nov 4 19:13:06 bionic kernel: [ 0.427824] mc-err: mcerr ops are set to t21x
Nov 4 19:13:06 bionic kernel: [ 0.437016] iommu: Adding device 70090000.xusb to group 2
Nov 4 19:13:06 bionic kernel: [ 0.437362] iommu: Adding device 70006000.serial to group 3
Nov 4 19:13:06 bionic kernel: [ 0.437422] platform 70006000.serial: domain=ffffffc0f9bcecd8 allocates as[0]=ffffffc0f9430178
Nov 4 19:13:06 bionic kernel: [ 0.437815] iommu: Adding device 70006040.serial to group 4
Nov 4 19:13:06 bionic kernel: [ 0.438071] iommu: Adding device 70006200.serial to group 5
Nov 4 19:13:06 bionic kernel: [ 0.438246] iommu: Adding device sound to group 6
Nov 4 19:13:06 bionic kernel: [ 0.438296] platform sound: domain=ffffffc0f94b4258 allocates as[0]=ffffffc0f94301e0
Nov 4 19:13:06 bionic kernel: [ 0.438843] iommu: Adding device 7000d400.spi to group 7
Nov 4 19:13:06 bionic kernel: [ 0.439092] iommu: Adding device 7000d600.spi to group 8
Nov 4 19:13:06 bionic kernel: [ 0.439381] iommu: Adding device 70410000.spi to group 9
Nov 4 19:13:06 bionic kernel: [ 0.439676] iommu: Adding device 50000000.host1x to group 10
Nov 4 19:13:06 bionic kernel: [ 0.439954] iommu: Adding device 54080000.vi to group 11
Nov 4 19:13:06 bionic kernel: [ 0.440340] iommu: Adding device 54600000.isp to group 12
Nov 4 19:13:06 bionic kernel: [ 0.440597] iommu: Adding device 54680000.isp to group 13
Nov 4 19:13:06 bionic kernel: [ 0.440866] iommu: Adding device tegradc.0 to group 14
Nov 4 19:13:06 bionic kernel: [ 0.440915] platform tegradc.0: domain=ffffffc0f94c0198 allocates as[0]=ffffffc0f9430248
Nov 4 19:13:06 bionic kernel: [ 0.441477] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
Nov 4 19:13:06 bionic kernel: [ 0.441799] iommu: Adding device tegradc.1 to group 15
Nov 4 19:13:06 bionic kernel: [ 0.441853] platform tegradc.1: domain=ffffffc0f94c03d8 allocates as[0]=ffffffc0f94302b0
Nov 4 19:13:06 bionic kernel: [ 0.442358] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
Nov 4 19:13:06 bionic kernel: [ 0.442631] iommu: Adding device 54340000.vic to group 16
Nov 4 19:13:06 bionic kernel: [ 0.442826] iommu: Adding device 544c0000.nvenc to group 17
Nov 4 19:13:06 bionic kernel: [ 0.443014] iommu: Adding device 54500000.tsec to group 18
Nov 4 19:13:06 bionic kernel: [ 0.443202] iommu: Adding device 54100000.tsecb to group 19
Nov 4 19:13:06 bionic kernel: [ 0.443402] iommu: Adding device 54480000.nvdec to group 20
Nov 4 19:13:06 bionic kernel: [ 0.443588] iommu: Adding device 54380000.nvjpg to group 21
Nov 4 19:13:06 bionic kernel: [ 0.444642] iommu: Adding device 546c0000.i2c to group 22
Nov 4 19:13:06 bionic kernel: [ 0.444966] iommu: Adding device 57000000.gpu to group 23
Nov 4 19:13:06 bionic kernel: [ 0.445016] platform 57000000.gpu: domain=ffffffc0f94cb3d8 allocates as[0]=ffffffc0f9430318
Nov 4 19:13:06 bionic kernel: [ 0.445101] platform 57000000.gpu: domain=ffffffc0f94cb3d8 allocates as[1]=ffffffc0f9430380
Nov 4 19:13:06 bionic kernel: [ 0.445140] platform 57000000.gpu: domain=ffffffc0f94cb3d8 allocates as[2]=ffffffc0f94303e8
Nov 4 19:13:06 bionic kernel: [ 0.445174] platform 57000000.gpu: domain=ffffffc0f94cb3d8 allocates as[3]=ffffffc0f9430450
Nov 4 19:13:06 bionic kernel: [ 0.446027] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
Nov 4 19:13:06 bionic kernel: [ 0.446037] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
Nov 4 19:13:06 bionic kernel: [ 0.446049] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
Nov 4 19:13:06 bionic kernel: [ 0.446054] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
Nov 4 19:13:06 bionic kernel: [ 0.446058] tegra-pmc: ### PMC reset status reg: 0x3
Nov 4 19:13:06 bionic kernel: [ 0.497244] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Nov 4 19:13:06 bionic kernel: [ 0.497253] tegra-pmc: Clear bootloader IO dpd settings
Nov 4 19:13:06 bionic kernel: [ 0.497275] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
Nov 4 19:13:06 bionic kernel: [ 0.497336] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
Nov 4 19:13:06 bionic kernel: [ 0.497628] iommu: Adding device 70012000.se to group 24
Nov 4 19:13:06 bionic kernel: [ 0.498403] iommu: Adding device 7000c000.i2c to group 25
Nov 4 19:13:06 bionic kernel: [ 0.498657] iommu: Adding device 7000c400.i2c to group 26
Nov 4 19:13:06 bionic kernel: [ 0.498898] iommu: Adding device 7000c500.i2c to group 27
Nov 4 19:13:06 bionic kernel: [ 0.499144] iommu: Adding device 7000c700.i2c to group 28
Nov 4 19:13:06 bionic kernel: [ 0.499404] iommu: Adding device 7000d000.i2c to group 29
Nov 4 19:13:06 bionic kernel: [ 0.499652] iommu: Adding device 7000d100.i2c to group 30
Nov 4 19:13:06 bionic kernel: [ 0.499939] iommu: Adding device sdhci-tegra.0 to group 31
Nov 4 19:13:06 bionic kernel: [ 0.499990] platform sdhci-tegra.0: domain=ffffffc0f959f558 allocates as[0]=ffffffc0f94304b8
Nov 4 19:13:06 bionic kernel: [ 0.500822] iommu: Adding device 700d0000.xudc to group 32
Nov 4 19:13:06 bionic kernel: [ 0.504149] vdd-ac-bat: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.504495] vdd-5v0-sys: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.505448] vdd-5v0-hdmi: supplied by vdd-5v0-sys
Nov 4 19:13:06 bionic kernel: [ 0.505492] vdd-5v0-hdmi: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.505895] vdd-1v8-sys: 1800 mV
Nov 4 19:13:06 bionic kernel: [ 0.506325] vdd-fan: supplied by vdd-5v0-sys
Nov 4 19:13:06 bionic kernel: [ 0.506362] vdd-fan: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.506734] vdd-usb-vbus: supplied by vdd-5v0-sys
Nov 4 19:13:06 bionic kernel: [ 0.506769] vdd-usb-vbus: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.507260] vdd-usb-vbus2: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.529960] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Nov 4 19:13:06 bionic kernel: [ 0.532448] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
Nov 4 19:13:06 bionic kernel: [ 0.534331] GPIO line 151 (camera-control-output-low) hogged as output/low
Nov 4 19:13:06 bionic kernel: [ 0.534351] GPIO line 152 (camera-control-output-low) hogged as output/low
Nov 4 19:13:06 bionic kernel: [ 0.534747] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
Nov 4 19:13:06 bionic kernel: [ 0.542613] eventlib_kernel: keventlib is initialized, test id: 0
Nov 4 19:13:06 bionic kernel: [ 0.542955] SCSI subsystem initialized
Nov 4 19:13:06 bionic kernel: [ 0.543194] libata version 3.00 loaded.
Nov 4 19:13:06 bionic kernel: [ 0.543479] usbcore: registered new interface driver usbfs
Nov 4 19:13:06 bionic kernel: [ 0.543530] usbcore: registered new interface driver hub
Nov 4 19:13:06 bionic kernel: [ 0.543605] usbcore: registered new device driver usb
Nov 4 19:13:06 bionic kernel: [ 0.547313] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
Nov 4 19:13:06 bionic kernel: [ 0.553222] vdd-core: 600 <–> 1162 mV at 1075 mV
Nov 4 19:13:06 bionic kernel: [ 0.554075] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
Nov 4 19:13:06 bionic kernel: [ 0.554291] random: fast init done
Nov 4 19:13:06 bionic kernel: [ 0.557059] vdd-ddr-1v1: 1150 mV
Nov 4 19:13:06 bionic kernel: [ 0.560335] vdd-pre-reg-1v35: 1350 mV
Nov 4 19:13:06 bionic kernel: [ 0.564268] vdd-1v8: 1800 mV
Nov 4 19:13:06 bionic kernel: [ 0.568240] avdd-sys-1v2: 1200 mV
Nov 4 19:13:06 bionic kernel: [ 0.572241] vdd-pex-1v0: 1050 mV
Nov 4 19:13:06 bionic kernel: [ 0.572794] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
Nov 4 19:13:06 bionic kernel: [ 0.573332] max77620-ldo3: at 3100 mV
Nov 4 19:13:06 bionic kernel: [ 0.576247] vdd-rtc: 850 <–> 1100 mV at 1000 mV
Nov 4 19:13:06 bionic kernel: [ 0.576759] max77620-ldo5: at 3100 mV
Nov 4 19:13:06 bionic kernel: [ 0.577257] max77620-ldo6: at 2800 mV
Nov 4 19:13:06 bionic kernel: [ 0.580252] avdd-1v05-pll: 1050 mV
Nov 4 19:13:06 bionic kernel: [ 0.584240] avdd-io-hdmi-dp: 1050 mV
Nov 4 19:13:06 bionic kernel: [ 0.585317] GPIO line 505 (spmic-default-output-high) hogged as output/high
Nov 4 19:13:06 bionic kernel: [ 0.585624] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
Nov 4 19:13:06 bionic kernel: [ 0.586959] max77620 4-003c: max77620 probe successful
Nov 4 19:13:06 bionic kernel: [ 0.589729] media: Linux media interface: v0.10
Nov 4 19:13:06 bionic kernel: [ 0.589789] Linux video capture interface: v2.00
Nov 4 19:13:06 bionic kernel: [ 0.590695] pps_core: LinuxPPS API ver. 1 registered
Nov 4 19:13:06 bionic kernel: [ 0.590701] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Nov 4 19:13:06 bionic kernel: [ 0.590727] PTP clock support registered
Nov 4 19:13:06 bionic kernel: [ 0.594227] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
Nov 4 19:13:06 bionic kernel: [ 0.600467] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
Nov 4 19:13:06 bionic kernel: [ 0.601456] Advanced Linux Sound Architecture Driver Initialized.
Nov 4 19:13:06 bionic kernel: [ 0.602066] Bluetooth: Core ver 2.22
Nov 4 19:13:06 bionic kernel: [ 0.602109] NET: Registered protocol family 31
Nov 4 19:13:06 bionic kernel: [ 0.602114] Bluetooth: HCI device and connection manager initialized
Nov 4 19:13:06 bionic kernel: [ 0.602128] Bluetooth: HCI socket layer initialized
Nov 4 19:13:06 bionic kernel: [ 0.602136] Bluetooth: L2CAP socket layer initialized
Nov 4 19:13:06 bionic kernel: [ 0.602161] Bluetooth: SCO socket layer initialized
Nov 4 19:13:06 bionic kernel: [ 0.603870] tegra210_dvfs: no clock found for sdmmc2_ddr
Nov 4 19:13:06 bionic kernel: [ 0.603886] tegra210_dvfs: no clock found for sdmmc4_ddr
Nov 4 19:13:06 bionic kernel: [ 0.603932] tegra210_dvfs: no clock found for sdmmc1_ddr
Nov 4 19:13:06 bionic kernel: [ 0.603946] tegra210_dvfs: no clock found for sdmmc3_ddr
Nov 4 19:13:06 bionic kernel: [ 0.607141] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
Nov 4 19:13:06 bionic kernel: [ 0.608242] vdd-3v3-sys: supplied by vdd-5v0-sys
Nov 4 19:13:06 bionic kernel: [ 0.608303] vdd-3v3-sys: 3300 mV
Nov 4 19:13:06 bionic kernel: [ 0.608577] vdd-1v8-sys: supplied by vdd-3v3-sys
Nov 4 19:13:06 bionic kernel: [ 0.613065] vdd-usb-vbus2: supplied by vdd-3v3-sys
Nov 4 19:13:06 bionic kernel: [ 0.613578] vdd-3v3-sd: supplied by vdd-3v3-sys
Nov 4 19:13:06 bionic kernel: [ 0.613617] vdd-3v3-sd: 3300 mV
Nov 4 19:13:06 bionic kernel: [ 0.614366] avdd-io-edp-1v05: supplied by avdd-1v05-pll
Nov 4 19:13:06 bionic kernel: [ 0.614412] avdd-io-edp-1v05: 1050 mV
Nov 4 19:13:06 bionic kernel: [ 0.614879] vdd-usb-hub-en: supplied by vdd-1v8-sys
Nov 4 19:13:06 bionic kernel: [ 0.614935] vdd-usb-hub-en: 5000 mV
Nov 4 19:13:06 bionic kernel: [ 0.616291] camchar: rtcpu character device driver loaded
Nov 4 19:13:06 bionic kernel: [ 0.617055] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
Nov 4 19:13:06 bionic kernel: [ 0.618370] clocksource: Switched to clocksource arch_sys_counter
Nov 4 19:13:06 bionic kernel: [ 0.658270] VFS: Disk quotas dquot_6.6.0
Nov 4 19:13:06 bionic kernel: [ 0.658444] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.658938] nvmap_heap_init: nvmap_heap_init: created heap block cache
Nov 4 19:13:06 bionic kernel: [ 0.659332] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
Nov 4 19:13:06 bionic kernel: [ 0.659351] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
Nov 4 19:13:06 bionic kernel: [ 0.659552] cma: enabled page replacement for spfn=d7000, epfn=f0000
Nov 4 19:13:06 bionic kernel: [ 0.659557] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
Nov 4 19:13:06 bionic kernel: [ 0.659568] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
Nov 4 19:13:06 bionic kernel: [ 0.659597] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
Nov 4 19:13:06 bionic kernel: [ 0.659602] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
Nov 4 19:13:06 bionic kernel: [ 0.659615] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
Nov 4 19:13:06 bionic kernel: [ 0.659625] nvmap_page_pool_init: Total RAM pages: 1011344
Nov 4 19:13:06 bionic kernel: [ 0.659630] nvmap_page_pool_init: nvmap page pool size: 126418 pages (493 MB)
Nov 4 19:13:06 bionic kernel: [ 0.659716] nvmap_background_zero_thread: PP zeroing thread starting.
Nov 4 19:13:06 bionic kernel: [ 0.660116] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
Nov 4 19:13:06 bionic kernel: [ 0.660847] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
Nov 4 19:13:06 bionic kernel: [ 0.670537] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
Nov 4 19:13:06 bionic kernel: [ 0.670942] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
Nov 4 19:13:06 bionic kernel: [ 0.671175] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Nov 4 19:13:06 bionic kernel: [ 0.671369] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Nov 4 19:13:06 bionic kernel: [ 0.671549] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
Nov 4 19:13:06 bionic kernel: [ 0.671823] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
Nov 4 19:13:06 bionic kernel: [ 0.671827] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
Nov 4 19:13:06 bionic kernel: [ 0.672259] NET: Registered protocol family 2
Nov 4 19:13:06 bionic kernel: [ 0.673234] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.673443] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.673940] TCP: Hash tables configured (established 32768 bind 32768)
Nov 4 19:13:06 bionic kernel: [ 0.674087] UDP hash table entries: 2048 (order: 4, 65536 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.674167] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
Nov 4 19:13:06 bionic kernel: [ 0.674686] NET: Registered protocol family 1
Nov 4 19:13:06 bionic kernel: [ 0.675395] RPC: Registered named UNIX socket transport module.
Nov 4 19:13:06 bionic kernel: [ 0.675399] RPC: Registered udp transport module.
Nov 4 19:13:06 bionic kernel: [ 0.675402] RPC: Registered tcp transport module.
Nov 4 19:13:06 bionic kernel: [ 0.675406] RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 4 19:13:06 bionic kernel: [ 0.675420] PCI: CLS 0 bytes, default 64
Nov 4 19:13:06 bionic kernel: [ 0.675654] Trying to unpack rootfs image as initramfs…
Nov 4 19:13:06 bionic kernel: [ 0.909810] Freeing initrd memory: 5432K
Nov 4 19:13:06 bionic kernel: [ 0.919726] host1x 50000000.host1x: initialized
Nov 4 19:13:06 bionic kernel: [ 0.921481] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Nov 4 19:13:06 bionic kernel: [ 0.924768] audit: initializing netlink subsys (disabled)
Nov 4 19:13:06 bionic kernel: [ 0.924860] audit: type=2000 audit(0.771:1): initialized
Nov 4 19:13:06 bionic kernel: [ 0.925584] workingset: timestamp_bits=46 max_order=20 bucket_order=0
Nov 4 19:13:06 bionic kernel: [ 0.935688] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Nov 4 19:13:06 bionic kernel: [ 0.937179] ntfs: driver 2.1.32 [Flags: R/W].
Nov 4 19:13:06 bionic kernel: [ 0.938004] 9p: Installing v9fs 9p2000 file system support
Nov 4 19:13:06 bionic kernel: [ 0.941305] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
Nov 4 19:13:06 bionic kernel: [ 0.941452] io scheduler noop registered
Nov 4 19:13:06 bionic kernel: [ 0.941736] io scheduler cfq registered (default)
Nov 4 19:13:06 bionic kernel: [ 0.944364] gic 702f9000.agic: GIC IRQ controller registered
Nov 4 19:13:06 bionic kernel: [ 0.947338] iommu: Adding device 702ef000.adsp to group 33
Nov 4 19:13:06 bionic kernel: [ 0.954385] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
Nov 4 19:13:06 bionic kernel: [ 0.954544] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
Nov 4 19:13:06 bionic kernel: [ 0.955138] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x81e8412
Nov 4 19:13:06 bionic kernel: [ 0.955147] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
Nov 4 19:13:06 bionic kernel: [ 0.956700] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
Nov 4 19:13:06 bionic kernel: [ 0.956805] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
Nov 4 19:13:06 bionic kernel: [ 0.956900] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
Nov 4 19:13:06 bionic kernel: [ 0.957088] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
Nov 4 19:13:06 bionic kernel: [ 0.957182] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
Nov 4 19:13:06 bionic kernel: [ 0.957268] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
Nov 4 19:13:06 bionic kernel: [ 0.957359] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
Nov 4 19:13:06 bionic kernel: [ 0.957451] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
Nov 4 19:13:06 bionic kernel: [ 0.957538] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
Nov 4 19:13:06 bionic kernel: [ 0.957623] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
Nov 4 19:13:06 bionic kernel: [ 0.963098] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
Nov 4 19:13:06 bionic kernel: [ 0.964806] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
Nov 4 19:13:06 bionic kernel: [ 0.966712] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
Nov 4 19:13:06 bionic kernel: [ 0.967977] tegra-pcie 1003000.pcie: PCIE: Enable power rails
Nov 4 19:13:06 bionic kernel: [ 0.968319] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
Nov 4 19:13:06 bionic kernel: [ 0.969474] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Nov 4 19:13:06 bionic kernel: [ 0.969702] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
Nov 4 19:13:06 bionic kernel: [ 0.969939] Adding domain tsec-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 0.972124] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
Nov 4 19:13:06 bionic kernel: [ 0.973002] tsec 54500000.tsec: initialized
Nov 4 19:13:06 bionic kernel: [ 0.974562] tsec 54100000.tsecb: initialized
Nov 4 19:13:06 bionic kernel: [ 0.975258] Adding domain nvdec-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 0.978698] nvdec 54480000.nvdec: initialized
Nov 4 19:13:06 bionic kernel: [ 0.979764] Adding domain vic03-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 0.979941] Adding domain msenc-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 0.980098] Adding domain nvjpg-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 0.984230] falcon 54340000.vic: initialized
Nov 4 19:13:06 bionic kernel: [ 0.985458] falcon 544c0000.nvenc: initialized
Nov 4 19:13:06 bionic kernel: [ 0.986803] falcon 54380000.nvjpg: initialized
Nov 4 19:13:06 bionic kernel: [ 0.991189] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
Nov 4 19:13:06 bionic kernel: [ 0.991312] display board info: id 0x0, fab 0x0
Nov 4 19:13:06 bionic kernel: [ 0.991372] generic_infoframe_type: 0x87
Nov 4 19:13:06 bionic kernel: [ 0.991500] tegradc tegradc.0: DT parsed successfully
Nov 4 19:13:06 bionic kernel: [ 0.991548] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
Nov 4 19:13:06 bionic kernel: [ 0.994982] tegradc tegradc.0: probed
Nov 4 19:13:06 bionic kernel: [ 0.999312] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
Nov 4 19:13:06 bionic kernel: [ 1.003584] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
Nov 4 19:13:06 bionic kernel: [ 1.004380] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
Nov 4 19:13:06 bionic kernel: [ 1.004754] kfuse 7000fc00.kfuse: initialized
Nov 4 19:13:06 bionic kernel: [ 1.006092] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
Nov 4 19:13:06 bionic kernel: [ 1.007221] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
Nov 4 19:13:06 bionic kernel: [ 1.008634] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
Nov 4 19:13:06 bionic kernel: [ 1.008647] vdd-cpu: 708 <–> 1322 mV at 708 mV
Nov 4 19:13:06 bionic kernel: [ 1.009115] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
Nov 4 19:13:06 bionic kernel: [ 1.010291] vdd-gpu: applied init 1000000uV constraint
Nov 4 19:13:06 bionic kernel: [ 1.010297] vdd-gpu: 708 <–> 1323 mV at 997 mV
Nov 4 19:13:06 bionic kernel: [ 1.010707] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
Nov 4 19:13:06 bionic kernel: [ 1.015079] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Nov 4 19:13:06 bionic kernel: [ 1.015184] No Device Node present for smmu client: serial8250 !!
Nov 4 19:13:06 bionic kernel: [ 1.015194] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
Nov 4 19:13:06 bionic kernel: [ 1.015232] iommu: Adding device serial8250 to group 35
Nov 4 19:13:06 bionic kernel: [ 1.017518] console [ttyS0] disabled
Nov 4 19:13:06 bionic kernel: [ 1.017593] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
Nov 4 19:13:06 bionic kernel: [ 1.017685] console [ttyS0] enabled
Nov 4 19:13:06 bionic kernel: [ 1.018577] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
Nov 4 19:13:06 bionic kernel: [ 1.018946] serial-tegra 70006200.serial: RX in PIO mode
Nov 4 19:13:06 bionic kernel: [ 1.019060] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
Nov 4 19:13:06 bionic kernel: [ 1.020280] [drm] Initialized
Nov 4 19:13:06 bionic kernel: [ 1.020353] Console: switching to colour frame buffer device 80x30
Nov 4 19:13:06 bionic kernel: [ 1.020390] tegradc tegradc.0: fb registered
Nov 4 19:13:06 bionic kernel: [ 1.021820] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
Nov 4 19:13:06 bionic kernel: [ 1.021910] tegradc tegradc.1: No lt-data, using default setting
Nov 4 19:13:06 bionic kernel: [ 1.021944] tegradc tegradc.1: No hpd-gpio in DT
Nov 4 19:13:06 bionic kernel: [ 1.021975] tegradc tegradc.1: DT parsed successfully
Nov 4 19:13:06 bionic kernel: [ 1.022025] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
Nov 4 19:13:06 bionic kernel: [ 1.023749] tegradc tegradc.1: dpd enable lookup fail:-19
Nov 4 19:13:06 bionic kernel: [ 1.032971] brd: module loaded
Nov 4 19:13:06 bionic kernel: [ 1.535056] Host read timeout at address 545c00c4
Nov 4 19:13:06 bionic kernel: [ 1.537189] tegradc tegradc.1: probed
Nov 4 19:13:06 bionic kernel: [ 1.544716] loop: module loaded
Nov 4 19:13:06 bionic kernel: [ 1.544839] tegra_profiler: version: 1.134, samples/io: 47/26
Nov 4 19:13:06 bionic kernel: [ 1.544998] tegra_profiler: auth: init
Nov 4 19:13:06 bionic kernel: [ 1.547328] THERMAL EST: found 2 subdevs
Nov 4 19:13:06 bionic kernel: [ 1.547348] THERMAL EST num_resources: 0
Nov 4 19:13:06 bionic kernel: [ 1.547355] [THERMAL EST subdev 0]
Nov 4 19:13:06 bionic kernel: [ 1.547365] [THERMAL EST subdev 1]
Nov 4 19:13:06 bionic kernel: [ 1.548013] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
Nov 4 19:13:06 bionic kernel: [ 1.548018] THERMAL EST: thz register success.
Nov 4 19:13:06 bionic kernel: [ 1.552264] THERMAL EST: end of probe, return err: 0
Nov 4 19:13:06 bionic kernel: [ 1.554255] hisi_sas: driver version v1.6
Nov 4 19:13:06 bionic kernel: [ 1.558538] tegra-qspi 70410000.spi: Prod settings list not found
Nov 4 19:13:06 bionic kernel: [ 1.559791] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
Nov 4 19:13:06 bionic kernel: [ 1.559801] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
Nov 4 19:13:06 bionic kernel: [ 1.560798] tegradc tegradc.1: fb registered
Nov 4 19:13:06 bionic kernel: [ 1.564009] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
Nov 4 19:13:06 bionic kernel: [ 1.564017] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
Nov 4 19:13:06 bionic kernel: [ 1.564026] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
Nov 4 19:13:06 bionic kernel: [ 1.564042] tegradc tegradc.1: blank - powerdown
Nov 4 19:13:06 bionic kernel: [ 1.564064] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
Nov 4 19:13:06 bionic kernel: [ 1.564069] Extcon DP: HPD disabled
Nov 4 19:13:06 bionic kernel: [ 1.564073] hpd: hpd_switch 0
Nov 4 19:13:06 bionic kernel: [ 1.564077] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
Nov 4 19:13:06 bionic kernel: [ 1.564087] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
Nov 4 19:13:06 bionic kernel: [ 1.564094] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
Nov 4 19:13:06 bionic kernel: [ 1.566858] libphy: Fixed MDIO Bus: probed
Nov 4 19:13:06 bionic kernel: [ 1.567541] tun: Universal TUN/TAP device driver, 1.6
Nov 4 19:13:06 bionic kernel: [ 1.567545] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
Nov 4 19:13:06 bionic kernel: [ 1.568482] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
Nov 4 19:13:06 bionic kernel: [ 1.568488] e1000e: Copyright© 1999 - 2015 Intel Corporation.
Nov 4 19:13:06 bionic kernel: [ 1.568544] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
Nov 4 19:13:06 bionic kernel: [ 1.568549] igb: Copyright © 2007-2014 Intel Corporation.
Nov 4 19:13:06 bionic kernel: [ 1.568596] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
Nov 4 19:13:06 bionic kernel: [ 1.568600] igbvf: Copyright © 2009 - 2012 Intel Corporation.
Nov 4 19:13:06 bionic kernel: [ 1.568646] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
Nov 4 19:13:06 bionic kernel: [ 1.568651] Copyright© 1999 - 2017 Intel Corporation.
Nov 4 19:13:06 bionic kernel: [ 1.573651] PPP generic driver version 2.4.2
Nov 4 19:13:06 bionic kernel: [ 1.573846] PPP BSD Compression module registered
Nov 4 19:13:06 bionic kernel: [ 1.573851] PPP Deflate Compression module registered
Nov 4 19:13:06 bionic kernel: [ 1.573892] PPP MPPE Compression module registered
Nov 4 19:13:06 bionic kernel: [ 1.573901] NET: Registered protocol family 24
Nov 4 19:13:06 bionic kernel: [ 1.573969] usbcore: registered new interface driver r8152
Nov 4 19:13:06 bionic kernel: [ 1.574018] usbcore: registered new interface driver asix
Nov 4 19:13:06 bionic kernel: [ 1.574065] usbcore: registered new interface driver ax88179_178a
Nov 4 19:13:06 bionic kernel: [ 1.574106] usbcore: registered new interface driver cdc_ether
Nov 4 19:13:06 bionic kernel: [ 1.574143] usbcore: registered new interface driver net1080
Nov 4 19:13:06 bionic kernel: [ 1.574181] usbcore: registered new interface driver cdc_subset
Nov 4 19:13:06 bionic kernel: [ 1.574223] usbcore: registered new interface driver zaurus
Nov 4 19:13:06 bionic kernel: [ 1.574280] usbcore: registered new interface driver cdc_ncm
Nov 4 19:13:06 bionic kernel: [ 1.574486] VFIO - User Level meta-driver version: 0.3
Nov 4 19:13:06 bionic kernel: [ 1.575771] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Nov 4 19:13:06 bionic kernel: [ 1.575808] ehci-pci: EHCI PCI platform driver
Nov 4 19:13:06 bionic kernel: [ 1.575851] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Nov 4 19:13:06 bionic kernel: [ 1.575866] ohci-pci: OHCI PCI platform driver
Nov 4 19:13:06 bionic kernel: [ 1.575907] ohci-platform: OHCI generic platform driver
Nov 4 19:13:06 bionic kernel: [ 1.578701] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
Nov 4 19:13:06 bionic kernel: [ 1.579312] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
Nov 4 19:13:06 bionic kernel: [ 1.580495] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f919c000 id
Nov 4 19:13:06 bionic kernel: [ 1.581627] usbcore: registered new interface driver uas
Nov 4 19:13:06 bionic kernel: [ 1.581697] usbcore: registered new interface driver usb-storage
Nov 4 19:13:06 bionic kernel: [ 1.581798] usbcore: registered new interface driver usbserial
Nov 4 19:13:06 bionic kernel: [ 1.584885] tegra-xudc-new 700d0000.xudc: device count: 1
Nov 4 19:13:06 bionic kernel: [ 1.586863] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
Nov 4 19:13:06 bionic kernel: [ 1.586880] tegra-xudc-new 700d0000.xudc: vbus state: 0
Nov 4 19:13:06 bionic kernel: [ 1.587598] tegra-xudc-new 700d0000.xudc: entering ELPG
Nov 4 19:13:06 bionic kernel: [ 1.587926] tegra-xudc-new 700d0000.xudc: entering ELPG done
Nov 4 19:13:06 bionic kernel: [ 1.587961] mousedev: PS/2 mouse device common for all mice
Nov 4 19:13:06 bionic kernel: [ 1.588054] usbcore: registered new interface driver xpad
Nov 4 19:13:06 bionic kernel: [ 1.588332] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
Nov 4 19:13:06 bionic kernel: [ 1.588406] tegra-xusb 70090000.xusb: xHCI Host Controller
Nov 4 19:13:06 bionic kernel: [ 1.588433] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
Nov 4 19:13:06 bionic kernel: [ 1.589357] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
Nov 4 19:13:06 bionic kernel: [ 1.589431] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
Nov 4 19:13:06 bionic kernel: [ 1.590599] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 4 19:13:06 bionic kernel: [ 1.590607] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 4 19:13:06 bionic kernel: [ 1.590623] usb usb1: Product: xHCI Host Controller
Nov 4 19:13:06 bionic kernel: [ 1.590628] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
Nov 4 19:13:06 bionic kernel: [ 1.590632] usb usb1: SerialNumber: 70090000.xusb
Nov 4 19:13:06 bionic kernel: [ 1.591200] hub 1-0:1.0: USB hub found
Nov 4 19:13:06 bionic kernel: [ 1.591266] hub 1-0:1.0: 5 ports detected
Nov 4 19:13:06 bionic kernel: [ 1.591947] tegra-xusb 70090000.xusb: xHCI Host Controller
Nov 4 19:13:06 bionic kernel: [ 1.591962] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
Nov 4 19:13:06 bionic kernel: [ 1.592104] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
Nov 4 19:13:06 bionic kernel: [ 1.592191] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Nov 4 19:13:06 bionic kernel: [ 1.592197] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 4 19:13:06 bionic kernel: [ 1.592201] usb usb2: Product: xHCI Host Controller
Nov 4 19:13:06 bionic kernel: [ 1.592206] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
Nov 4 19:13:06 bionic kernel: [ 1.592211] usb usb2: SerialNumber: 70090000.xusb
Nov 4 19:13:06 bionic kernel: [ 1.592659] hub 2-0:1.0: USB hub found
Nov 4 19:13:06 bionic kernel: [ 1.592690] hub 2-0:1.0: 4 ports detected
Nov 4 19:13:06 bionic kernel: [ 1.670478] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Nov 4 19:13:06 bionic kernel: [ 1.672995] rtc rtc1: alarm rtc device
Nov 4 19:13:06 bionic kernel: [ 1.673013] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
Nov 4 19:13:06 bionic kernel: [ 1.673045] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
Nov 4 19:13:06 bionic kernel: [ 1.673698] i2c /dev entries driver
Nov 4 19:13:06 bionic kernel: [ 1.675599] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
Nov 4 19:13:06 bionic kernel: [ 1.694484] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
Nov 4 19:13:06 bionic kernel: [ 1.698944] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
Nov 4 19:13:06 bionic kernel: [ 1.699020] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
Nov 4 19:13:06 bionic kernel: [ 1.706575] imx219 6-0010: board setup failed
Nov 4 19:13:06 bionic kernel: [ 1.711044] imx219: probe of 6-0010 failed with error -121
Nov 4 19:13:06 bionic kernel: [ 1.712042] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
Nov 4 19:13:06 bionic kernel: [ 1.714765] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
Nov 4 19:13:06 bionic kernel: [ 1.714774] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
Nov 4 19:13:06 bionic kernel: [ 1.715223] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.715241] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
Nov 4 19:13:06 bionic kernel: [ 1.715251] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
Nov 4 19:13:06 bionic kernel: [ 1.715395] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.715406] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
Nov 4 19:13:06 bionic kernel: [ 1.715413] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
Nov 4 19:13:06 bionic kernel: [ 1.715562] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.715573] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
Nov 4 19:13:06 bionic kernel: [ 1.715579] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
Nov 4 19:13:06 bionic kernel: [ 1.715755] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
Nov 4 19:13:06 bionic kernel: [ 1.716565] tegra_aotag tegra-aotag: Registering sensor 0
Nov 4 19:13:06 bionic kernel: [ 1.716626] tegra_aotag tegra-aotag: Invalid temp readout
Nov 4 19:13:06 bionic kernel: [ 1.716653] tegra_aotag tegra-aotag: Invalid temp readout
Nov 4 19:13:06 bionic kernel: [ 1.716672] tegra_aotag tegra-aotag: Bound to TZ : ID 0
Nov 4 19:13:06 bionic kernel: [ 1.716681] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
Nov 4 19:13:06 bionic kernel: [ 1.717589] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.717608] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
Nov 4 19:13:06 bionic kernel: [ 1.717799] tegra_aotag tegra-aotag: Invalid temp readout
Nov 4 19:13:06 bionic kernel: [ 1.717831] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
Nov 4 19:13:06 bionic kernel: [ 1.718251] parse_throttle_dt_data: Num cap clks = 6
Nov 4 19:13:06 bionic kernel: [ 1.718258] parse_throttle_dt_data: clk=cclk_g type=2
Nov 4 19:13:06 bionic kernel: [ 1.718272] parse_throttle_dt_data: clk=gpu type=4
Nov 4 19:13:06 bionic kernel: [ 1.718298] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
Nov 4 19:13:06 bionic kernel: [ 1.718319] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
Nov 4 19:13:06 bionic kernel: [ 1.718341] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
Nov 4 19:13:06 bionic kernel: [ 1.718346] parse_throttle_dt_data: clk=emc type=3
Nov 4 19:13:06 bionic kernel: [ 1.718780] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.718881] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.719027] tegra_throttle_probe: probe successful. #cdevs=4
Nov 4 19:13:06 bionic kernel: [ 1.719779] FAN dev name: pwm-fan
Nov 4 19:13:06 bionic kernel: [ 1.719835] FAN:gpio request success.
Nov 4 19:13:06 bionic kernel: [ 1.719900] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
Nov 4 19:13:06 bionic kernel: [ 1.720210] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
Nov 4 19:13:06 bionic kernel: [ 1.720420] pwm_fan_driver pwm-fan: fan tach request irq success
Nov 4 19:13:06 bionic kernel: [ 1.720430] pwm_fan_driver pwm-fan: tach period: 1000
Nov 4 19:13:06 bionic kernel: [ 1.720525] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
Nov 4 19:13:06 bionic kernel: [ 1.720530] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
Nov 4 19:13:06 bionic kernel: [ 1.720536] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
Nov 4 19:13:06 bionic kernel: [ 1.720541] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
Nov 4 19:13:06 bionic kernel: [ 1.720547] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
Nov 4 19:13:06 bionic kernel: [ 1.720552] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
Nov 4 19:13:06 bionic kernel: [ 1.720557] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
Nov 4 19:13:06 bionic kernel: [ 1.720562] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
Nov 4 19:13:06 bionic kernel: [ 1.720567] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
Nov 4 19:13:06 bionic kernel: [ 1.720572] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
Nov 4 19:13:06 bionic kernel: [ 1.721234] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
Nov 4 19:13:06 bionic kernel: [ 1.721623] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
Nov 4 19:13:06 bionic kernel: [ 1.722565] device-mapper: uevent: version 1.0.3
Nov 4 19:13:06 bionic kernel: [ 1.723034] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Nov 4 19:13:06 bionic kernel: [ 1.728640] tegra210-cpufreq cpufreq: probe()…completed
Nov 4 19:13:06 bionic kernel: [ 1.729331] sdhci: Secure Digital Host Controller Interface driver
Nov 4 19:13:06 bionic kernel: [ 1.729334] sdhci: Copyright© Pierre Ossman
Nov 4 19:13:06 bionic kernel: [ 1.729336] sdhci-pltfm: SDHCI platform and OF driver helper
Nov 4 19:13:06 bionic kernel: [ 1.729812] sdhci-tegra sdhci-tegra.0: Got CD GPIO
Nov 4 19:13:06 bionic kernel: [ 1.730170] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
Nov 4 19:13:06 bionic kernel: [ 1.730297] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
Nov 4 19:13:06 bionic kernel: [ 1.734727] tegra-se 70012000.se: tegra_se_probe: complete
Nov 4 19:13:06 bionic kernel: [ 1.735235] hidraw: raw HID events driver © Jiri Kosina
Nov 4 19:13:06 bionic kernel: [ 1.736437] usbcore: registered new interface driver usbhid
Nov 4 19:13:06 bionic kernel: [ 1.736440] usbhid: USB HID core driver
Nov 4 19:13:06 bionic kernel: [ 1.738563] tegra21x_actmon 6000c800.actmon: in actmon_register()…
Nov 4 19:13:06 bionic kernel: [ 1.738737] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
Nov 4 19:13:06 bionic kernel: [ 1.740406] nvpmodel: initialized successfully
Nov 4 19:13:06 bionic kernel: [ 1.741525] usbcore: registered new interface driver snd-usb-audio
Nov 4 19:13:06 bionic kernel: [ 1.741584] No Device Node present for smmu client: snd-soc-dummy !!
Nov 4 19:13:06 bionic kernel: [ 1.741590] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
Nov 4 19:13:06 bionic kernel: [ 1.741608] iommu: Adding device snd-soc-dummy to group 36
Nov 4 19:13:06 bionic kernel: [ 1.747474] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
Nov 4 19:13:06 bionic kernel: [ 1.767276] OPE platform probe
Nov 4 19:13:06 bionic kernel: [ 1.767365] OPE platform probe successful
Nov 4 19:13:06 bionic kernel: [ 1.767391] OPE platform probe
Nov 4 19:13:06 bionic kernel: [ 1.767472] OPE platform probe successful
Nov 4 19:13:06 bionic kernel: [ 1.778493] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
Nov 4 19:13:06 bionic kernel: [ 1.795343] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.795483] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.795613] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.795750] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.795880] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.796009] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.796139] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.796269] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.796401] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.796533] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
Nov 4 19:13:06 bionic kernel: [ 1.810711] u32 classifier
Nov 4 19:13:06 bionic kernel: [ 1.810715] Actions configured
Nov 4 19:13:06 bionic kernel: [ 1.810788] Initializing XFRM netlink socket
Nov 4 19:13:06 bionic kernel: [ 1.811521] NET: Registered protocol family 10
Nov 4 19:13:06 bionic kernel: [ 1.812245] NET: Registered protocol family 17
Nov 4 19:13:06 bionic kernel: [ 1.812256] NET: Registered protocol family 15
Nov 4 19:13:06 bionic kernel: [ 1.812335] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Nov 4 19:13:06 bionic kernel: [ 1.812395] Bluetooth: RFCOMM socket layer initialized
Nov 4 19:13:06 bionic kernel: [ 1.812405] Bluetooth: RFCOMM ver 1.11
Nov 4 19:13:06 bionic kernel: [ 1.812419] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Nov 4 19:13:06 bionic kernel: [ 1.812424] Bluetooth: HIDP socket layer initialized
Nov 4 19:13:06 bionic kernel: [ 1.812442] 9pnet: Installing 9P2000 support
Nov 4 19:13:06 bionic kernel: [ 1.812478] Key type dns_resolver registered
Nov 4 19:13:06 bionic kernel: [ 1.812857] Registered cp15_barrier emulation handler
Nov 4 19:13:06 bionic kernel: [ 1.812864] Registered setend emulation handler
Nov 4 19:13:06 bionic kernel: [ 1.813922] registered taskstats version 1
Nov 4 19:13:06 bionic kernel: [ 1.814476] Adding domain ve2-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 1.814730] Adding domain ve-pd to PM domain host1x-pd
Nov 4 19:13:06 bionic kernel: [ 1.816783] isp 54600000.isp: initialized
Nov 4 19:13:06 bionic kernel: [ 1.817750] isp 54680000.isp: initialized
Nov 4 19:13:06 bionic kernel: [ 1.829286] last reset is due to software reset
Nov 4 19:13:06 bionic kernel: [ 1.829290] KERNEL: PMC reset status reg: 0x3
Nov 4 19:13:06 bionic kernel: [ 1.829402] BL: PMC reset status reg: 0x3
Nov 4 19:13:06 bionic kernel: [ 1.829405] BL: PMIC poweroff Event Recorder: 0x0
Nov 4 19:13:06 bionic kernel: [ 1.831015] clk_cbus_recalc_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831021] clk_cbus_round_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831024] clk_cbus_round_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831031] clk_cbus_recalc_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831129] clk_cbus_recalc_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831133] clk_cbus_round_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831135] clk_cbus_round_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831139] clk_cbus_recalc_rate: no gbus parent
Nov 4 19:13:06 bionic kernel: [ 1.831827] tegra_dvfs: GPU-cap: registered
Nov 4 19:13:06 bionic kernel: [ 1.831881] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
Nov 4 19:13:06 bionic kernel: [ 1.831884] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
Nov 4 19:13:06 bionic kernel: [ 1.831886] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
Nov 4 19:13:06 bionic kernel: [ 1.833280] tegra_dvfs: vdd-gpu-vts: registered
Nov 4 19:13:06 bionic kernel: [ 1.833962] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
Nov 4 19:13:06 bionic kernel: [ 1.834538] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
Nov 4 19:13:06 bionic kernel: [ 1.835099] input: gpio-keys as /devices/gpio-keys/input/input1
Nov 4 19:13:06 bionic kernel: [ 1.868093] tegra_rtc 7000e000.rtc: setting system clock to 2019-11-05 00:13:04 UTC (1572912784)
Nov 4 19:13:06 bionic kernel: [ 1.869118] vi 54080000.vi: vi_probe: ++
Nov 4 19:13:06 bionic kernel: [ 1.873428] vi 54080000.vi: initialized
Nov 4 19:13:06 bionic kernel: [ 1.876617] vi 54080000.vi: subdev nvcsi–1 bound
Nov 4 19:13:06 bionic kernel: [ 1.878086] Disable partitions left on by BL
Nov 4 19:13:06 bionic kernel: [ 1.878090] disb
Nov 4 19:13:06 bionic kernel: [ 1.878134] bwmgr: missing cdev-type property
Nov 4 19:13:06 bionic kernel: [ 1.878232] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
Nov 4 19:13:06 bionic kernel: [ 1.878238] DRAM derating cdev registered.
Nov 4 19:13:06 bionic kernel: [ 1.879233] vdd-fan: disabling
Nov 4 19:13:06 bionic kernel: [ 1.879237] vdd-usb-vbus: disabling
Nov 4 19:13:06 bionic kernel: [ 1.879240] vdd-usb-vbus2: disabling
Nov 4 19:13:06 bionic kernel: [ 1.879249] avdd-io-edp-1v05: disabling
Nov 4 19:13:06 bionic kernel: [ 1.879347] ALSA device list:
Nov 4 19:13:06 bionic kernel: [ 1.879350] #0: tegra-hda at 0x70038000 irq 83
Nov 4 19:13:06 bionic kernel: [ 1.879352] #1: tegra-snd-t210ref-mobile-rt565x
Nov 4 19:13:06 bionic kernel: [ 1.882514] Freeing unused kernel memory: 8576K
Nov 4 19:13:06 bionic kernel: [ 1.904406] tegra-pcie 1003000.pcie: link 0 down, retrying
Nov 4 19:13:06 bionic kernel: [ 1.918383] usb 1-2: new high-speed USB device number 2 using tegra-xusb
Nov 4 19:13:06 bionic kernel: [ 1.953485] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
Nov 4 19:13:06 bionic kernel: [ 1.953490] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 4 19:13:06 bionic kernel: [ 1.953493] usb 1-2: Product: 4-Port USB 2.1 Hub
Nov 4 19:13:06 bionic kernel: [ 1.953496] usb 1-2: Manufacturer: Generic
Nov 4 19:13:06 bionic kernel: [ 1.954954] hub 1-2:1.0: USB hub found
Nov 4 19:13:06 bionic kernel: [ 1.956004] hub 1-2:1.0: 4 ports detected
Nov 4 19:13:06 bionic kernel: [ 1.975906] mmc0: Applying tuning correction
Nov 4 19:13:06 bionic kernel: [ 1.975921] mmc0: Tap value after applying correction 63
Nov 4 19:13:06 bionic kernel: [ 1.975939] mmc0: hw tuning done …
Nov 4 19:13:06 bionic kernel: [ 1.975974] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
Nov 4 19:13:06 bionic kernel: [ 1.980298] mmcblk0: mmc0:59b4 50300 29.9 GiB
Nov 4 19:13:06 bionic kernel: [ 1.983865] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
Nov 4 19:13:06 bionic kernel: [ 2.148348] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Nov 4 19:13:06 bionic kernel: [ 2.254384] usb 1-2.1: new full-speed USB device number 3 using tegra-xusb
Nov 4 19:13:06 bionic kernel: [ 2.280056] usb 1-2.1: New USB device found, idVendor=046d, idProduct=c52b
Nov 4 19:13:06 bionic kernel: [ 2.280062] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 4 19:13:06 bionic kernel: [ 2.280067] usb 1-2.1: Product: USB Receiver
Nov 4 19:13:06 bionic kernel: [ 2.280070] usb 1-2.1: Manufacturer: Logitech
Nov 4 19:13:06 bionic kernel: [ 2.308393] tegra-pcie 1003000.pcie: link 0 down, retrying
Nov 4 19:13:06 bionic kernel: [ 2.374398] usb 1-2.2: new full-speed USB device number 4 using tegra-xusb
Nov 4 19:13:06 bionic kernel: [ 2.384315] ip_tables: © 2000-2006 Netfilter Core Team
Nov 4 19:13:06 bionic kernel: [ 2.396244] cgroup: cgroup2: unknown option “nsdelegate”
Nov 4 19:13:06 bionic kernel: [ 2.404447] usb 1-2.2: New USB device found, idVendor=0403, idProduct=fc0d
Nov 4 19:13:06 bionic kernel: [ 2.404452] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 4 19:13:06 bionic kernel: [ 2.404455] usb 1-2.2: Product: Crystalfontz CFA635-USB LCD
Nov 4 19:13:06 bionic kernel: [ 2.404459] usb 1-2.2: Manufacturer: Crystalfontz
Nov 4 19:13:06 bionic kernel: [ 2.404462] usb 1-2.2: SerialNumber: CF115854
Nov 4 19:13:06 bionic kernel: [ 2.701922] random: systemd: uninitialized urandom read (16 bytes read)
Nov 4 19:13:06 bionic kernel: [ 2.702152] random: systemd: uninitialized urandom read (16 bytes read)
Nov 4 19:13:06 bionic kernel: [ 2.703909] random: systemd: uninitialized urandom read (16 bytes read)
Nov 4 19:13:06 bionic kernel: [ 2.714705] tegra-pcie 1003000.pcie: link 0 down, retrying
Nov 4 19:13:06 bionic kernel: [ 2.716732] tegra-pcie 1003000.pcie: link 0 down, ignoring
Nov 4 19:13:06 bionic kernel: [ 2.748381] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
Nov 4 19:13:06 bionic kernel: [ 2.821765] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
Nov 4 19:13:06 bionic kernel: [ 2.821773] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
Nov 4 19:13:06 bionic kernel: [ 2.821777] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
Nov 4 19:13:06 bionic kernel: [ 2.821782] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
Nov 4 19:13:06 bionic kernel: [ 2.821786] pci_bus 0000:00: root bus resource [bus 00-ff]
Nov 4 19:13:06 bionic kernel: [ 2.821810] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
Nov 4 19:13:06 bionic kernel: [ 2.821872] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
Nov 4 19:13:06 bionic kernel: [ 2.822032] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Nov 4 19:13:06 bionic kernel: [ 2.822139] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
Nov 4 19:13:06 bionic kernel: [ 2.822163] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
Nov 4 19:13:06 bionic kernel: [ 2.822193] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
Nov 4 19:13:06 bionic kernel: [ 2.822213] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
Nov 4 19:13:06 bionic kernel: [ 2.822345] pci 0000:01:00.0: supports D1 D2
Nov 4 19:13:06 bionic kernel: [ 2.822377] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Nov 4 19:13:06 bionic kernel: [ 2.834476] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Nov 4 19:13:06 bionic kernel: [ 2.834509] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
Nov 4 19:13:06 bionic kernel: [ 2.834513] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
Nov 4 19:13:06 bionic kernel: [ 2.834521] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
Nov 4 19:13:06 bionic kernel: [ 2.834539] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
Nov 4 19:13:06 bionic kernel: [ 2.834556] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
Nov 4 19:13:06 bionic kernel: [ 2.834564] pci 0000:00:02.0: PCI bridge to [bus 01]
Nov 4 19:13:06 bionic kernel: [ 2.834569] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
Nov 4 19:13:06 bionic kernel: [ 2.834574] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
Nov 4 19:13:06 bionic kernel: [ 2.834898] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
Nov 4 19:13:06 bionic kernel: [ 2.834902] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
Nov 4 19:13:06 bionic kernel: [ 2.834908] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
Nov 4 19:13:06 bionic kernel: [ 2.835020] aer 0000:00:02.0:pcie002: service driver aer loaded
Nov 4 19:13:06 bionic kernel: [ 2.835242] r8168 0000:01:00.0: enabling device (0000 -> 0003)
Nov 4 19:13:06 bionic kernel: [ 2.835259] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
Nov 4 19:13:06 bionic kernel: [ 2.849364] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
Nov 4 19:13:06 bionic kernel: [ 2.849452] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:cc:48:49 from device tree
Nov 4 19:13:06 bionic kernel: [ 2.850035] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
Nov 4 19:13:06 bionic kernel: [ 2.850051] r8168 Copyright © 2017 Realtek NIC software team nicfae@realtek.com
Nov 4 19:13:06 bionic kernel: [ 2.850051] This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
Nov 4 19:13:06 bionic kernel: [ 2.850051] This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
Nov 4 19:13:06 bionic kernel: [ 2.867766] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
Nov 4 19:13:06 bionic kernel: [ 2.878851] fuse init (API version 7.26)
Nov 4 19:13:06 bionic kernel: [ 3.840217] using random self ethernet address
Nov 4 19:13:06 bionic kernel: [ 3.844799] using random host ethernet address
Nov 4 19:13:06 bionic kernel: [ 4.111046] random: crng init done
Nov 4 19:13:06 bionic kernel: [ 4.114453] random: 7 urandom warning(s) missed due to ratelimiting
Nov 4 19:13:06 bionic kernel: [ 4.304713] Mass Storage Function, version: 2009/09/11
Nov 4 19:13:06 bionic kernel: [ 4.304720] LUN: removable file: (no medium)
Nov 4 19:13:06 bionic kernel: [ 4.311738] using random self ethernet address
Nov 4 19:13:06 bionic kernel: [ 4.318987] using random host ethernet address
Nov 4 19:13:07 bionic kernel: [ 4.375191] rndis0: HOST MAC 66:55:52:44:47:24
Nov 4 19:13:07 bionic kernel: [ 4.375514] rndis0: MAC 66:55:52:44:47:25
Nov 4 19:13:07 bionic kernel: [ 4.386878] usb0: HOST MAC 66:55:52:44:47:26
Nov 4 19:13:07 bionic kernel: [ 4.386907] usb0: MAC 66:55:52:44:47:27
Nov 4 19:13:07 bionic kernel: [ 4.386927] tegra-xudc-new 700d0000.xudc: exiting ELPG
Nov 4 19:13:07 bionic kernel: [ 4.389155] tegra-xudc-new 700d0000.xudc: exiting ELPG done
Nov 4 19:13:07 bionic kernel: [ 4.389174] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
Nov 4 19:13:07 bionic kernel: [ 4.389207] tegra-xudc-new 700d0000.xudc: entering ELPG
Nov 4 19:13:07 bionic kernel: [ 4.389441] tegra-xudc-new 700d0000.xudc: entering ELPG done
Nov 4 19:13:07 bionic kernel: [ 4.389454] tegra-xudc-new 700d0000.xudc: exiting ELPG
Nov 4 19:13:07 bionic kernel: [ 4.390531] tegra-xudc-new 700d0000.xudc: exiting ELPG done
Nov 4 19:13:07 bionic kernel: [ 4.390551] tegra-xudc-new 700d0000.xudc: entering ELPG
Nov 4 19:13:07 bionic kernel: [ 4.390767] tegra-xudc-new 700d0000.xudc: entering ELPG done
Nov 4 19:13:07 bionic kernel: [ 4.398306] l4tbr0: port 1(rndis0) entered blocking state
Nov 4 19:13:07 bionic kernel: [ 4.398312] l4tbr0: port 1(rndis0) entered disabled state
Nov 4 19:13:07 bionic kernel: [ 4.398574] device rndis0 entered promiscuous mode
Nov 4 19:13:07 bionic kernel: [ 4.404028] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
Nov 4 19:13:07 bionic kernel: [ 4.408170] l4tbr0: port 2(usb0) entered blocking state
Nov 4 19:13:07 bionic kernel: [ 4.408175] l4tbr0: port 2(usb0) entered disabled state
Nov 4 19:13:07 bionic kernel: [ 4.408572] device usb0 entered promiscuous mode
Nov 4 19:13:07 bionic kernel: [ 4.413570] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
Nov 4 19:13:08 bionic kernel: [ 5.410912] blk_update_request: I/O error, dev loop1, sector 0
Nov 4 19:13:08 bionic kernel: [ 5.757126] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
Nov 4 19:13:08 bionic kernel: [ 5.757133] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
Nov 4 19:13:08 bionic kernel: [ 6.083531] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
Nov 4 19:13:08 bionic kernel: [ 6.119074] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
Nov 4 19:13:08 bionic kernel: [ 6.119079] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 4 19:13:08 bionic kernel: [ 6.119082] usb 2-1: Product: 4-Port USB 3.1 Hub
Nov 4 19:13:08 bionic kernel: [ 6.119085] usb 2-1: Manufacturer: Generic
Nov 4 19:13:08 bionic kernel: [ 6.123880] hub 2-1:1.0: USB hub found
Nov 4 19:13:08 bionic kernel: [ 6.125343] hub 2-1:1.0: 4 ports detected
Nov 4 19:13:08 bionic kernel: [ 6.286415] usb 2-1: usb_suspend_both: status 0
Nov 4 19:13:08 bionic kernel: [ 6.286593] usb usb2: usb_suspend_both: status 0
Nov 4 19:13:08 bionic kernel: [ 6.308743] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Nov 4 19:13:08 bionic kernel: [ 6.309827] eth0: 0xffffff800abe7000, 00:04:4b:cc:48:49, IRQ 405
Nov 4 19:13:08 bionic kernel: [ 6.348218] usbcore: registered new interface driver ftdi_sio
Nov 4 19:13:08 bionic kernel: [ 6.348304] usbserial: USB Serial support registered for FTDI USB Serial Device
Nov 4 19:13:08 bionic kernel: [ 6.348460] ftdi_sio 1-2.2:1.0: FTDI USB Serial Device converter detected
Nov 4 19:13:08 bionic kernel: [ 6.348592] usb 1-2.2: Detected FT232RL
Nov 4 19:13:08 bionic kernel: [ 6.360979] usb 1-2.2: FTDI USB Serial Device converter now attached to ttyUSB0
Nov 4 19:13:09 bionic kernel: [ 6.371454] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Nov 4 19:13:09 bionic kernel: [ 6.381152] logitech-djreceiver 0003:046D:C52B.0003: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.1/input2
Nov 4 19:13:09 bionic kernel: [ 6.426042] zram: Added device: zram0
Nov 4 19:13:09 bionic kernel: [ 6.429565] zram: Added device: zram1
Nov 4 19:13:09 bionic kernel: [ 6.431100] zram: Added device: zram2
Nov 4 19:13:09 bionic kernel: [ 6.432597] zram: Added device: zram3
Nov 4 19:13:09 bionic kernel: [ 6.456830] zram0: detected capacity change from 0 to 519602176
Nov 4 19:13:09 bionic kernel: [ 6.607457] input: Logitech MX Keys as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.2/0003:046D:C52B.0003/0003:046D:408A.0004/input/input2
Nov 4 19:13:09 bionic kernel: [ 6.608825] logitech-hidpp-device 0003:046D:408A.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Keys] on usb-70090000.xusb-2.1:1
Nov 4 19:13:09 bionic kernel: [ 6.615489] input: Logitech M720 Triathlon as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.2/0003:046D:C52B.0003/0003:046D:405E.0005/input/input3
Nov 4 19:13:09 bionic kernel: [ 6.616664] logitech-hidpp-device 0003:046D:405E.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-70090000.xusb-2.1:3
Nov 4 19:13:09 bionic kernel: [ 6.621483] input: Logitech K780 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.2/0003:046D:C52B.0003/0003:046D:405B.0006/input/input4
Nov 4 19:13:09 bionic kernel: [ 6.623712] logitech-hidpp-device 0003:046D:405B.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech K780] on usb-70090000.xusb-2.1:4
Nov 4 19:13:09 bionic kernel: [ 6.632818] Adding 507420k swap on /dev/zram0. Priority:5 extents:1 across:507420k SS
Nov 4 19:13:09 bionic kernel: [ 6.640349] zram1: detected capacity change from 0 to 519602176
Nov 4 19:13:09 bionic kernel: [ 6.658097] Adding 507420k swap on /dev/zram1. Priority:5 extents:1 across:507420k SS
Nov 4 19:13:09 bionic kernel: [ 6.670868] zram2: detected capacity change from 0 to 519602176
Nov 4 19:13:09 bionic kernel: [ 6.704394] Adding 507420k swap on /dev/zram2. Priority:5 extents:1 across:507420k SS
Nov 4 19:13:09 bionic kernel: [ 6.714959] zram3: detected capacity change from 0 to 519602176
Nov 4 19:13:09 bionic kernel: [ 6.727132] Adding 507420k swap on /dev/zram3. Priority:5 extents:1 across:507420k SS
Nov 4 19:13:12 bionic kernel: [ 9.436290] tegradc tegradc.0: blank - powerdown
Nov 4 19:13:12 bionic kernel: [ 9.436300] tegradc tegradc.1: blank - powerdown
Nov 4 19:13:13 bionic kernel: [ 10.454382] r8168: eth0: link up
Nov 4 19:13:13 bionic kernel: [ 10.454440] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Nov 4 19:13:13 bionic kernel: [ 11.110468] usb 2-1: usb_suspend_both: status 0
Nov 4 19:13:13 bionic kernel: [ 11.110706] usb usb2: usb_suspend_both: status 0
Nov 4 19:13:16 bionic kernel: [ 14.218569] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Nov 4 19:13:16 bionic kernel: [ 14.218581] Bluetooth: BNEP socket layer initialized
Nov 4 19:16:09 bionic kernel: [ 187.461639] tegra-i2c 7000c400.i2c: no acknowledge from address 0x30
Nov 4 19:16:09 bionic kernel: [ 187.468538] tegra-i2c 7000c400.i2c: no acknowledge from address 0x31
Nov 4 19:16:09 bionic kernel: [ 187.475618] tegra-i2c 7000c400.i2c: no acknowledge from address 0x32
Nov 4 19:16:09 bionic kernel: [ 187.482669] tegra-i2c 7000c400.i2c: no acknowledge from address 0x33
Nov 4 19:16:09 bionic kernel: [ 187.489439] tegra-i2c 7000c400.i2c: no acknowledge from address 0x34
Nov 4 19:16:09 bionic kernel: [ 187.496200] tegra-i2c 7000c400.i2c: no acknowledge from address 0x35
Nov 4 19:16:09 bionic kernel: [ 187.502943] tegra-i2c 7000c400.i2c: no acknowledge from address 0x36
Nov 4 19:16:09 bionic kernel: [ 187.509710] tegra-i2c 7000c400.i2c: no acknowledge from address 0x37
Nov 4 19:16:09 bionic kernel: [ 187.516556] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
Nov 4 19:16:09 bionic kernel: [ 187.523331] tegra-i2c 7000c400.i2c: no acknowledge from address 0x51
Nov 4 19:16:09 bionic kernel: [ 187.530082] tegra-i2c 7000c400.i2c: no acknowledge from address 0x52
Nov 4 19:16:09 bionic kernel: [ 187.536800] tegra-i2c 7000c400.i2c: no acknowledge from address 0x53
Nov 4 19:16:09 bionic kernel: [ 187.543537] tegra-i2c 7000c400.i2c: no acknowledge from address 0x54
Nov 4 19:16:09 bionic kernel: [ 187.550245] tegra-i2c 7000c400.i2c: no acknowledge from address 0x55
Nov 4 19:16:09 bionic kernel: [ 187.557012] tegra-i2c 7000c400.i2c: no acknowledge from address 0x56
Nov 4 19:16:09 bionic kernel: [ 187.563774] tegra-i2c 7000c400.i2c: no acknowledge from address 0x57
Nov 4 19:16:09 bionic kernel: [ 187.570538] tegra-i2c 7000c400.i2c: no acknowledge from address 0x58
Nov 4 19:16:09 bionic kernel: [ 187.577359] tegra-i2c 7000c400.i2c: no acknowledge from address 0x59
Nov 4 19:16:09 bionic kernel: [ 187.584229] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5a
Nov 4 19:16:09 bionic kernel: [ 187.591001] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5b
Nov 4 19:16:09 bionic kernel: [ 187.598062] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5c
Nov 4 19:16:09 bionic kernel: [ 187.604994] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5d
Nov 4 19:16:09 bionic kernel: [ 187.611946] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5e
Nov 4 19:16:09 bionic kernel: [ 187.618933] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5f
Nov 4 19:16:31 bionic kernel: [ 209.121806] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3
Nov 4 19:16:31 bionic kernel: [ 209.128726] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4
Nov 4 19:16:31 bionic kernel: [ 209.135548] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5
Nov 4 19:16:31 bionic kernel: [ 209.142379] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6
Nov 4 19:16:31 bionic kernel: [ 209.149099] tegra-i2c 7000c400.i2c: no acknowledge from address 0x7
Nov 4 19:16:31 bionic kernel: [ 209.155816] tegra-i2c 7000c400.i2c: no acknowledge from address 0x8
Nov 4 19:16:31 bionic kernel: [ 209.162496] tegra-i2c 7000c400.i2c: no acknowledge from address 0x9
Nov 4 19:16:31 bionic kernel: [ 209.169218] tegra-i2c 7000c400.i2c: no acknowledge from address 0xa
Nov 4 19:16:31 bionic kernel: [ 209.175847] tegra-i2c 7000c400.i2c: no acknowledge from address 0xb
Nov 4 19:16:31 bionic kernel: [ 209.182488] tegra-i2c 7000c400.i2c: no acknowledge from address 0xc
Nov 4 19:16:31 bionic kernel: [ 209.189201] tegra-i2c 7000c400.i2c: no acknowledge from address 0xd
Nov 4 19:16:31 bionic kernel: [ 209.195889] tegra-i2c 7000c400.i2c: no acknowledge from address 0xe
Nov 4 19:16:31 bionic kernel: [ 209.202552] tegra-i2c 7000c400.i2c: no acknowledge from address 0xf
Nov 4 19:16:31 bionic kernel: [ 209.209239] tegra-i2c 7000c400.i2c: no acknowledge from address 0x10
Nov 4 19:16:31 bionic kernel: [ 209.216110] tegra-i2c 7000c400.i2c: no acknowledge from address 0x11
Nov 4 19:16:31 bionic kernel: [ 209.222855] tegra-i2c 7000c400.i2c: no acknowledge from address 0x12
Nov 4 19:16:31 bionic kernel: [ 209.229619] tegra-i2c 7000c400.i2c: no acknowledge from address 0x13
Nov 4 19:16:31 bionic kernel: [ 209.236393] tegra-i2c 7000c400.i2c: no acknowledge from address 0x14
Nov 4 19:16:31 bionic kernel: [ 209.243129] tegra-i2c 7000c400.i2c: no acknowledge from address 0x15
Nov 4 19:16:31 bionic kernel: [ 209.249886] tegra-i2c 7000c400.i2c: no acknowledge from address 0x16
Nov 4 19:16:31 bionic kernel: [ 209.256739] tegra-i2c 7000c400.i2c: no acknowledge from address 0x17
Nov 4 19:16:31 bionic kernel: [ 209.263514] tegra-i2c 7000c400.i2c: no acknowledge from address 0x18
Nov 4 19:16:31 bionic kernel: [ 209.270255] tegra-i2c 7000c400.i2c: no acknowledge from address 0x19
Nov 4 19:16:31 bionic kernel: [ 209.277016] tegra-i2c 7000c400.i2c: no acknowledge from address 0x1a
Nov 4 19:16:31 bionic kernel: [ 209.283760] tegra-i2c 7000c400.i2c: no acknowledge from address 0x1b
Nov 4 19:16:31 bionic kernel: [ 209.290586] tegra-i2c 7000c400.i2c: no acknowledge from address 0x1c
Nov 4 19:16:31 bionic kernel: [ 209.297517] tegra-i2c 7000c400.i2c: no acknowledge from address 0x1d
Nov 4 19:16:31 bionic kernel: [ 209.304272] tegra-i2c 7000c400.i2c: no acknowledge from address 0x1e
Nov 4 19:16:31 bionic kernel: [ 209.311791] tegra-i2c 7000c400.i2c: no acknowledge from address 0x1f
Nov 4 19:16:31 bionic kernel: [ 209.318731] tegra-i2c 7000c400.i2c: no acknowledge from address 0x20
Nov 4 19:16:31 bionic kernel: [ 209.325554] tegra-i2c 7000c400.i2c: no acknowledge from address 0x21
Nov 4 19:16:31 bionic kernel: [ 209.333020] tegra-i2c 7000c400.i2c: no acknowledge from address 0x22
Nov 4 19:16:31 bionic kernel: [ 209.339863] tegra-i2c 7000c400.i2c: no acknowledge from address 0x23
Nov 4 19:16:31 bionic kernel: [ 209.346654] tegra-i2c 7000c400.i2c: no acknowledge from address 0x24
Nov 4 19:16:31 bionic kernel: [ 209.353419] tegra-i2c 7000c400.i2c: no acknowledge from address 0x25
Nov 4 19:16:31 bionic kernel: [ 209.360411] tegra-i2c 7000c400.i2c: no acknowledge from address 0x26
Nov 4 19:16:31 bionic kernel: [ 209.367524] tegra-i2c 7000c400.i2c: no acknowledge from address 0x27
Nov 4 19:16:31 bionic kernel: [ 209.374704] tegra-i2c 7000c400.i2c: no acknowledge from address 0x28
Nov 4 19:16:31 bionic kernel: [ 209.381720] tegra-i2c 7000c400.i2c: no acknowledge from address 0x29
Nov 4 19:16:31 bionic kernel: [ 209.388609] tegra-i2c 7000c400.i2c: no acknowledge from address 0x2a
Nov 4 19:16:31 bionic kernel: [ 209.396652] tegra-i2c 7000c400.i2c: no acknowledge from address 0x2b
Nov 4 19:16:31 bionic kernel: [ 209.403463] tegra-i2c 7000c400.i2c: no acknowledge from address 0x2c
Nov 4 19:16:31 bionic kernel: [ 209.410202] tegra-i2c 7000c400.i2c: no acknowledge from address 0x2d
Nov 4 19:16:31 bionic kernel: [ 209.417377] tegra-i2c 7000c400.i2c: no acknowledge from address 0x2e
Nov 4 19:16:31 bionic kernel: [ 209.424403] tegra-i2c 7000c400.i2c: no acknowledge from address 0x2f
Nov 4 19:16:31 bionic kernel: [ 209.431567] tegra-i2c 7000c400.i2c: no acknowledge from address 0x30
Nov 4 19:16:31 bionic kernel: [ 209.438611] tegra-i2c 7000c400.i2c: no acknowledge from address 0x31
Nov 4 19:16:31 bionic kernel: [ 209.445592] tegra-i2c 7000c400.i2c: no acknowledge from address 0x32
Nov 4 19:16:31 bionic kernel: [ 209.452631] tegra-i2c 7000c400.i2c: no acknowledge from address 0x33
Nov 4 19:16:31 bionic kernel: [ 209.459660] tegra-i2c 7000c400.i2c: no acknowledge from address 0x34
Nov 4 19:16:31 bionic kernel: [ 209.466831] tegra-i2c 7000c400.i2c: no acknowledge from address 0x35
Nov 4 19:16:31 bionic kernel: [ 209.473845] tegra-i2c 7000c400.i2c: no acknowledge from address 0x36
Nov 4 19:16:31 bionic kernel: [ 209.480813] tegra-i2c 7000c400.i2c: no acknowledge from address 0x37
Nov 4 19:16:31 bionic kernel: [ 209.487576] tegra-i2c 7000c400.i2c: no acknowledge from address 0x38
Nov 4 19:16:31 bionic kernel: [ 209.494273] tegra-i2c 7000c400.i2c: no acknowledge from address 0x39
Nov 4 19:16:31 bionic kernel: [ 209.500990] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3a
Nov 4 19:16:31 bionic kernel: [ 209.507632] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3b
Nov 4 19:16:31 bionic kernel: [ 209.514302] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
Nov 4 19:16:31 bionic kernel: [ 209.521011] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3d
Nov 4 19:16:31 bionic kernel: [ 209.527809] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3e
Nov 4 19:16:31 bionic kernel: [ 209.535301] tegra-i2c 7000c400.i2c: no acknowledge from address 0x3f
Nov 4 19:16:31 bionic kernel: [ 209.542154] tegra-i2c 7000c400.i2c: no acknowledge from address 0x40
Nov 4 19:16:31 bionic kernel: [ 209.548911] tegra-i2c 7000c400.i2c: no acknowledge from address 0x41
Nov 4 19:16:31 bionic kernel: [ 209.555685] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
Nov 4 19:16:31 bionic kernel: [ 209.562628] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
Nov 4 19:16:31 bionic kernel: [ 209.569459] tegra-i2c 7000c400.i2c: no acknowledge from address 0x44
Nov 4 19:16:31 bionic kernel: [ 209.576313] tegra-i2c 7000c400.i2c: no acknowledge from address 0x45
Nov 4 19:16:31 bionic kernel: [ 209.583073] tegra-i2c 7000c400.i2c: no acknowledge from address 0x46
Nov 4 19:16:31 bionic kernel: [ 209.589864] tegra-i2c 7000c400.i2c: no acknowledge from address 0x47
Nov 4 19:16:31 bionic kernel: [ 209.596684] tegra-i2c 7000c400.i2c: no acknowledge from address 0x48
Nov 4 19:16:31 bionic kernel: [ 209.603429] tegra-i2c 7000c400.i2c: no acknowledge from address 0x49
Nov 4 19:16:31 bionic kernel: [ 209.610172] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4a
Nov 4 19:16:31 bionic kernel: [ 209.616982] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4b
Nov 4 19:16:31 bionic kernel: [ 209.623777] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4c
Nov 4 19:16:31 bionic kernel: [ 209.630541] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4d
Nov 4 19:16:32 bionic kernel: [ 209.637306] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4e
Nov 4 19:16:32 bionic kernel: [ 209.644039] tegra-i2c 7000c400.i2c: no acknowledge from address 0x4f
Nov 4 19:16:32 bionic kernel: [ 209.650842] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
Nov 4 19:16:32 bionic kernel: [ 209.657669] tegra-i2c 7000c400.i2c: no acknowledge from address 0x51
Nov 4 19:16:32 bionic kernel: [ 209.664437] tegra-i2c 7000c400.i2c: no acknowledge from address 0x52
Nov 4 19:16:32 bionic kernel: [ 209.671268] tegra-i2c 7000c400.i2c: no acknowledge from address 0x53
Nov 4 19:16:32 bionic kernel: [ 209.678042] tegra-i2c 7000c400.i2c: no acknowledge from address 0x54
Nov 4 19:16:32 bionic kernel: [ 209.684799] tegra-i2c 7000c400.i2c: no acknowledge from address 0x55
Nov 4 19:16:32 bionic kernel: [ 209.691603] tegra-i2c 7000c400.i2c: no acknowledge from address 0x56
Nov 4 19:16:32 bionic kernel: [ 209.698442] tegra-i2c 7000c400.i2c: no acknowledge from address 0x57
Nov 4 19:16:32 bionic kernel: [ 209.705233] tegra-i2c 7000c400.i2c: no acknowledge from address 0x58
Nov 4 19:16:32 bionic kernel: [ 209.711944] tegra-i2c 7000c400.i2c: no acknowledge from address 0x59
Nov 4 19:16:32 bionic kernel: [ 209.718748] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5a
Nov 4 19:16:32 bionic kernel: [ 209.725504] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5b
Nov 4 19:16:32 bionic kernel: [ 209.732287] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5c
Nov 4 19:16:32 bionic kernel: [ 209.739136] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5d
Nov 4 19:16:32 bionic kernel: [ 209.745892] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5e
Nov 4 19:16:32 bionic kernel: [ 209.752663] tegra-i2c 7000c400.i2c: no acknowledge from address 0x5f
Nov 4 19:16:32 bionic kernel: [ 209.759409] tegra-i2c 7000c400.i2c: no acknowledge from address 0x60
Nov 4 19:16:32 bionic kernel: [ 209.766149] tegra-i2c 7000c400.i2c: no acknowledge from address 0x61
Nov 4 19:16:32 bionic kernel: [ 209.772986] tegra-i2c 7000c400.i2c: no acknowledge from address 0x62
Nov 4 19:16:32 bionic kernel: [ 209.779807] tegra-i2c 7000c400.i2c: no acknowledge from address 0x63
Nov 4 19:16:32 bionic kernel: [ 209.786640] tegra-i2c 7000c400.i2c: no acknowledge from address 0x64
Nov 4 19:16:32 bionic kernel: [ 209.793465] tegra-i2c 7000c400.i2c: no acknowledge from address 0x65
Nov 4 19:16:32 bionic kernel: [ 209.800493] tegra-i2c 7000c400.i2c: no acknowledge from address 0x66
Nov 4 19:16:32 bionic kernel: [ 209.807262] tegra-i2c 7000c400.i2c: no acknowledge from address 0x67
Nov 4 19:16:32 bionic kernel: [ 209.814097] tegra-i2c 7000c400.i2c: no acknowledge from address 0x68
Nov 4 19:16:32 bionic kernel: [ 209.820897] tegra-i2c 7000c400.i2c: no acknowledge from address 0x69
Nov 4 19:16:32 bionic kernel: [ 209.827726] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6a
Nov 4 19:16:32 bionic kernel: [ 209.834506] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6b
Nov 4 19:16:32 bionic kernel: [ 209.841314] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6c
Nov 4 19:16:32 bionic kernel: [ 209.848112] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6d
Nov 4 19:16:32 bionic kernel: [ 209.854890] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6e
Nov 4 19:16:32 bionic kernel: [ 209.861672] tegra-i2c 7000c400.i2c: no acknowledge from address 0x6f
Nov 4 19:16:32 bionic kernel: [ 209.868471] tegra-i2c 7000c400.i2c: no acknowledge from address 0x70
Nov 4 19:16:32 bionic kernel: [ 209.875285] tegra-i2c 7000c400.i2c: no acknowledge from address 0x71
Nov 4 19:16:32 bionic kernel: [ 209.882039] tegra-i2c 7000c400.i2c: no acknowledge from address 0x72
Nov 4 19:16:32 bionic kernel: [ 209.888785] tegra-i2c 7000c400.i2c: no acknowledge from address 0x73
Nov 4 19:16:32 bionic kernel: [ 209.895526] tegra-i2c 7000c400.i2c: no acknowledge from address 0x74
Nov 4 19:16:32 bionic kernel: [ 209.902307] tegra-i2c 7000c400.i2c: no acknowledge from address 0x75
Nov 4 19:16:32 bionic kernel: [ 209.909135] tegra-i2c 7000c400.i2c: no acknowledge from address 0x76
Nov 4 19:16:32 bionic kernel: [ 209.915893] tegra-i2c 7000c400.i2c: no acknowledge from address 0x77
Where is the i2c timeout in the log you provided?
the no ack must be because there is no device connected.
Also, before running the test, increase the log level using the command:
dmesg -n 7
Sorry the XRUNs are happening when I have I2C not acknowledged transactions, I should not have called it timeout.
You are correct, one cause of transactions not acknowledged is when the device is not present and this is the easiest way to reproduce the problem by using i2cdetect.
Another cause of not acknowledged transaction is when the device is not ready, with happens with slow devices or when the device is busy doing something else, and this is the case in my application.
I used “dmesg -n 7”, the log is pretty long, what is the easiest way to upload it?
Hello!
Once you have created a post, there is a paper-clip icon in the top right corner you can use to attach a file. Its a bit weird that you cannot add an attachment until you have created the post, but that is how it currently works.
Regards Jon
No problem, here is the log
dmesg.txt (61.6 KB)
Hi I think you should check the devices on I2C-bus 1 for 7000c000.i2c.
