We have a third-party carrier board for which we recently add the RTC. Everything seems to work fine but the audio does not work.
I tried my best to understand this conversation but could not make it, I am a novice in understanding the DTB file.
I am attaching the DTS file for our DTB file, Please help me to resolve the issue.
dtb.txt (329.0 KB)
Hi @sarodeanil35 ,
I have couple of questions.
Which JP version are you using on Jetson Nano?
How are you checking Audio on 40 pin HDR?
Have you done pinmux settings to enable Audio via 40pin HDR? Kindly read through/follow instructions provided in the Developer Guide for the specific JP release. Jetson Software Documentation - Section " 40-pin GPIO Expansion Header"
Thanks,
Sharad
Hi @sharadg
Thanks for your response.
JP version :
Package: nvidia-jetpack
Version: 4.6.5-b29
# R32 (release), REVISION: 7.5, GCID: 36557527, BOARD: t210ref, EABI: aarch64, DATE: Tue Jun 11 23:12:44 UTC 2024
Audio checking:
I2S4 PINs
7 - AUDIO_MCLK
12 - I2S_4_SCLK
35 - I2S_4_LRCK
38 - I2S_4_SDIN
40 - I2S_4_SDOUT
sharadg:
Please check above.
Are you probing I2S signals or connecting Audio Codec to it? Please follow instructions provided in the link above to enable Audio via 40 pin HDR.
@sharadg
I am using the follwing commnad
sudo /opt/nvidia/jetson-io/jetson-io.py
I get the following
But dev kit I got the following
Is there anything wrong, if so can you guide me to correct it?
