I can’t use a GSML camera right now
I found that my aurix does not match
shell> status
Info: Executing cmd: status, argc: 0, args:
Alive : 00:04:56
CPU load Core 0: 9%
CPU load max Core 0: 9%
CPU load Core 1: 0%
CPU load max Core 1: 0%
CPU load Core 2: 0%
CPU load max Core 2: 0%
Hardware information:
PMU-chip: B-Step
SCU_CHIPID: 0x4B459051
SystemUpInit-Time[ms]: 47
FPD-switch = 1 (Tegra-B)
IP-address (Tegra-A): 192.168.199.173
IP-address (Tegra-B): 10.42.0.29
IP-address (AURIX): 10.42.0.29
MAC-address (Tegra-A): 0x000000044BABF986
MAC-address (Tegra-B): 0x000000044BABF987
MAC-address (AURIX): 0x000000044BABF988
MAC-address (FPGA): 0x0000000000000000
ADC0_HRNS2: 0x0950
ADC1_HRNS2: 0x0951
Command Executed
tegra a
AURIX_IP_ADDRESS=10.42.0.146
TEGRA_A_IP_ADDRESS=10.42.0.29
TEGRA_B_IP_ADDRESS=10.42.0.29
TEGRA_CVM_IP_ADDRESS=10.42.0.30
TEGRA_IP_ADDRESS=10.42.0.28
AURIX_SERVER_PORT=5000
AURIX_EASYCAN_PORT=50000
TEGRA_EASYCAN_PORT=60395
drive-px2-a=eth0.200
drive-px2-b=eth0.200
drive-px2-autocruise=lo
drive-ax=eth0.200
ddpx-a=eth0
ddpx-b=eth0
ddpx-c=eth0
RECEIVE_TIMEOUT_S=5
RECEIVE_TIMEOUT_US=0
SPI_RECEIVE_TIMEOUT_US=1000000
My network configuration
nvidia@nvidia:/etc/network$ cat interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto enp3s0
iface enp3s0 inet static
address 192.168.199.200
netmask 255.255.0.0
gateway 192.168.199.1
dns-nameserver 8.8.8.8
nvidia@nvidia:/etc/network$ ifconfig
enp3s0 Link encap:Ethernet HWaddr 00:04:4b:8d:a6:fa
inet addr:192.168.199.200 Bcast:192.168.255.255 Mask:255.255.0.0
inet6 addr: fe80::204:4bff:fe8d:a6fa/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:7548 errors:0 dropped:1189 overruns:0 frame:0
TX packets:481 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:570948 (570.9 KB) TX bytes:62040 (62.0 KB)
eth0 Link encap:Ethernet HWaddr 00:04:4b:ab:f9:86
inet addr:192.168.199.98 Bcast:192.168.255.255 Mask:255.255.0.0
inet6 addr: fe80::204:4bff:feab:f986/64 Scope:Link
RX packets:7513 errors:0 dropped:1236 overruns:0 frame:0
TX packets:549 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:713339 (713.3 KB) TX bytes:57406 (57.4 KB)
Interrupt:46
eth0.200 Link encap:Ethernet HWaddr 00:04:4b:ab:f9:86
inet addr:10.42.0.29 Bcast:10.42.0.255 Mask:255.255.255.0
RX packets:51 errors:0 dropped:0 overruns:0 frame:0
TX packets:116 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4619 (4.6 KB) TX bytes:15260 (15.2 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:250 errors:0 dropped:0 overruns:0 frame:0
TX packets:250 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:19358 (19.3 KB) TX bytes:19358 (19.3 KB)
I tried to modify the AURIX’s IP through the shell
But no response
Setip a 10.42.0.28
aurixreset
No effect, configuration has not changed, how should I configure?
What is the default configuration? How do I need to modify it?
