Aurix flashing fails
I have DRIVE AGX Xavier™ Developer Kit, On it I have Drive os version 5.0.13.0, one that goes with QNX on Xavier. Board was working fine until flashing Xaviers failed, after that I tried flashing Aurix version 5.0.13 and version 5.1.0, and both failed on UPDATE part: E3550-NV-Aurix-UPDATE.hex, at the moment when flashing UCBS start:
[LOG]
Tu 11.08.2020 15:39:44.925, Success, PFLASH, Flashing program sections succeeded.
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, ProgramSections
Tu 11.08.2020 15:39:44.925, Message, MiniMonTargIntf, BeginCmdSequence
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, AutoChipErase: 0
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, AutoErase: 0
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, SimulateRAM: 0
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, AutoVerify: 1
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, SkipUnchangedSectors: 0
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, FillGaps: 0
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, AbmHeaderHandling: 0
Tu 11.08.2020 15:39:44.925, Message, DF_UCBS, Download driver section 0xC0000000-0xC000060F
Tu 11.08.2020 15:39:44.925, Message, MiniMonTargIntf, WriteBlock(Mode: 0x40000001, Start: 0xC0000000, Bytes: 1552 (0x00000610))
Tu 11.08.2020 15:39:45.205, Message, MiniMonTargIntf, WriteBlock, Result: 0x00000000, Time: 281, State: 0x00000000
Tu 11.08.2020 15:39:45.205, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xC0000000, Bytes: 1552 (0x00000610))
Tu 11.08.2020 15:39:45.205, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xC0000000-0xC000060F) …
Tu 11.08.2020 15:39:45.475, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 266, State: 0x00000000
Tu 11.08.2020 15:39:45.475, Message, DF_UCBS, ExecMonExt: 0000,AF40,86A0,000A,0064,0000,0000,80FF, Timeout: 5000 ms
Tu 11.08.2020 15:39:45.475, Message, MiniMonTargIntf, ExecMonExt(Start: 0xC0000000, Bytes: 16 (0x10), Timeout: 5000)
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ExecMonExt, Result: 0x00000000, Time: 31, State: halted
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, MonExtResult: 8000,D000,0000,2000,0216,01C1,0004,0000, Time: 31 ms
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, Protection is installed
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadMem(Mode: 0x00000003, Addr: 0xF804001C)
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 0, State: 0x00000000, Value: 0x00000001
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadMem(Mode: 0x00000003, Addr: 0xF8040024)
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 0, State: 0x00000000, Value: 0x00000555
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, PROTECT: 0x00000001
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, CONFIRM1: 0x00000555
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, Read Sector0, Range0 …
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, Read Block: 0xAF4001F4 - 0xAF4001FF (12 bytes)
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xAF4001F4, Bytes: 12 (0x0000000C))
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xAF4001F4-0xAF4001FF) …
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 0, State: 0x00000000
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, Read Sector1, Range0 …
Tu 11.08.2020 15:39:45.505, Message, DF_UCBS, Read Block: 0xAF4003F4 - 0xAF4003FF (12 bytes)
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xAF4003F4, Bytes: 12 (0x0000000C))
Tu 11.08.2020 15:39:45.505, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xAF4003F4-0xAF4003FF) …
Tu 11.08.2020 15:39:45.515, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 0, State: 0x00000000
Tu 11.08.2020 15:39:45.515, Message, DF_UCBS, Read Sector2, Range0 …
Tu 11.08.2020 15:39:45.515, Message, DF_UCBS, Read Block: 0xAF4005F4 - 0xAF4005FF (12 bytes)
Tu 11.08.2020 15:39:45.515, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xAF4005F4, Bytes: 12 (0x0000000C))
Tu 11.08.2020 15:39:45.515, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xAF4005F4-0xAF4005FF) …
Tu 11.08.2020 15:39:45.515, Message, DF_UCBS, Read Sector8, Range0 …
Tu 11.08.2020 15:39:45.515, Message, DF_UCBS, Read Block: 0xAF4011F4 - 0xAF4011FF (12 bytes)
Tu 11.08.2020 15:39:45.515, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xAF4011F4, Bytes: 12 (0x0000000C))
Tu 11.08.2020 15:39:45.515, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xAF4011F4-0xAF4011FF) …
Tu 11.08.2020 15:39:45.525, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 16, State: 0x00000000
Tu 11.08.2020 15:39:45.525, Message, DF_UCBS, Read Sector9, Range0 …
Tu 11.08.2020 15:39:45.525, Message, DF_UCBS, Read Block: 0xAF4013F4 - 0xAF4013FF (12 bytes)
Tu 11.08.2020 15:39:45.525, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xAF4013F4, Bytes: 12 (0x0000000C))
Tu 11.08.2020 15:39:45.525, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xAF4013F4-0xAF4013FF) …
Tu 11.08.2020 15:39:45.525, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 0, State: 0x00000000
Tu 11.08.2020 15:39:45.525, Message, DF_UCBS, Read Sector10, Range0 …
Tu 11.08.2020 15:39:45.525, Message, DF_UCBS, Read Block: 0xAF4015F4 - 0xAF4015FF (12 bytes)
Tu 11.08.2020 15:39:45.525, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xAF4015F4, Bytes: 12 (0x0000000C))
Tu 11.08.2020 15:39:45.525, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xAF4015F4-0xAF4015FF) …
Tu 11.08.2020 15:39:45.535, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 15, State: 0x00000000
Tu 11.08.2020 15:39:45.535, Message, DF_UCBS, Program sector 0 …
Tu 11.08.2020 15:39:45.535, Message, DF_UCBS, Prog Block: 0xAF400000 - 0xAF4001FF, 16 Bursts
Tu 11.08.2020 15:39:45.535, Message, DF_UCBS, Download driver section 0xC0000000-0xC000060F
Tu 11.08.2020 15:39:45.535, Message, MiniMonTargIntf, WriteBlock(Mode: 0x40000001, Start: 0xC0000000, Bytes: 1552 (0x00000610))
Tu 11.08.2020 15:39:45.815, Message, MiniMonTargIntf, WriteBlock, Result: 0x00000000, Time: 281, State: 0x00000000
Tu 11.08.2020 15:39:45.815, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xC0000000, Bytes: 1552 (0x00000610))
Tu 11.08.2020 15:39:45.815, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xC0000000-0xC000060F) …
Tu 11.08.2020 15:39:46.085, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 266, State: 0x00000000
Tu 11.08.2020 15:39:46.085, Message, DF_UCBS, ExecMonExt: 0000,AF40,86A0,000A,0064,0000,0000,80FF, Timeout: 5000 ms
Tu 11.08.2020 15:39:46.085, Message, MiniMonTargIntf, ExecMonExt(Start: 0xC0000000, Bytes: 16 (0x10), Timeout: 5000)
Tu 11.08.2020 15:39:46.115, Message, MiniMonTargIntf, ExecMonExt, Result: 0x00000000, Time: 31, State: halted
Tu 11.08.2020 15:39:46.115, Message, DF_UCBS, MonExtResult: 8000,D000,0000,2000,0216,01C1,0004,0000, Time: 31 ms
Tu 11.08.2020 15:39:46.115, Message, DF_UCBS, Protection is installed
Tu 11.08.2020 15:39:46.115, Message, MiniMonTargIntf, ReadMem(Mode: 0x00000003, Addr: 0xF804001C)
Tu 11.08.2020 15:39:46.115, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 0, State: 0x00000000, Value: 0x00000001
Tu 11.08.2020 15:39:46.115, Message, MiniMonTargIntf, ReadMem(Mode: 0x00000003, Addr: 0xF8040024)
Tu 11.08.2020 15:39:46.115, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 0, State: 0x00000000, Value: 0x00000555
Tu 11.08.2020 15:39:46.115, Message, DF_UCBS, PROTECT: 0x00000001
Tu 11.08.2020 15:39:46.115, Message, DF_UCBS, CONFIRM1: 0x00000555
Tu 11.08.2020 15:39:46.115, Message, MiniMonTargIntf, WriteBlock(Mode: 0x40000001, Start: 0xD0000000, Bytes: 512 (0x00000200))
Tu 11.08.2020 15:39:46.215, Message, MiniMonTargIntf, WriteBlock, Result: 0x00000000, Time: 94, State: 0x00000000
Tu 11.08.2020 15:39:46.215, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xD0000000, Bytes: 512 (0x00000200))
Tu 11.08.2020 15:39:46.215, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xD0000000-0xD00001FF) …
Tu 11.08.2020 15:39:46.305, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 94, State: 0x00000000
Tu 11.08.2020 15:39:46.305, Message, DF_UCBS, ExecMonExt: 0017,AF40,AF40,0000,0010,D000,0000,80FF, Timeout: 5000 ms
Tu 11.08.2020 15:39:46.305, Message, MiniMonTargIntf, ExecMonExt(Start: 0xC0000000, Bytes: 16 (0x10), Timeout: 10)
Tu 11.08.2020 15:39:46.355, Message, MiniMonTargIntf, ExecMonExt, Result: 0x00000000, Time: 47, State: halted
Tu 11.08.2020 15:39:46.355, Message, DF_UCBS, MonExtResult: 0017,AF40,0000,0020,0001,D000,0000,0000, Time: 47 ms
Tu 11.08.2020 15:39:46.355, Message, DF_UCBS, UCB programmed successfully
Tu 11.08.2020 15:39:46.355, Message, DF_UCBS, Program sector 1 …
Tu 11.08.2020 15:39:46.355, Message, DF_UCBS, Prog Block: 0xAF400200 - 0xAF4003FF, 16 Bursts
Tu 11.08.2020 15:39:46.355, Message, DF_UCBS, Download driver section 0xC0000000-0xC000060F
Tu 11.08.2020 15:39:46.355, Message, MiniMonTargIntf, WriteBlock(Mode: 0x40000001, Start: 0xC0000000, Bytes: 1552 (0x00000610))
Tu 11.08.2020 15:39:46.635, Message, MiniMonTargIntf, WriteBlock, Result: 0x00000000, Time: 281, State: 0x00000000
Tu 11.08.2020 15:39:46.635, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xC0000000, Bytes: 1552 (0x00000610))
Tu 11.08.2020 15:39:46.635, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xC0000000-0xC000060F) …
Tu 11.08.2020 15:39:46.905, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 266, State: 0x00000000
Tu 11.08.2020 15:39:46.905, Message, DF_UCBS, ExecMonExt: 0000,AF40,86A0,000A,0064,0000,0000,80FF, Timeout: 5000 ms
Tu 11.08.2020 15:39:46.905, Message, MiniMonTargIntf, ExecMonExt(Start: 0xC0000000, Bytes: 16 (0x10), Timeout: 5000)
Tu 11.08.2020 15:39:46.935, Message, MiniMonTargIntf, ExecMonExt, Result: 0x00000000, Time: 31, State: halted
Tu 11.08.2020 15:39:46.935, Message, DF_UCBS, MonExtResult: 8000,D000,0000,2000,0216,01C1,0004,0000, Time: 31 ms
Tu 11.08.2020 15:39:46.935, Message, DF_UCBS, Protection is installed
Tu 11.08.2020 15:39:46.935, Message, MiniMonTargIntf, ReadMem(Mode: 0x00000003, Addr: 0xF804001C)
Tu 11.08.2020 15:39:46.935, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 0, State: 0x00000000, Value: 0x00000001
Tu 11.08.2020 15:39:46.935, Message, MiniMonTargIntf, ReadMem(Mode: 0x00000003, Addr: 0xF8040024)
Tu 11.08.2020 15:39:46.935, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 0, State: 0x00000000, Value: 0x00000555
Tu 11.08.2020 15:39:46.945, Message, MiniMonTargIntf, ReadMem, Result: 0x00000000, Time: 15, State: 0x00000000, Value: 0x00000555
Tu 11.08.2020 15:39:46.945, Message, DF_UCBS, PROTECT: 0x00000001
Tu 11.08.2020 15:39:46.945, Message, DF_UCBS, CONFIRM1: 0x00000555
Tu 11.08.2020 15:39:46.945, Message, MiniMonTargIntf, WriteBlock(Mode: 0x40000001, Start: 0xD0000000, Bytes: 512 (0x00000200))
Tu 11.08.2020 15:39:47.035, Message, MiniMonTargIntf, WriteBlock, Result: 0x00000000, Time: 94, State: 0x00000000
Tu 11.08.2020 15:39:47.035, Message, MiniMonTargIntf, ReadBlock(Mode: 0x40000001, Start: 0xD0000000, Bytes: 512 (0x00000200))
Tu 11.08.2020 15:39:47.035, Message, MiniMonTargIntf, CTcRs232MiniMonTargetPort::ReadBlock(0xD0000000-0xD00001FF) …
Tu 11.08.2020 15:39:47.125, Message, MiniMonTargIntf, ReadBlock, Result: 0x00000000, Time: 78, State: 0x00000000
Tu 11.08.2020 15:39:47.125, Message, DF_UCBS, ExecMonExt: 0017,AF40,AF40,0200,0010,D000,0000,80FF, Timeout: 5000 ms
Tu 11.08.2020 15:39:47.125, Message, MiniMonTargIntf, ExecMonExt(Start: 0xC0000000, Bytes: 16 (0x10), Timeout: 10)
Tu 11.08.2020 15:39:47.175, Message, MiniMonTargIntf, ExecMonExt, Result: 0x00000000, Time: 63, State: halted
Tu 11.08.2020 15:39:47.175, Message, DF_UCBS, MonExtResult: 0017,AF40,0000,0020,0001,D000,0000,0000, Time: 63 ms
Tu 11.08.2020 15:39:47.175, Message, DF_UCBS, UCB programmed successfully
Tu 11.08.2020 15:39:47.175, Message, DF_UCBS, Program sector 2 …
Tu 11.08.2020 15:39:47.175, Message, DF_UCBS, Prog Block: 0xAF400400 - 0xAF4005FF, 16 Bursts
Tu 11.08.2020 15:39:47.175, Error, DF_UCBS, Loaded UCB image is invalid !
Tu 11.08.2020 15:39:47.175, Message, DF_UCBS, Install write filter 0xAF400000-0xAF405FFF
Tu 11.08.2020 15:39:47.175, Message, DF_UCBS, Install read filter 0xAF400000-0xAF405FFF
Tu 11.08.2020 15:39:47.175, Message, MiniMonTargIntf, EndCmdSequence
Tu 11.08.2020 15:39:47.175, Error, DF_UCBS, Flashing program sections failed.
Tu 11.08.2020 15:39:47.185, Message, MiniMonTargIntf, TestConnection()
Tu 11.08.2020 15:39:47.185, Message, MiniMonTargIntf, TestConnection, Result: 0x00000000, Time: 0, State: halted
I am flashing board with Infinion Memtool 4.8.
Since I fail to flash any software now and last Xavier flash also failed I cannot make use of any host on board. Can you tell me if I am missing something on a way of recovering board?
Hi @mihajloj,
Please try if flashing with Infinion Memtool 4.7 could work. Thanks!
Is this topic duplicate to below one? Are you working on Linux or QNX?
