( Edited, updated the class to have more functionality Feb 9 2021 )
In my project I want to make sure that cudaMallocManaged memory blocks get freed. Much like shared pointers. So I wrote a .cuh file called CUDAAutoMemory.
When it goes out of scope it frees the block.
Question: Is there a better way, I have not yet discovered, to do this?
Here is the code (only the float version of the code. There is also Double, Char, Int.)
/// <summary>
/// Allocated CUDA memory that automaticaly is disposed on scope exit.
/// Can fail in which case failedFlag is true.
/// </summary>
class ScopedCUDAMemoryFloat {
public:
float* m = NULL;
bool failedFlag = false;
// Empty constructor. Used in conjunction with AllocateIfNull(...)
ScopedCUDAMemoryFloat() {
/// <summary>
/// Allocate the cuda Memory if m is NULL. Also sets failedFlag, usually indicates out-of-memory.
/// If dat is not NULL then copy it into this memory block.
/// If always copy then will do a copy from dat (if not NULL) even if the block is already allocated.
/// </summary>
/// <param name="countOfFloats"></param>
void AllocateIfNull(unsigned long long countOfFloats, float* dat, bool alwaysCopy) {
if (m == NULL) {
cudaMallocManaged((void**)&m, countOfFloats * sizeof(float));
cudaError_t err = cudaGetLastError();
failedFlag = (err != cudaSuccess);
if (!failedFlag && dat)
cudaMemcpy(m, dat, countOfFloats * sizeof(float), cudaMemcpyKind::cudaMemcpyHostToDevice);
else if(alwaysCopy && dat && !failedFlag)
/// <summary>
/// Make the memory block. If dat is not NULL then copy the data to the new block.
/// </summary>
/// <param name="sz"></param>
/// <param name="dat"></param>
ScopedCUDAMemoryFloat(unsigned long long countOfFloats, float* dat) {
~ScopedCUDAMemoryFloat() {
if (m != NULL) {
cudaFree(m);
m = NULL;
float* operator&() {
if (m == NULL) throw "Out of memory. NULL pointer access.";
return m;
float& operator[](int i) {
return m[i];
