Hi all, I am using the Jetson nano 2gb Developer Kit. I currently have a Python script which I run through Visual Studio code ide which uses two Zed stereo cameras to detect some aruco markers - hence I am using opencv. The code runs successfully through VS code but I now want to run this code automatically when I connect the Nano to the power source - eliminating the need for peripherals (keyboard, mouse, monitor).
I have come across a couple of suggestions and tried the following using a simple hello world script I created.
In /home/user/.config I created a autostart folder and in there I made a new script called myscript.desktop using Text Editor:
[Desktop Entry]
Encoding=UTF-8
Name=myscript
Comment=myscript
Icon=gnome-info
Exec=python3 /home/user/Documents/PythonCode/helloworld.py
Terminal=false
Type=Application
Categories=
X-GNOME-Autostart-enabled=true
X-GNOME-Autostart-Delay=0automyJets
When I reboot nothing seems to happen. There is the possibility that my python script ran but I can’t check because the terminal isn’t open.
The other man suggestion I saw was using systemd commands as follows: Jetson nano auto run python code when power up
I am stuck on step 1. as I don’t know what commands to write in order to run my python script in the mything.sh file.
Any help/guidance on getting my python script to run on boot is welcome, thank you in advance!
