AutoMagicCalib (AMC) Error with DeepStream 9.1 MV3DT Pipeline
• Hardware Platform (Jetson / GPU): GeForce RTX 5080 16GB Workstation
• DeepStream Version: 9.1
• JetPack Version (valid for Jetson only): 7.2
• TensorRT Version:
• NVIDIA GPU Driver Version (valid for GPU only): 580.82.09
• Issue Type( questions, new requirements, bugs): Error with running the reference setup
Hi. I’m trying to test the AMC workflow for deploying the reference DeepStream 9.1 MV3DT pipeline on my custom video data.
Currently, I have two RTSP cameras looking over a 3m x 3m taped off area from ~2-2.5m height with 30-degrees angle. I recorded two ~3 minutes synchronized videos from both cameras while I walked in and out of the taped area (for generating multiple tracking IDs for a single person). Both cameras can fully see the taped off area (overlap) and they are across each other, not overlapping from side-angles.
Then I did a manual alignment as per the recent blog post: Build a Multi-Camera 3D Tracking Application with NVIDIA DeepStream 9.1 Skills | NVIDIA Technical Blog.
However, when I start the calibration, I’m getting ERROR - No valid tracklet matches found error from the AMC tool. I’m also attaching the full log.
What exactly is the AMC expecting to overcome this tracklet match problem?
amc_calibration_full.txt (109.9 KB)
At least 3 matched targets (tracklets) per camera pair. Please have a try to record videos which included 4 or 5 people walked in the camera view.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
