• Hardware Platform (Jetson / GPU): RTX 4090 • DeepStream Version: 9.0 • JetPack Version (valid for Jetson only): N/A • TensorRT Version: 11.0.0.114-1+cuda13.2 • NVIDIA GPU Driver Version (valid for GPU only): 595.71.05 • Issue Type( questions, new requirements, bugs): bug • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am using AutoMagicCalib and I have uploaded 3 videos from 3 different cameras, but on Step 4: Manual Alignment it only uses the first 2 videos and the layout instead of the 3 videos.
In my full system I will have 8 cameras working together. How can I calibrate them using this software. Using just 2 cameras is not giving me good calibration results.
The Manual Alignment UI currently uses Camera 0 + Camera 1 + Layout. However, this does not mean AutoMagicCalib is limited to only two input cameras. The documentation describes multi-camera input, but the videos must be ordered so consecutive camera pairs overlap, as shown in the doc1. The upload step also says that upload order determines the camera order, as shown in doc2, For an 8-camera setup, please upload all 8 videos and order them like an overlap chain:
cam_00 overlaps cam_01
cam_01 overlaps cam_02
cam_02 overlaps cam_03
cam_06 overlaps cam_07
Also make sure the videos are synchronized, 1920x1080, and contain enough moving people/objects across the overlapping regions. The documentation emphasizes overlap and scene features, as shown in doc3.
I was using 5120 × 3840 videos I will re-record at 1920 x 1080.
Right now all the cameras are overlapping, but on my final setup they will not completely overlap to each other, but they will overlap mostly on pairs, creating the overlap chain.
I tried with 1 or 2 people walking around the full area, trying to cover all the area, on a 4 minute video. Do I need more people?
How can I calibrate more than 2 cameras if AutoMagicCalib is limited to only two input cameras?
I want to stream using 5120 × 3840 in my final system. Will the calibration that I got on 1920 x 1080 work with the higher resolution?
The number of people must be greater than or equal to 3.
please refer to my last comment. AutoMagicCalib is not limited to only two input cameras.
Note that 1920x1080 is 16:9 while 5120x3840 is 4:3, so this is not a simple same-aspect-ratio scale. If the 5120x3840 stream uses a different sensor mode/crop/FOV, the 1920x1080 calibration may not directly apply. Please both use 1920x1080 resolution first.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
