Hi, I am trying to flash multiple Jetson Orin NX 16GB device of the same configuration. I am wondering if it was possible to skip through the GUI initial setup? (e.g. do not need to specify APP partition size, or Privacy settings).
Hi retro,
Are you using the devkit or custom board for Orin NX?
Do you mean the system configuration at first boot?
If so, you could refer to the following instruction to configure it before flash.
Flashing Support — Skipping oem-config
Thank you for replying. I am using a JETSON-ORIN-NX-16G-DEV-KIT (JETSON-IO-BASE-B) from Waveshare.
I am not using SDK Manger, but the manual flashing method (l4t_initrd_flash.sh) for JetPack 5.1 with R35.2.1 Linux.
I am refering to system configuration at first boot. Also, where can I specify the APP partition size?
It is a custom board from Waveshare.
You could add -S parameter in flash command to specify the size for your rootfs.
