Automatically creating device nodes
I’d like to reliably create device nodes for my Cuda cards.
There is a script that counts your number of cards by
lspci | grep -e nvidia -e 3D
But this doesn’t work very well for me, since my cards are not listed as “3D Controllers”.
What I currently do is
cards=$(lspci | grep VGA | grep -c nVidia)
but that’s not reliable either. On a system with a 7300 and a 295 this matches the 7300 and “half” the 295.
What I’d like to do is execute a devicequery, and awk the x from “NumDevs = x”, but that doesn’t work, because the devicequery won’t die without the user pressing .
Not very useful for automation.
So what’s the best way you know of, to solve this? :)
I would be incredibly surprised if you could run a useful device query before creating the devices CUDA needs to work…
Avid is correct - devicequery will fail if the drivers are not properly installed.
we use the following:
#!/bin/bash
timestamp=`date`
#  modprobe nvidia
if [ ! -c /dev/nvidiactl ]
then
echo "Server $machine device files re-created by crontab at $timestamp" >> ~/devicecrash.log
  # Count the number of NVIDIA controllers found.
  N3D=`/sbin/lspci | grep -i NVIDIA | grep "3D controller" | wc -l`
  NVGA=`/sbin/lspci | grep -i NVIDIA | grep "VGA compatible controller" | wc -l`
N=`expr $N3D + $NVGA - 1`
  for i in `seq 0 $N`; do
  mknod -m 666 /dev/nvidia$i c 195 $i;
  done
  mknod -m 666 /dev/nvidiactl c 195 255
. /home/run/stopGSlaves.sh
else
echo "Files exists"
exit 1
fi
Change to your SDK /C/src/deviceQuery directory, open the deviceQuery.cpp file, comment-out the last line (// CUT_EXIT(argc, argv); ) and type “make”.
The command string would be
cards=$(deviceQuery | grep supporting | awk ‘{print $3}’) Of course, it is trivial to code:
## devcount.cpp
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <cuda.h>
#include <cuda_runtime_api.h>
#include <cutil.h>
int
main( int argc, char** argv)
	int deviceCount;
	cudaGetDeviceCount(&deviceCount);
	printf("%d\n", deviceCount);
nvcc -I=/usr/local/cuda_sdk/C/common/inc/ devcount.cpp -o devcount
 ./devcount
2
As the others have noted, the title of this thread makes no sense.
The proper way to do it is by opening the /dev/nvidiactl device node and running a NV_CARD_INFO ioctl(2) on it.
Decoding the results makes clear the number of devices. This information can then be used to mknod(2) the
appropriate /dev/nvidiaX nodes.
The nvidia module will be loaded by opening the nvidiactl device node, so long as char-major-195-* is properly
bound to nvidia in modprobe.d/aliases.conf.
The ‘cudaminimal’ binary built with my libcudest library performs these tasks when run as root (otherwise,
mknod(2) will fail on EPERM). You can see how libcudest handles things here:
http://github.com/dankamongmen/libcudest/b…er/src/cudest.c
Look at init_ctlfd() and get_card_count(). There’s more info on libcudest on its home page:
http://dank.qemfd.net/dankwiki/index.php/Libcudest
Observe:
mmas $ ls -l /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 2010-07-08 06:50 /dev/nvidia0
crw-rw-rw- 1 root root 195, 1 2010-07-08 06:50 /dev/nvidia1
crw-rw-rw- 1 root root 195, 2 2010-07-08 06:50 /dev/nvidia2
crw-rw-rw- 1 root root 195, 3 2010-07-08 06:50 /dev/nvidia3
crw-rw-rw- 1 root root 195, 255 2010-07-08 05:32 /dev/nvidiactl
mmas $ sudo rm /dev/nvidia?
mmas $ sudo out/cudaminimal
cuInit:362] CTL handle (/dev/nvidiactl) at fd 3
convert_version:281] Expecting version ‘256.35’
Verified version 256.35
init_ctlfd:325] PAT support: yes
get_card_count:236] Probing for up to 32 cards
get_card_count:261] Found device 1 ID #7 (IRQ 18)
get_card_count:263] Domain: 0 Bus: 7 Slot: 0
get_card_count:265] Vendor ID: 0x10de Device ID: 0x05e7
get_card_count:266] Flags: 0x0001
get_card_count:268] Framebuffer: 0x4000000 @ 0xb4000000
get_card_count:270] Register base: 0x01000000b @ 0xd4000000
get_card_count:261] Found device 2 ID #9 (IRQ 16)
get_card_count:263] Domain: 0 Bus: 9 Slot: 0
get_card_count:268] Framebuffer: 0x4000000 @ 0xb8000000
get_card_count:270] Register base: 0x01000000b @ 0xd8000000
get_card_count:261] Found device 3 ID #17 (IRQ 18)
get_card_count:263] Domain: 0 Bus: 17 Slot: 0
get_card_count:268] Framebuffer: 0x4000000 @ 0xa4000000
get_card_count:270] Register base: 0x01000000b @ 0xc8000000
get_card_count:261] Found device 4 ID #19 (IRQ 16)
get_card_count:263] Domain: 0 Bus: 19 Slot: 0
get_card_count:268] Framebuffer: 0x4000000 @ 0xa8000000
get_card_count:270] Register base: 0x01000000b @ 0xcc000000
Found 4 cards
init_dev:174] Device #0 PMC: 0x2000b @ 0xd4000000
init_dev:192] Device #0 handle (/dev/nvidia0) at fd 4
init_dev:200] Architecture: GA0
GPU returned error 12 on fd 3
init_dev:174] Device #1 PMC: 0x2000b @ 0xd8000000
init_dev:192] Device #1 handle (/dev/nvidia1) at fd 4
init_dev:174] Device #2 PMC: 0x2000b @ 0xc8000000
init_dev:192] Device #2 handle (/dev/nvidia2) at fd 4
init_dev:174] Device #3 PMC: 0x2000b @ 0xcc000000
init_dev:192] Device #3 handle (/dev/nvidia3) at fd 4
Couldn’t initialize CUDA (101)
mmas $ !ls
ls -l /dev/nvidia*
crw-rw-rw- 1 root root 195, 0 2010-07-08 07:08 /dev/nvidia0
crw-rw-rw- 1 root root 195, 1 2010-07-08 07:08 /dev/nvidia1
crw-rw-rw- 1 root root 195, 2 2010-07-08 07:08 /dev/nvidia2
crw-rw-rw- 1 root root 195, 3 2010-07-08 07:08 /dev/nvidia3
mmas $
I hope this helps!
That code isn’t going to run if you’re lacking /dev/nvidia* devices, chief. You’ll draw a 100 or 101 error. Try it and see.
While this topic is pretty old, I figured I would post what I do to create nodes.
I created the following perl script and call it from my /etc/rc.local script
#!/usr/bin/perl -w
my $file = "/dev/nvidiactl";
unless ( -e $file )
    `mknod -m 666 $file c 195 255`;
my @gpus = `ls -1 /proc/driver/nvidia/gpus`;
foreach my $dev(@gpus)
    my $cmd;
    chomp($dev);
    $file = "/dev/nvidia$dev";
unless ( -e $file )
        $cmd = "mknod -m 666 $file c 195 $dev";
        `$cmd`;
