Autosuspend Permission Error in SDK Manager(R36.5.0)
The SDKManager (v2.4.0.13236) installed on Win11 Pro 25H2 worked fine until yesterday but all of sudden start giving ‘autosuspend no permission’ error. Tried reset power, change cable/port and reset USB controller but no luck.
AI gave suggestions to comment out that code in line 46. Where to change it given the SDK manger is running a VM on WSL2?
Or any other authentic solution to work around this permission issue on ‘autosuspend’?
18:54:28 ERROR: Flash Jetson Linux - flash: Error: No Board Spec. and no target connected, exit.
18:54:28 ERROR: Flash Jetson Linux - flash: Error: failed to generate images
18:54:28 INFO: Flash Jetson Linux - flash: Cleaning up…
18:54:28 INFO: Flash Jetson Linux - flash: /home/nvidia/nvidia/nvidia_sdk/JetPack_6.2.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh: line 46: /sys/module/usbcore/parameters/autosuspend: Permission denied
18:54:28 ERROR: Flash Jetson Linux - flash: command error code: 202
18:54:28 DEBUG: Flash Jetson Linux - flash: command terminated with error
The kernel version is R36.5.0(JP6.2.2). See UART log captured by Cytrence Kiwi
@kayccc thank you for re-tagging it. any update regarding the WSL AUTOSUSPEND issue with sdkmanager on windows?
The same setup (same PC, same cables) worked with SDKManager running on native U22. But that was only for verification purpose. In real-workflow, Windows will be more convenient as many other apps are running for team communication. Wondering how others are dealing with such Windows specific challenges too…
Please try to reinstall the sdk manager.
