Auvidea M110
Hi! i’ve got a TX2 connected to an Auvidea J106 and an Auvidea M110. I was able to load Jetpack 3.2 on it, but I need to update the DTB. I downloaded the files from Auvidea, but now I can’t get the board back into recovery mode!
Is there a forum specifically for Auvidea boards, or is this the right place to ask about this? How can I troubleshoot this further?
ok, managed to get it into recovery mode, loaded the new dtb files per the instructions, but I’m still getting “virtual device driver node not found in proc device-tree” when i try to run 10_camera_recording.
Hi wdouglass,
You may need to contact with Auvidea to get the support:
[url]https://auvidea.com/support/[/url]
Cheers
Thank you so much for pointing me in the right direction!
